just tested 6.6.20, unfortunately the same behaviour ![]()
Other users have also reported issues with flow-control with some link partners. Try if disabling flow-control helps:
ethtool -A lanX autoneg off rx off tx off
yes that fixes/workarounds it. is there anything i can do to provide more information so someone can fix it?
You can show ethtool for all ports involved with auto-neg settings and if you compile kernel yourself adding debug to phylink which should result in printing Advertisement in bootlog
yes i compile my own builds. can you tell me where this option is in menuconfig? its so gigantic…
oli@DESKTOP-RA0V02P:~/openwrt$ grep -ri phy .config
CONFIG_DEFAULT_kmod-phy-aquantia=y
# CONFIG_PACKAGE_mt7988-2p5g-phy-firmware is not set
# CONFIG_PACKAGE_kmod-ipt-physdev is not set
# CONFIG_PACKAGE_kmod-fixed-phy is not set
CONFIG_PACKAGE_kmod-libphy=y
# CONFIG_PACKAGE_kmod-phy-airoha-en8811h is not set
# CONFIG_PACKAGE_kmod-phy-amd is not set
# CONFIG_PACKAGE_kmod-phy-aquantia is not set
# CONFIG_PACKAGE_kmod-phy-ax88796b is not set
# CONFIG_PACKAGE_kmod-phy-bcm84881 is not set
# CONFIG_PACKAGE_kmod-phy-broadcom is not set
# CONFIG_PACKAGE_kmod-phy-marvell is not set
# CONFIG_PACKAGE_kmod-phy-marvell-10g is not set
# CONFIG_PACKAGE_kmod-phy-microchip is not set
# CONFIG_PACKAGE_kmod-phy-realtek is not set
# CONFIG_PACKAGE_kmod-phy-smsc is not set
CONFIG_PACKAGE_kmod-phylink=y
# CONFIG_PACKAGE_python3-cryptography is not set
# CONFIG_PACKAGE_iptables-mod-physdev is not set
Only ethtool is available through menuconfig
The other is in source
So just add
#define DEBUG
After includes and before the source-line i pointed above and compile
should i test with 6.6 or better stay with 6.1 and add debug infos. Both are affected, but guess it is better with 6.1 as this is non-experimental, right?
i hope its enabled now, can you check that?
root@OpenWrt:~# cat dmesg.log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.1.81 (oli@DESKTOP-RA0V02P) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r25540-7b89388674) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Wed Mar 13 22:51:23 2024
[ 0.000000] Machine model: Bananapi BPI-R4
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 18 pages/cpu s33384 r8192 d32152 u73728
[ 0.000000] pcpu-alloc: s33384 r8192 d32152 u73728 alloc=18*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa7b4000-0x00000000fe7b4000] (64MB)
[ 0.000000] Memory: 4034692K/4194304K available (8320K kernel code, 886K rwdata, 2416K rodata, 448K init, 289K bss, 159612K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000058] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000065] pid_max: default: 32768 minimum: 301
[ 0.000272] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000286] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000857] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.001064] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001066] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.001140] rcu: Hierarchical SRCU implementation.
[ 0.001142] rcu: Max phase no-delay instances is 1000.
[ 0.001406] smp: Bringing up secondary CPUs ...
[ 0.001621] Detected VIPT I-cache on CPU1
[ 0.001665] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 0.001672] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.001691] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.001917] Detected VIPT I-cache on CPU2
[ 0.001948] cacheinfo: Unable to detect cache hierarchy for CPU 2
[ 0.001952] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.001961] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.002185] Detected VIPT I-cache on CPU3
[ 0.002216] cacheinfo: Unable to detect cache hierarchy for CPU 3
[ 0.002220] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002229] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.002257] smp: Brought up 1 node, 4 CPUs
[ 0.002262] SMP: Total of 4 processors activated.
[ 0.002265] CPU features: detected: 32-bit EL0 Support
[ 0.002267] CPU features: detected: CRC32 instructions
[ 0.002294] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002298] CPU: All CPU(s) started at EL2
[ 0.002299] alternatives: applying system-wide alternatives
[ 0.005758] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005770] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.005866] pinctrl core: initialized pinctrl subsystem
[ 0.006427] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006699] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.006803] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006905] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.007142] thermal_sys: Registered thermal governor 'fair_share'
[ 0.007145] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.007146] thermal_sys: Registered thermal governor 'step_wise'
[ 0.007148] thermal_sys: Registered thermal governor 'user_space'
[ 0.007186] ASID allocator initialised with 65536 entries
[ 0.007661] printk: console [ramoops-1] enabled
[ 0.007700] pstore: Registered ramoops as persistent store backend
[ 0.007704] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.015761] cryptd: max_cpu_qlen set to 1000
[ 0.016536] SCSI subsystem initialized
[ 0.016588] libata version 3.00 loaded.
[ 0.017303] clocksource: Switched to clocksource arch_sys_counter
[ 0.017721] NET: Registered PF_INET protocol family
[ 0.017867] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.019690] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.019712] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.019721] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.019828] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.020234] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.020319] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.020375] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.020535] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.020578] PCI: CLS 0 bytes, default 64
[ 0.021358] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.023336] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.023347] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.042971] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[ 0.043476] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.043495] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.043506] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 0.043518] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 0.043606] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 0.043617] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 0.043626] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 0.043635] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 0.043652] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[ 0.043661] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[ 0.043722] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 0.043732] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 0.043741] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 0.043749] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 0.043765] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[ 0.043773] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[ 0.043844] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 0.043854] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 0.043862] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 0.043871] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 0.043891] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[ 0.043898] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[ 0.047764] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.048299] printk: console [ttyS0] disabled
[ 0.068432] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 0.932622] printk: console [ttyS0] enabled
[ 0.957344] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[ 0.987013] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[ 0.996777] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.004586] loop: module loaded
[ 1.008936] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.014250] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 1.022495] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.028859] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.035728] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[ 1.042707] Creating 2 MTD partitions on "spi0.0":
[ 1.047495] 0x000000000000-0x000000200000 : "bl2"
[ 1.053550] 0x000000200000-0x000008000000 : "ubi"
[ 1.126321] ubi0: default fastmap pool size: 50
[ 1.130854] ubi0: default fastmap WL pool size: 25
[ 1.135633] ubi0: attaching mtd1
[ 1.941471] ubi0: scanning is finished
[ 1.954621] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 1.960105] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 1.966967] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 1.973744] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 1.980693] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 1.986774] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[ 1.993985] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1697192243
[ 2.003103] ubi0: available PEBs: 105, total reserved PEBs: 903, PEBs reserved for bad PEB handling: 20
[ 2.012485] ubi0: background thread "ubi_bgt0d" started, PID 210
[ 2.014104] block ubiblock0_1: created from ubi0:1(rootfs)
[ 2.023974] ubiblock: device ubiblock0_1 (rootfs) set to be root filesystem
[ 2.158718] i2c_dev: i2c /dev entries driver
[ 2.178210] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 2.187910] mtk-msdc 11230000.mmc: Got CD GPIO
[ 2.188030] NET: Registered PF_INET6 protocol family
[ 2.197744] Segment Routing with IPv6
[ 2.201410] In-situ OAM (IOAM) with IPv6
[ 2.205347] NET: Registered PF_PACKET protocol family
[ 2.210447] 8021q: 802.1Q VLAN Support v1.8
[ 2.215310] pstore: Using crash dump compression: deflate
[ 2.229056] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[ 2.236054] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 2.243426] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 2.249697] mtk-pcie-gen3 11280000.pcie: IO 0x0020000000..0x00201fffff -> 0x0020000000
[ 2.258136] mtk-pcie-gen3 11280000.pcie: MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[ 2.284356] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.294366] mmc0: new high speed SDHC card at address 59b4
[ 2.300445] mmcblk0: mmc0:59b4 USD 29.5 GiB
[ 2.309464] Alternate GPT is invalid, using primary GPT.
[ 2.315562] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.607329] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.616129] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 2.623163] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[ 2.630476] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[ 2.636738] mtk-pcie-gen3 11290000.pcie: IO 0x0028000000..0x00281fffff -> 0x0028000000
[ 2.645172] mtk-pcie-gen3 11290000.pcie: MEM 0x0028200000..0x002fffffff -> 0x0028200000
[ 2.987307] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 2.996084] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[ 3.002932] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[ 3.010239] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[ 3.016498] mtk-pcie-gen3 11300000.pcie: IO 0x0030000000..0x00301fffff -> 0x0030000000
[ 3.024929] mtk-pcie-gen3 11300000.pcie: MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[ 3.367326] mtk-pcie-gen3 11300000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[ 3.376103] mtk-pcie-gen3: probe of 11300000.pcie failed with error -110
[ 3.382955] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[ 3.390263] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[ 3.396520] mtk-pcie-gen3 11310000.pcie: IO 0x0038000000..0x00381fffff -> 0x0038000000
[ 3.404951] mtk-pcie-gen3 11310000.pcie: MEM 0x0038200000..0x003fffffff -> 0x0038200000
[ 3.650077] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[ 3.661457] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[ 3.672922] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[ 3.684384] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[ 3.695847] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[ 3.707397] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[ 3.718946] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[ 3.730612] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[ 3.737216] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.742696] pci_bus 0001:00: root bus resource [io 0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[ 3.752511] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[ 3.759376] pci_bus 0001:00: scanning bus
[ 3.763394] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[ 3.769406] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 3.776241] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.782327] pci 0001:00:00.0: PME# disabled
[ 3.787704] pci_bus 0001:00: fixups for bus
[ 3.791880] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 3.798572] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.806568] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 3.813309] pci_bus 0001:01: scanning bus
[ 3.817336] pci 0001:01:00.0: [14c3:7615] type 00 class 0x000280
[ 3.823354] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[ 3.857320] pci_bus 0001:01: fixups for bus
[ 3.861493] pci_bus 0001:01: bus scan returning with max=01
[ 3.867053] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.873664] pci_bus 0001:00: bus scan returning with max=01
[ 3.879238] pci 0001:00:00.0: BAR 8: assigned [mem 0x38200000-0x382fffff]
[ 3.886015] pci 0001:00:00.0: BAR 0: assigned [mem 0x38300000-0x38307fff 64bit]
[ 3.893320] pci 0001:01:00.0: BAR 0: assigned [mem 0x38200000-0x382fffff 64bit]
[ 3.900629] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.905584] pci 0001:00:00.0: bridge window [mem 0x38200000-0x382fffff]
[ 3.912372] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.920814] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 3.929306] pcieport 0001:00:00.0: assign IRQ: got 112
[ 3.934437] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[ 3.940531] pcieport 0001:00:00.0: enabling bus mastering
[ 3.946178] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 3.954612] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 3.963039] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[ 3.971464] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[ 3.979893] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[ 3.988319] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[ 3.996742] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[ 4.005168] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[ 4.013594] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[ 4.022019] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[ 4.030445] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[ 4.038957] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[ 4.047469] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[ 4.055979] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[ 4.064491] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[ 4.073003] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[ 4.081515] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[ 4.090118] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[ 4.098721] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[ 4.107321] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[ 4.115918] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[ 4.124517] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[ 4.133116] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[ 4.141715] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[ 4.150313] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[ 4.158912] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[ 4.167511] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[ 4.176108] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[ 4.184707] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[ 4.193306] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[ 4.201906] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[ 4.210505] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[ 4.219403] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[ 4.227891] pcieport 0001:00:00.0: PME: Signaling with IRQ 113
[ 4.233815] pcieport 0001:00:00.0: AER: enabled with IRQ 113
[ 4.239503] pcieport 0001:00:00.0: saving config space at offset 0x0 (reading 0x798814c3)
[ 4.247672] pcieport 0001:00:00.0: saving config space at offset 0x4 (reading 0x100406)
[ 4.255662] pcieport 0001:00:00.0: saving config space at offset 0x8 (reading 0x6040001)
[ 4.263740] pcieport 0001:00:00.0: saving config space at offset 0xc (reading 0x10000)
[ 4.271645] pcieport 0001:00:00.0: saving config space at offset 0x10 (reading 0x38300004)
[ 4.279897] pcieport 0001:00:00.0: saving config space at offset 0x14 (reading 0x0)
[ 4.287541] pcieport 0001:00:00.0: saving config space at offset 0x18 (reading 0x10100)
[ 4.295532] pcieport 0001:00:00.0: saving config space at offset 0x1c (reading 0x1f1)
[ 4.303349] pcieport 0001:00:00.0: saving config space at offset 0x20 (reading 0x38203820)
[ 4.311601] pcieport 0001:00:00.0: saving config space at offset 0x24 (reading 0x1fff1)
[ 4.319592] pcieport 0001:00:00.0: saving config space at offset 0x28 (reading 0x0)
[ 4.327234] pcieport 0001:00:00.0: saving config space at offset 0x2c (reading 0x0)
[ 4.334879] pcieport 0001:00:00.0: saving config space at offset 0x30 (reading 0x0)
[ 4.342525] pcieport 0001:00:00.0: saving config space at offset 0x34 (reading 0x80)
[ 4.350257] pcieport 0001:00:00.0: saving config space at offset 0x38 (reading 0x0)
[ 4.357901] pcieport 0001:00:00.0: saving config space at offset 0x3c (reading 0x20170)
[ 4.367013] FIT: Detected U-Boot 2024.01-OpenWrt-r25540-7b89388674
[ 4.373192] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[ 4.382272] FIT: kernel sub-image 0x00001000..0x00540d6c "kernel-1" (ARM64 OpenWrt Linux-6.1.81)
[ 4.392006] FIT: flat_dt sub-image 0x00541000..0x0054b822 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4 device tree blob)
[ 4.403215] FIT: flat_dt sub-image 0x0054c000..0x0054c611 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[ 4.419544] FIT: flat_dt sub-image 0x0054d000..0x0054d11c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[ 4.435699] FIT: flat_dt sub-image 0x0054e000..0x0054e5c9 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[ 4.451681] FIT: flat_dt sub-image 0x0054f000..0x0054f8eb "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[ 4.469397] FIT: filesystem sub-image 0x00550000..0x01810fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4 rootfs)
[ 4.480217] block mmcblk0p7: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[ 4.487931] block mmcblk0p7: mapped remaing space as /dev/fitrw
[ 4.618785] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[ 4.626970] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[ 4.635146] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[ 4.645348] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc00a300000, irq 103
[ 4.654966] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc00a300000, irq 103
[ 4.664587] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc00a300000, irq 103
[ 4.753588] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[ 4.761094] mt7530-mmio 15020000.switch: major config internal
[ 4.766915] mt7530-mmio 15020000.switch: phylink_mac_config: mode=fixed/internal/10Gbps/Full/none adv=00000000,00000400,00006240 pause=03 link=0
[ 4.779871] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[ 4.804188] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=115)
[ 4.814792] mt7530-mmio 15020000.switch wan (uninitialized): phy: internal setting supported 00000000,00000000,000062ef advertising 00000000,00000000,000062ef
[ 4.853602] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=116)
[ 4.864290] mt7530-mmio 15020000.switch lan1 (uninitialized): phy: internal setting supported 00000000,00000000,000062ef advertising 00000000,00000000,000062ef
[ 4.902997] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=117)
[ 4.913686] mt7530-mmio 15020000.switch lan2 (uninitialized): phy: internal setting supported 00000000,00000000,000062ef advertising 00000000,00000000,000062ef
[ 4.953080] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=118)
[ 4.963769] mt7530-mmio 15020000.switch lan3 (uninitialized): phy: internal setting supported 00000000,00000000,000062ef advertising 00000000,00000000,000062ef
[ 4.978287] device eth0 entered promiscuous mode
[ 4.982907] DSA: tree 0 setup
[ 4.986492] UBI: auto-attach mtd1
[ 4.989809] ubi: mtd1 is already attached to ubi0
[ 4.994501] UBI error: cannot attach mtd1
[ 5.006912] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[ 5.014165] Freeing unused kernel memory: 448K
[ 5.057386] Run /sbin/init as init process
[ 5.061473] with arguments:
[ 5.064429] /sbin/init
[ 5.067126] with environment:
[ 5.070260] HOME=/
[ 5.072609] TERM=linux
[ 5.209107] init: Console is alive
[ 5.212620] init: - watchdog -
[ 5.792845] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.832747] pps_core: LinuxPPS API ver. 1 registered
[ 5.837729] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 5.847480] PTP clock support registered
[ 5.853536] usbcore: registered new interface driver usbfs
[ 5.859079] usbcore: registered new interface driver hub
[ 5.864404] usbcore: registered new device driver usb
[ 5.872756] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 5.880172] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 5.888034] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.893263] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 5.903707] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 5.912890] xhci-mtk 11200000.usb: irq 119, io mem 0x11200000
[ 5.918706] xhci-mtk 11200000.usb: xHCI Host Controller
[ 5.923923] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 5.931312] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 5.938622] hub 1-0:1.0: USB hub found
[ 5.942378] hub 1-0:1.0: 1 port detected
[ 5.946468] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.954753] hub 2-0:1.0: USB hub found
[ 5.958514] hub 2-0:1.0: 1 port detected
[ 5.964823] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.974838] init: - preinit -
[ 6.196213] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 6.204363] mtk_soc_eth 15100000.ethernet eth0: major config internal
[ 6.210797] mtk_soc_eth 15100000.ethernet eth0: phylink_mac_config: mode=fixed/internal/10Gbps/Full/none adv=00000000,00000400,00006240 pause=03 link=0
[ 6.224376] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 6.231514] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 6.240691] mt7530-mmio 15020000.switch lan1: major config internal
[ 6.246949] mt7530-mmio 15020000.switch lan1: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 6.260627] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6.260952] mt7530-mmio 15020000.switch lan1: phy link down internal/Unknown/Unknown/none/off
[ 6.397322] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 6.579918] hub 1-1:1.0: USB hub found
[ 6.583838] hub 1-1:1.0: 5 ports detected
[ 6.727501] usb 2-1: new SuperSpeed USB device number 2 using xhci-mtk
[ 6.760010] hub 2-1:1.0: USB hub found
[ 6.763937] hub 2-1:1.0: 4 ports detected
[ 7.277304] usb 1-1.5: new high-speed USB device number 3 using xhci-mtk
[ 7.587306] random: crng init done
[ 8.590025] EXT4-fs (fitrw): recovery complete
[ 8.601148] EXT4-fs (fitrw): mounted filesystem with ordered data mode. Quota mode: disabled.
[ 8.613070] mount_root: switching to ext4 overlay
[ 8.619792] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 8.630735] urandom-seed: Seeding with /etc/urandom.seed
[ 8.672405] procd: - early -
[ 8.675339] procd: - watchdog -
[ 9.220018] procd: - watchdog -
[ 9.255976] procd: - ubus -
[ 9.410412] procd: - init -
[ 9.630416] kmodloader: loading kernel modules from /etc/modules.d/*
[ 9.676743] i2c i2c-1: Added multiplexed i2c bus 2
[ 9.681637] i2c i2c-1: Added multiplexed i2c bus 3
[ 9.686478] i2c i2c-1: Added multiplexed i2c bus 4
[ 9.691321] i2c i2c-1: Added multiplexed i2c bus 5
[ 9.696104] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[ 9.706560] crypto-safexcel 15600000.crypto: can't request region for resource [mem 0x15600000-0x1577ffff]
[ 9.716234] crypto-safexcel 15600000.crypto: failed to get resource
[ 9.722492] crypto-safexcel: probe of 15600000.crypto failed with error -16
[ 9.726903] urngd: v1.0.2 started.
[ 9.734590] at24 2-0050: supply vcc not found, using dummy regulator
[ 9.770659] at24 2-0057: supply vcc not found, using dummy regulator
[ 9.777590] at24 2-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 9.784621] Loading modules backported from Linux version v6.6.15-0-g51f354b815c4
[ 9.792115] Backport generated by backports.git 193becf2
[ 9.802050] sfp sfp1: Host maximum power 3.0W
[ 9.806894] sfp sfp2: Host maximum power 3.0W
[ 9.817600] Intel(R) Wireless WiFi driver for Linux
[ 9.831849] mt7615e 0001:01:00.0: assign IRQ: got 112
[ 9.836917] mt7615e 0001:01:00.0: enabling device (0000 -> 0002)
[ 9.842957] mt7615e 0001:01:00.0: enabling bus mastering
[ 9.848331] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[ 9.860821] mt7615e 0001:01:00.0: registering led 'mt76-phy0'
[ 9.866857] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 9.874039] mt7615e 0001:01:00.0: registering led 'mt76-phy1'
[ 9.880171] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 9.886968] ieee80211 phy1: copying sband (band 1) due to VHT EXT NSS BW flag
[ 9.912377] PPP generic driver version 2.4.2
[ 9.915971] mt7615e 0001:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[ 9.915971]
[ 9.926557] NET: Registered PF_PPPOX protocol family
[ 10.028742] mt7615e 0001:01:00.0: N9 Firmware Version: _reserved_, Build Time: 20200814163649
[ 10.038242] RTL871X: module init start
[ 10.041998] RTL871X: rtl8812au v4.3.14_13455.20150212_BTCOEX20150128-51
[ 10.048609] RTL871X: rtl8812au BT-Coex version = BTCOEX20150128-51
[ 10.054866] usbcore: registered new interface driver rtl8812au
[ 10.060696] RTL871X: module init ret=0
[ 10.068308] mt7615e 0001:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20190415154149
[ 10.077218] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 10.085061] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 10.109685] usbcore: registered new interface driver ath9k_htc
[ 10.117380] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 10.128619] sfp sfp1: module OEM GLC-BX-U-C rev 1.0 sn 1152216730 dc 150602
[ 10.138031] mtk_soc_eth 15100000.ethernet eth2: optical SFP: interfaces=[mac=2-4,22-24,27,29, sfp=22]
[ 10.147251] mtk_soc_eth 15100000.ethernet eth2: optical SFP: chosen 1000base-x interface
[ 10.155402] mtk_soc_eth 15100000.ethernet eth2: requesting link mode inband/1000base-x with support 00000000,00000200,00006440
[ 10.166803] mtk_soc_eth 15100000.ethernet eth2: switched to inband/1000base-x link mode
[ 10.197813] sfp sfp2: module OEM SFP+10G-T rev A sn WEPOQTBZ1001 dc 230915
[ 10.199793] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 10.207221] mtk_soc_eth 15100000.ethernet eth1: optical SFP: interfaces=[mac=1-4,22-24,27,29, sfp=27]
[ 10.222990] mtk_soc_eth 15100000.ethernet eth1: optical SFP: chosen 10gbase-r interface
[ 10.231005] mtk_soc_eth 15100000.ethernet eth1: requesting link mode inband/10gbase-r with support 00000000,00000800,00006440
[ 10.242320] mtk_soc_eth 15100000.ethernet eth1: switched to inband/10gbase-r link mode
[ 10.261441] hwmon hwmon3: temp1_input not attached to any thermal zone
[ 12.377468] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[ 12.385747] mtk_soc_eth 15100000.ethernet eth1: major config 10gbase-r
[ 12.393179] mtk_soc_eth 15100000.ethernet eth1: phylink_mac_config: mode=inband/10gbase-r/Unknown/Unknown/none adv=00000000,00000800,00006440 pause=04 link=0
[ 12.420682] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/1000base-x link mode
[ 12.429084] mtk_soc_eth 15100000.ethernet eth2: major config 1000base-x
[ 12.436256] mtk_soc_eth 15100000.ethernet eth2: phylink_mac_config: mode=inband/1000base-x/Unknown/Unknown/none adv=00000000,00000200,00006440 pause=04 link=0
[ 12.454840] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 12.462540] mt7530-mmio 15020000.switch wan: major config internal
[ 12.468746] mt7530-mmio 15020000.switch wan: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 12.484695] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 12.485110] mt7530-mmio 15020000.switch wan: phy link up internal/1Gbps/Full/none/rx/tx
[ 12.489772] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.492466] mt7530-mmio 15020000.switch lan1: major config internal
[ 12.492471] mt7530-mmio 15020000.switch lan1: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 12.530457] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
[ 12.537353] mt7530-mmio 15020000.switch lan1: phy link down internal/Unknown/Unknown/none/off
[ 12.537432] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[ 12.553698] mt7530-mmio 15020000.switch lan2: major config internal
[ 12.560008] mt7530-mmio 15020000.switch lan2: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 12.574239] mt7530-mmio 15020000.switch lan2: phy link up internal/100Mbps/Full/none/rx/tx
[ 12.574425] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[ 12.578730] mt7530-mmio 15020000.switch lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 12.598725] mt7530-mmio 15020000.switch lan3: major config internal
[ 12.604992] mt7530-mmio 15020000.switch lan3: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 12.619787] IPv6: ADDRCONF(NETDEV_CHANGE): lan2: link becomes ready
[ 12.620222] mt7530-mmio 15020000.switch lan3: phy link down internal/Unknown/Unknown/none/off
[ 12.671387] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[ 12.679711] mtk_soc_eth 15100000.ethernet eth1: major config 10gbase-r
[ 12.686250] mtk_soc_eth 15100000.ethernet eth1: phylink_mac_config: mode=inband/10gbase-r/Unknown/Unknown/none adv=00000000,00000800,00006440 pause=04 link=0
[ 12.723662] br-lan: port 1(eth1) entered blocking state
[ 12.728919] br-lan: port 1(eth1) entered disabled state
[ 12.734313] device eth1 entered promiscuous mode
[ 12.750885] mt7530-mmio 15020000.switch lan2: phy link down internal/100Mbps/Full/none/rx/tx
[ 12.757200] mt7530-mmio 15020000.switch lan2: Link is Down
[ 12.764964] mt7530-mmio 15020000.switch wan: phy link down internal/1Gbps/Full/none/rx/tx
[ 12.765163] mt7530-mmio 15020000.switch wan: Link is Down
[ 12.780208] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 12.788254] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 12.796354] mtk_soc_eth 15100000.ethernet eth0: major config internal
[ 12.802844] mtk_soc_eth 15100000.ethernet eth0: phylink_mac_config: mode=fixed/internal/10Gbps/Full/none adv=00000000,00000400,00006240 pause=03 link=0
[ 12.816464] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 12.819262] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[ 12.832755] mt7530-mmio 15020000.switch lan1: major config internal
[ 12.839120] mt7530-mmio 15020000.switch lan1: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 12.852944] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.853380] mt7530-mmio 15020000.switch lan1: phy link down internal/Unknown/Unknown/none/off
[ 12.867784] br-lan: port 2(lan1) entered blocking state
[ 12.873014] br-lan: port 2(lan1) entered disabled state
[ 12.878611] device lan1 entered promiscuous mode
[ 12.886796] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[ 12.894606] mt7530-mmio 15020000.switch lan2: major config internal
[ 12.900899] mt7530-mmio 15020000.switch lan2: phylink_mac_config: mode=phy/internal/100Mbps/Full/none adv=00000000,00000000,00000000 pause=03 link=0
[ 12.914756] mt7530-mmio 15020000.switch lan2: phy link down internal/Unknown/Unknown/none/off
[ 12.923346] br-lan: port 3(lan2) entered blocking state
[ 12.928598] br-lan: port 3(lan2) entered disabled state
[ 12.934121] device lan2 entered promiscuous mode
[ 12.938909] br-lan: port 3(lan2) entered blocking state
[ 12.944135] br-lan: port 3(lan2) entered forwarding state
[ 12.949657] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 12.956309] br-lan: port 3(lan2) entered disabled state
[ 12.964990] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[ 12.972795] mt7530-mmio 15020000.switch lan3: major config internal
[ 12.979107] mt7530-mmio 15020000.switch lan3: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
[ 12.993854] mt7530-mmio 15020000.switch lan3: phy link down internal/Unknown/Unknown/none/off
[ 13.002445] br-lan: port 4(lan3) entered blocking state
[ 13.007686] br-lan: port 4(lan3) entered disabled state
[ 13.013121] device lan3 entered promiscuous mode
[ 13.020805] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 13.028534] mt7530-mmio 15020000.switch wan: major config internal
[ 13.034710] mt7530-mmio 15020000.switch wan: phylink_mac_config: mode=phy/internal/1Gbps/Full/none adv=00000000,00000000,00000000 pause=03 link=0
[ 13.048275] mt7530-mmio 15020000.switch wan: phy link down internal/Unknown/Unknown/none/off
[ 13.056722] br-lan: port 5(wan) entered blocking state
[ 13.061870] br-lan: port 5(wan) entered disabled state
[ 13.067168] device wan entered promiscuous mode
[ 13.071755] br-lan: port 5(wan) entered blocking state
[ 13.076892] br-lan: port 5(wan) entered forwarding state
[ 13.085212] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/1000base-x link mode
[ 13.093681] mtk_soc_eth 15100000.ethernet eth2: major config 1000base-x
[ 13.100313] mtk_soc_eth 15100000.ethernet eth2: phylink_mac_config: mode=inband/1000base-x/Unknown/Unknown/none adv=00000000,00000200,00006440 pause=04 link=0
[ 13.537601] br-lan: port 5(wan) entered disabled state
[ 14.169641] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[ 14.178010] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[ 14.512451] mt7530-mmio 15020000.switch lan2: phy link up internal/100Mbps/Full/none/rx/tx
[ 14.512908] mt7530-mmio 15020000.switch lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 14.529591] br-lan: port 3(lan2) entered blocking state
[ 14.534823] br-lan: port 3(lan2) entered forwarding state
[ 15.981501] mt7530-mmio 15020000.switch wan: phy link up internal/1Gbps/Full/none/rx/tx
[ 15.982175] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 28.330354] br-lan: port 6(phy0-ap0) entered blocking state
[ 28.335930] br-lan: port 6(phy0-ap0) entered disabled state
[ 28.341645] device phy0-ap0 entered promiscuous mode
[ 28.346681] br-lan: port 6(phy0-ap0) entered blocking state
[ 28.352264] br-lan: port 6(phy0-ap0) entered forwarding state
[ 28.358137] br-lan: port 5(wan) entered blocking state
[ 28.363269] br-lan: port 5(wan) entered forwarding state
[ 28.368691] br-lan: port 6(phy0-ap0) entered disabled state
[ 28.376562] device phy0-ap0 left promiscuous mode
[ 28.381379] br-lan: port 6(phy0-ap0) entered disabled state
[ 28.450176] br-lan: port 6(phy0-ap0) entered blocking state
[ 28.455761] br-lan: port 6(phy0-ap0) entered disabled state
[ 28.461586] device phy0-ap0 entered promiscuous mode
[ 28.471219] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap0: link becomes ready
[ 28.477936] br-lan: port 6(phy0-ap0) entered blocking state
[ 28.483512] br-lan: port 6(phy0-ap0) entered forwarding state
[ 28.635492] br-lan: port 7(phy1-ap0) entered blocking state
[ 28.641095] br-lan: port 7(phy1-ap0) entered disabled state
[ 28.647290] device phy1-ap0 entered promiscuous mode
[ 28.652435] br-lan: port 7(phy1-ap0) entered blocking state
[ 28.658018] br-lan: port 7(phy1-ap0) entered forwarding state
[ 29.055192] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap0: link becomes ready
root@OpenWrt:~# cat logread.log
Wed Mar 13 22:51:30 2024 daemon.info dhcpcd[1999]: DUID 00:01:00:01:2d:84:ea:72:36:18:cf:43:52:7e
Wed Mar 13 22:51:30 2024 daemon.info dhcpcd[1999]: eth0: IAID cf:43:52:7e
Wed Mar 13 22:51:30 2024 daemon.err dhcpcd[1999]: eth0: IAID conflicts with one assigned to wan
Wed Mar 13 22:51:30 2024 kern.info kernel: [ 12.377468] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.385747] mtk_soc_eth 15100000.ethernet eth1: major config 10gbase-r
Wed Mar 13 22:51:30 2024 user.debug adblock-4.1.5[1938]: f_jsnup ::: status: running, cnt: , mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Wed Mar 13 22:51:30 2024 user.debug adblock-4.1.5[1938]: f_uci ::: config: dhcp, change:
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.393179] mtk_soc_eth 15100000.ethernet eth1: phylink_mac_config: mode=inband/10gbase-r/Unknown/Unknown/none adv=00000000,00000800,00006440 pause=04 link=0
Wed Mar 13 22:51:30 2024 user.debug adblock-4.1.5[1938]: f_uci ::: config: firewall, change:
Wed Mar 13 22:51:30 2024 daemon.info dhcpcd[1999]: eth1: waiting for carrier
Wed Mar 13 22:51:30 2024 user.debug adblock-4.1.5[1938]: f_temp ::: tmp_base: /tmp, tmp_dir: /tmp/tmp.nMBNkc, sort_options: --temporary-directory=/tmp/tmp.nMBNkc --compress-program=gzip --parallel=4, pid_file: /var/run/adblock.pid
Wed Mar 13 22:51:30 2024 local0.notice udpxy[2242]: udpxy 1.0-25.1 (prod) standard [Linux 6.1.81 aarch64] is starting
Wed Mar 13 22:51:30 2024 kern.info kernel: [ 12.420682] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/1000base-x link mode
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.429084] mtk_soc_eth 15100000.ethernet eth2: major config 1000base-x
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.436256] mtk_soc_eth 15100000.ethernet eth2: phylink_mac_config: mode=inband/1000base-x/Unknown/Unknown/none adv=00000000,00000200,00006440 pause=04 link=0
Wed Mar 13 22:51:30 2024 daemon.info dhcpcd[1999]: eth2: waiting for carrier
Wed Mar 13 22:51:30 2024 kern.info kernel: [ 12.454840] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.462540] mt7530-mmio 15020000.switch wan: major config internal
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.468746] mt7530-mmio 15020000.switch wan: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
Wed Mar 13 22:51:30 2024 daemon.info dhcpcd[1999]: wan: waiting for carrier
Wed Mar 13 22:51:30 2024 kern.info kernel: [ 12.484695] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.485110] mt7530-mmio 15020000.switch wan: phy link up internal/1Gbps/Full/none/rx/tx
Wed Mar 13 22:51:30 2024 kern.info kernel: [ 12.489772] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.492466] mt7530-mmio 15020000.switch lan1: major config internal
Wed Mar 13 22:51:30 2024 kern.debug kernel: [ 12.492471] mt7530-mmio 15020000.switch lan1: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_main ::: memory: 4035/3930/3921, cores: 4, safe_search: 0, force_dns: 0, awk: /usr/bin/awk
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: iplist, mode: iplist, cnt: 0, in_rc: 0, out_rc: 0
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.530457] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.537353] mt7530-mmio 15020000.switch lan1: phy link down internal/Unknown/Unknown/none/off
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.537432] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan1: waiting for carrier
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: blacklist, mode: blacklist, cnt: 0, in_rc: 0, out_rc: 0
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.553698] mt7530-mmio 15020000.switch lan2: major config internal
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.560008] mt7530-mmio 15020000.switch lan2: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: waiting for carrier
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.574239] mt7530-mmio 15020000.switch lan2: phy link up internal/100Mbps/Full/none/rx/tx
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.574425] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.578730] mt7530-mmio 15020000.switch lan2: Link is Up - 100Mbps/Full - flow control rx/tx
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/network
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/wireless
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.598725] mt7530-mmio 15020000.switch lan3: major config internal
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.604992] mt7530-mmio 15020000.switch lan3: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan3: waiting for carrier
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: wan: carrier acquired
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.619787] IPv6: ADDRCONF(NETDEV_CHANGE): lan2: link becomes ready
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.620222] mt7530-mmio 15020000.switch lan3: phy link down internal/Unknown/Unknown/none/off
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/luci-splash reload dependency on /etc/config/firewall
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/qos reload dependency on /etc/config/firewall
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: wan: IAID cf:43:52:7e
Wed Mar 13 22:51:31 2024 daemon.err dhcpcd[1999]: wan: IAID conflicts with one assigned to eth0
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: wan: adding address fe80::12e6:b454:4ccb:e989
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: whitelist, mode: whitelist, cnt: 1, in_rc: 0, out_rc: 0
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/miniupnpd reload dependency on /etc/config/firewall
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: carrier acquired
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: adaway, mode: restore, cnt: 0, in_rc: 4, out_rc: 4
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: adguard, mode: restore, cnt: 0, in_rc: 4, out_rc: 4
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: disconnect, mode: restore, cnt: 0, in_rc: 4, out_rc: 4
Wed Mar 13 22:51:31 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: easylist, mode: restore, cnt: 0, in_rc: 4, out_rc: 4
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.671387] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.679711] mtk_soc_eth 15100000.ethernet eth1: major config 10gbase-r
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.686250] mtk_soc_eth 15100000.ethernet eth1: phylink_mac_config: mode=inband/10gbase-r/Unknown/Unknown/none adv=00000000,00000800,00006440 pause=04 link=0
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/odhcpd reload dependency on /etc/config/dhcp
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: IAID cf:43:52:7e
Wed Mar 13 22:51:31 2024 daemon.err dhcpcd[1999]: lan2: IAID conflicts with one assigned to eth0
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: adding address fe80::12e6:b454:4ccb:e989
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.723662] br-lan: port 1(eth1) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.728919] br-lan: port 1(eth1) entered disabled state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.734313] device eth1 entered promiscuous mode
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'lan' is enabled
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'lan' is setting up now
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'lan' is now up
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: soliciting an IPv6 router
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.750885] mt7530-mmio 15020000.switch lan2: phy link down internal/100Mbps/Full/none/rx/tx
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.757200] mt7530-mmio 15020000.switch lan2: Link is Down
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.764964] mt7530-mmio 15020000.switch wan: phy link down internal/1Gbps/Full/none/rx/tx
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.765163] mt7530-mmio 15020000.switch wan: Link is Down
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: carrier lost
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.780208] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: lan2: deleting address fe80::12e6:b454:4ccb:e989
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.788254] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.796354] mtk_soc_eth 15100000.ethernet eth0: major config internal
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.802844] mtk_soc_eth 15100000.ethernet eth0: phylink_mac_config: mode=fixed/internal/10Gbps/Full/none adv=00000000,00000400,00006240 pause=03 link=0
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.816464] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: wan: carrier lost
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.819262] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.832755] mt7530-mmio 15020000.switch lan1: major config internal
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: wan: deleting address fe80::12e6:b454:4ccb:e989
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.839120] mt7530-mmio 15020000.switch lan1: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.852944] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.853380] mt7530-mmio 15020000.switch lan1: phy link down internal/Unknown/Unknown/none/off
Wed Mar 13 22:51:31 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.867784] br-lan: port 2(lan1) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.873014] br-lan: port 2(lan1) entered disabled state
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: eth0: carrier lost
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.878611] device lan1 entered promiscuous mode
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.886796] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.894606] mt7530-mmio 15020000.switch lan2: major config internal
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/luci_statistics reload dependency on /etc/config/system
Wed Mar 13 22:51:31 2024 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/system
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.900899] mt7530-mmio 15020000.switch lan2: phylink_mac_config: mode=phy/internal/100Mbps/Full/none adv=00000000,00000000,00000000 pause=03 link=0
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: eth0: carrier acquired
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.914756] mt7530-mmio 15020000.switch lan2: phy link down internal/Unknown/Unknown/none/off
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.923346] br-lan: port 3(lan2) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.928598] br-lan: port 3(lan2) entered disabled state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.934121] device lan2 entered promiscuous mode
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.938909] br-lan: port 3(lan2) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.944135] br-lan: port 3(lan2) entered forwarding state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.949657] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.956309] br-lan: port 3(lan2) entered disabled state
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: eth0: IAID cf:43:52:7e
Wed Mar 13 22:51:31 2024 daemon.err dhcpcd[1999]: eth0: IAID conflicts with one assigned to wan
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: eth0: adding address fe80::12e6:b454:4ccb:e989
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 12.964990] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.972795] mt7530-mmio 15020000.switch lan3: major config internal
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.979107] mt7530-mmio 15020000.switch lan3: phylink_mac_config: mode=phy/internal/Unknown/Unknown/none adv=00000000,00000000,00000000 pause=00 link=0
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 12.993854] mt7530-mmio 15020000.switch lan3: phy link down internal/Unknown/Unknown/none/off
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.002445] br-lan: port 4(lan3) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.007686] br-lan: port 4(lan3) entered disabled state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.013121] device lan3 entered promiscuous mode
Wed Mar 13 22:51:31 2024 daemon.err dhcpcd[1999]: ipv6_addaddr1: Permission denied
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.020805] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 13.028534] mt7530-mmio 15020000.switch wan: major config internal
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 13.034710] mt7530-mmio 15020000.switch wan: phylink_mac_config: mode=phy/internal/1Gbps/Full/none adv=00000000,00000000,00000000 pause=03 link=0
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 13.048275] mt7530-mmio 15020000.switch wan: phy link down internal/Unknown/Unknown/none/off
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.056722] br-lan: port 5(wan) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.061870] br-lan: port 5(wan) entered disabled state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.067168] device wan entered promiscuous mode
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.071755] br-lan: port 5(wan) entered blocking state
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.076892] br-lan: port 5(wan) entered forwarding state
Wed Mar 13 22:51:31 2024 daemon.notice netifd: bridge 'br-lan' link is up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'lan' has link connectivity
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'loopback' is enabled
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'loopback' is setting up now
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'loopback' is now up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'vpn' is setting up now
Wed Mar 13 22:51:31 2024 kern.info kernel: [ 13.085212] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/1000base-x link mode
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 13.093681] mtk_soc_eth 15100000.ethernet eth2: major config 1000base-x
Wed Mar 13 22:51:31 2024 kern.debug kernel: [ 13.100313] mtk_soc_eth 15100000.ethernet eth2: phylink_mac_config: mode=inband/1000base-x/Unknown/Unknown/none adv=00000000,00000200,00006440 pause=04 link=0
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'wan' is enabled
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'wan6' is enabled
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: eth2: old hardware address: 76:e2:fe:7b:08:bc
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: eth2: new hardware address: 24:a4:3c:b3:b2:f6
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'wan' link is up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'lan2' link is up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: bridge 'br-lan' link is down
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'lan' has link connectivity loss
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'lan2' link is down
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'wan' link is down
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'eth0' link is up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'lo' link is up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'loopback' has link connectivity
Wed Mar 13 22:51:31 2024 daemon.notice netifd: radio0 (2772): WARNING: Variable 'data' does not exist or is not an array/object
Wed Mar 13 22:51:31 2024 daemon.notice netifd: radio1 (2773): WARNING: Variable 'data' does not exist or is not an array/object
Wed Mar 13 22:51:31 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led lan0
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: vpn: waiting for carrier
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: vpn: carrier acquired
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: vpn: IAID 76:70:6e:00
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: vpn: waiting for 3rd party to configure IP address
Wed Mar 13 22:51:31 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led lan1
Wed Mar 13 22:51:31 2024 daemon.notice procd: /etc/rc.d/S96led: sh: write error: Invalid argument
Wed Mar 13 22:51:31 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led lan2
Wed Mar 13 22:51:31 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led lan3
Wed Mar 13 22:51:31 2024 daemon.info dhcpcd[1999]: vpn: carrier lost
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Interface 'vpn' is now up
Wed Mar 13 22:51:31 2024 daemon.notice netifd: Network device 'vpn' link is up
Wed Mar 13 22:51:32 2024 daemon.info dhcpcd[1999]: wan: carrier lost
Wed Mar 13 22:51:32 2024 kern.info kernel: [ 13.537601] br-lan: port 5(wan) entered disabled state
Wed Mar 13 22:51:32 2024 daemon.info procd: - init complete -
Wed Mar 13 22:51:32 2024 daemon.info dhcpcd[1999]: eth0: soliciting an IPv6 router
Wed Mar 13 22:51:32 2024 daemon.notice netifd: Network device 'eth2' link is up
Wed Mar 13 22:51:32 2024 daemon.info dhcpcd[1999]: eth2: carrier acquired
Wed Mar 13 22:51:32 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Wed Mar 13 22:51:32 2024 daemon.notice netifd: Interface 'wan' is setting up now
Wed Mar 13 22:51:32 2024 daemon.notice netifd: Interface 'wan6' has link connectivity
Wed Mar 13 22:51:32 2024 daemon.notice netifd: Interface 'wan6' is setting up now
Wed Mar 13 22:51:32 2024 kern.info kernel: [ 14.169641] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Wed Mar 13 22:51:32 2024 kern.info kernel: [ 14.178010] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Wed Mar 13 22:51:32 2024 daemon.info dhcpcd[1999]: eth2: IAID 3c:b3:b2:f6
Wed Mar 13 22:51:32 2024 daemon.info dhcpcd[1999]: eth2: adding address fe80::516e:13c2:d2d0:ddda
Wed Mar 13 22:51:32 2024 daemon.err odhcp6c[3213]: Failed to send RS (Address not available)
Wed Mar 13 22:51:32 2024 daemon.notice netifd: wan (3224): udhcpc: started, v1.36.1
Wed Mar 13 22:51:32 2024 daemon.info dhcpcd[1999]: eth2: soliciting an IPv6 router
Wed Mar 13 22:51:32 2024 daemon.notice netifd: wan (3224): udhcpc: broadcasting discover
Wed Mar 13 22:51:32 2024 daemon.notice hostapd: Set new config for phy phy0:
Wed Mar 13 22:51:32 2024 daemon.notice hostapd: Set new config for phy phy1:
Wed Mar 13 22:51:32 2024 daemon.notice wpa_supplicant[1782]: Set new config for phy phy0
Wed Mar 13 22:51:32 2024 daemon.notice wpa_supplicant[1782]: Set new config for phy phy1
Wed Mar 13 22:51:33 2024 kern.debug kernel: [ 14.512451] mt7530-mmio 15020000.switch lan2: phy link up internal/100Mbps/Full/none/rx/tx
Wed Mar 13 22:51:33 2024 kern.info kernel: [ 14.512908] mt7530-mmio 15020000.switch lan2: Link is Up - 100Mbps/Full - flow control rx/tx
Wed Mar 13 22:51:33 2024 kern.info kernel: [ 14.529591] br-lan: port 3(lan2) entered blocking state
Wed Mar 13 22:51:33 2024 kern.info kernel: [ 14.534823] br-lan: port 3(lan2) entered forwarding state
Wed Mar 13 22:51:33 2024 daemon.notice netifd: Network device 'lan2' link is up
Wed Mar 13 22:51:33 2024 daemon.info dhcpcd[1999]: lan2: carrier acquired
Wed Mar 13 22:51:33 2024 daemon.info dhcpcd[1999]: lan2: IAID cf:43:52:7e
Wed Mar 13 22:51:33 2024 daemon.err dhcpcd[1999]: lan2: IAID conflicts with one assigned to eth0
Wed Mar 13 22:51:33 2024 daemon.notice wpa_supplicant[1782]: Set new config for phy phy0
Wed Mar 13 22:51:33 2024 daemon.notice wpa_supplicant[1782]: Set new config for phy phy1
Wed Mar 13 22:51:33 2024 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Wed Mar 13 22:51:33 2024 daemon.notice hostapd: Restart interface for phy phy0
Wed Mar 13 22:51:33 2024 daemon.info dhcpcd[1999]: eth2: soliciting a DHCP lease
Wed Mar 13 22:51:33 2024 daemon.err odhcp6c[3213]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Wed Mar 13 22:51:33 2024 daemon.notice hostapd: Set new config for phy phy1: /var/run/hostapd-phy1.conf
Wed Mar 13 22:51:33 2024 daemon.notice hostapd: Restart interface for phy phy1
Wed Mar 13 22:51:33 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=CH ieee80211d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100 chanlist=1 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1] channel=1 interface=phy0-ap0 bssid=00:c0:ca:b0:85:45 ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=ganzgeheim1A! wpa_psk_file=/var/run/hostapd-phy0-ap0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=oli bridge=br-lan wds_bridge= snoop_iface=br-lan wpa_disable_eapol_key_retries=0 wpa_key_mgmt=WPA-PSK okc=0 disable_pmksa_caching=1 dynamic_vlan=0 vlan_naming=1 vlan_no_bridge=1 vlan_file=/var/run/hostapd-phy0-ap0.vlan qos_map
Wed Mar 13 22:51:34 2024 daemon.warn odhcpd[2053]: No default route present, overriding ra_lifetime!
Wed Mar 13 22:51:34 2024 daemon.err odhcp6c[3213]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Wed Mar 13 22:51:34 2024 kern.debug kernel: [ 15.981501] mt7530-mmio 15020000.switch wan: phy link up internal/1Gbps/Full/none/rx/tx
Wed Mar 13 22:51:34 2024 kern.info kernel: [ 15.982175] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
Wed Mar 13 22:51:36 2024 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Wed Mar 13 22:51:36 2024 user.info adblock-4.1.5[1938]: download of 'adguard' failed, url: https://adguardteam.github.io/AdGuardSDNSFilter/Filters/filter.txt, rule: BEGIN{FS="[/|^|\r]"}/^\|\|([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+[\/\^\r]+$/{print tolower($3)}, categories: -, rc: 4, log: Downloading 'https://adguardteam.github.io/AdGuardSDNSFilter/Filters/filter.txt' Failed to send request: Operation not permitted
Wed Mar 13 22:51:36 2024 user.info adblock-4.1.5[1938]: download of 'easylist' failed, url: https://easylist-downloads.adblockplus.org/easylist.txt, rule: BEGIN{FS="[|^]"}/^\|\|([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+\^(\$third-party)?$/{print tolower($3)}, categories: -, rc: 4, log: Downloading 'https://easylist-downloads.adblockplus.org/easylist.txt' Failed to send request: Operation not permitted
Wed Mar 13 22:51:36 2024 user.info adblock-4.1.5[1938]: download of 'disconnect' failed, url: https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt, rule: /^([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+([[:space:]]|$)/{print tolower($1)}, categories: -, rc: 4, log: Downloading 'https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt' Failed to send request: Operation not permitted
Wed Mar 13 22:51:36 2024 user.info adblock-4.1.5[1938]: download of 'adaway' failed, url: https://raw.githubusercontent.com/AdAway/adaway.github.io/master/hosts.txt, rule: /^127\.0\.0\.1[[:space:]]+([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+([[:space:]]|$)/{print tolower($2)}, categories: -, rc: 4, log: Downloading 'https://raw.githubusercontent.com/AdAway/adaway.github.io/master/hosts.txt' Failed to send request: Operation not permitted
Wed Mar 13 22:51:36 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: easyprivacy, mode: restore, cnt: 0, in_rc: 4, out_rc: 4
Wed Mar 13 22:51:36 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: yoyo, mode: restore, cnt: 0, in_rc: 4, out_rc: 4
Wed Mar 13 22:51:36 2024 daemon.err odhcp6c[3213]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Wed Mar 13 22:51:36 2024 daemon.err odhcp6c[3213]: Failed to send RS (Address not available)
Wed Mar 13 22:51:40 2024 daemon.err odhcp6c[3213]: Failed to send RS (Address not available)
Wed Mar 13 22:51:40 2024 daemon.err odhcp6c[3213]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Wed Mar 13 22:51:41 2024 user.info adblock-4.1.5[1938]: download of 'easyprivacy' failed, url: https://easylist-downloads.adblockplus.org/easyprivacy.txt, rule: BEGIN{FS="[|^]"}/^\|\|([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+\^(\$third-party)?$/{print tolower($3)}, categories: -, rc: 4, log: Downloading 'https://easylist-downloads.adblockplus.org/easyprivacy.txt' Failed to send request: Operation not permitted
Wed Mar 13 22:51:41 2024 user.info adblock-4.1.5[1938]: download of 'yoyo' failed, url: https://pgl.yoyo.org/adservers/serverlist.php?hostformat=nohtml&showintro=0&mimetype=plaintext, rule: /^([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+([[:space:]]|$)/{print tolower($1)}, categories: -, rc: 4, log: Downloading 'https://pgl.yoyo.org/adservers/serverlist.php?hostformat=nohtml&showintro=0&mimetype=plaintext' Failed to send request: Operation not permitted
Wed Mar 13 22:51:41 2024 user.debug adblock-4.1.5[1938]: f_list ::: name: -, mode: merge, cnt: 0, in_rc: 4, out_rc: 0
Wed Mar 13 22:51:44 2024 daemon.err odhcp6c[3213]: Failed to send RS (Address not available)
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.330354] br-lan: port 6(phy0-ap0) entered blocking state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.335930] br-lan: port 6(phy0-ap0) entered disabled state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.341645] device phy0-ap0 entered promiscuous mode
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.346681] br-lan: port 6(phy0-ap0) entered blocking state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.352264] br-lan: port 6(phy0-ap0) entered forwarding state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.358137] br-lan: port 5(wan) entered blocking state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.363269] br-lan: port 5(wan) entered forwarding state
Wed Mar 13 22:51:46 2024 daemon.notice hostapd: phy0-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.368691] br-lan: port 6(phy0-ap0) entered disabled state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.376562] device phy0-ap0 left promiscuous mode
Wed Mar 13 22:51:46 2024 daemon.info dhcpcd[1999]: phy0-ap0: connected to Access Point:
Wed Mar 13 22:51:46 2024 daemon.info dhcpcd[1999]: phy0-ap0: IAID ca:b0:85:45
Wed Mar 13 22:51:46 2024 daemon.info dhcpcd[1999]: phy0-ap0: adding address fe80::4b47:a965:23dc:d4cb
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.381379] br-lan: port 6(phy0-ap0) entered disabled state
Wed Mar 13 22:51:46 2024 daemon.warn odhcpd[2053]: No default route present, overriding ra_lifetime!
Wed Mar 13 22:51:46 2024 daemon.notice netifd: Wireless device 'radio0' is now up
Wed Mar 13 22:51:46 2024 daemon.notice netifd: wan (3224): udhcpc: broadcasting discover
Wed Mar 13 22:51:46 2024 daemon.notice netifd: wan (3224): udhcpc: broadcasting select for xx.195.252.69, server 77.109.180.81
Wed Mar 13 22:51:46 2024 daemon.notice netifd: wan (3224): udhcpc: lease of xx.195.252.69 obtained from 77.109.180.81, lease time 4000
Wed Mar 13 22:51:46 2024 daemon.info dhcpcd[1999]: eth0: soliciting a DHCP lease
Wed Mar 13 22:51:46 2024 daemon.notice netifd: Interface 'wan' is now up
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.450176] br-lan: port 6(phy0-ap0) entered blocking state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.455761] br-lan: port 6(phy0-ap0) entered disabled state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.461586] device phy0-ap0 entered promiscuous mode
Wed Mar 13 22:51:46 2024 daemon.notice netifd: Network device 'wan' link is up
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.471219] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap0: link becomes ready
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.477936] br-lan: port 6(phy0-ap0) entered blocking state
Wed Mar 13 22:51:46 2024 kern.info kernel: [ 28.483512] br-lan: port 6(phy0-ap0) entered forwarding state
Wed Mar 13 22:51:46 2024 daemon.notice netifd: Network device 'phy0-ap0' link is up
Wed Mar 13 22:51:47 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth2)
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: lan2: soliciting an IPv6 router
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: lan2: soliciting a DHCP lease
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: phy0-ap0: interface state COUNTRY_UPDATE->ENABLED
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: phy0-ap0: AP-ENABLED
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=CH ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 chanlist=36 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1] ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=42 vht_capab=[RXLDPC][SHORT-GI-80][TX-STBC-2BY1][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][MAX-A-MPDU-LEN-EXP7] channel=36 interface=phy1-ap0 bssid=82:c0:ca:b0:85:45 ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=ganzgeheim1A! wpa_psk_file=/var/run/hostapd-phy1-ap0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=oli5 bridge=br-lan wds_bridge= snoop_iface=br-lan wpa_disable_eap
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: eth2: probing for an IPv4LL address
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: eth2: offered xx.195.252.6 from 77.109.180.81
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: carrier lost
Wed Mar 13 22:51:47 2024 user.notice unbound: default protocol configuration
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: deleting address fe80::4b47:a965:23dc:d4cb
Wed Mar 13 22:51:47 2024 user.notice unbound: default memory configuration
Wed Mar 13 22:51:47 2024 kern.info kernel: [ 28.635492] br-lan: port 7(phy1-ap0) entered blocking state
Wed Mar 13 22:51:47 2024 kern.info kernel: [ 28.641095] br-lan: port 7(phy1-ap0) entered disabled state
Wed Mar 13 22:51:47 2024 kern.info kernel: [ 28.647290] device phy1-ap0 entered promiscuous mode
Wed Mar 13 22:51:47 2024 kern.info kernel: [ 28.652435] br-lan: port 7(phy1-ap0) entered blocking state
Wed Mar 13 22:51:47 2024 kern.info kernel: [ 28.658018] br-lan: port 7(phy1-ap0) entered forwarding state
Wed Mar 13 22:51:47 2024 daemon.warn dhcpcd[1999]: eth2: ignoring offer of xx.195.252.69 from 77.109.180.81
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: phy1-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: phy1-ap0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Mar 13 22:51:47 2024 daemon.notice netifd: Wireless device 'radio1' is now up
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: eth2: probing address xx.195.252.6/24
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: carrier acquired
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: IAID ca:b0:85:45
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: adding address fe80::4b47:a965:23dc:d4cb
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: wan: carrier acquired
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: wan: IAID cf:43:52:7e
Wed Mar 13 22:51:47 2024 daemon.err dhcpcd[1999]: wan: IAID conflicts with one assigned to eth0
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: removing interface
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: connected to Access Point:
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy1-ap0: connected to Access Point:
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy1-ap0: IAID ca:b0:85:45
Wed Mar 13 22:51:47 2024 daemon.err dhcpcd[1999]: phy1-ap0: IAID conflicts with one assigned to phy0-ap0
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy1-ap0: adding address fe80::f1f4:99c5:4d1c:6f99
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy1-ap0: carrier lost
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy1-ap0: deleting address fe80::f1f4:99c5:4d1c:6f99
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy1-ap0: carrier acquired
Wed Mar 13 22:51:47 2024 user.notice unbound: default recursion configuration
Wed Mar 13 22:51:47 2024 daemon.notice netifd: Network device 'phy1-ap0' link is up
Wed Mar 13 22:51:47 2024 kern.info kernel: [ 29.055192] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap0: link becomes ready
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: phy1-ap0: interface state HT_SCAN->ENABLED
Wed Mar 13 22:51:47 2024 daemon.notice hostapd: phy1-ap0: AP-ENABLED
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: wan: soliciting an IPv6 router
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: phy0-ap0: soliciting an IPv6 router
Wed Mar 13 22:51:47 2024 daemon.warn odhcpd[2053]: No default route present, overriding ra_lifetime!
Wed Mar 13 22:51:47 2024 daemon.info dhcpcd[1999]: wan: soliciting a DHCP lease
Wed Mar 13 22:51:48 2024 daemon.info dhcpcd[1999]: phy1-ap0: soliciting an IPv6 router
Wed Mar 13 22:51:48 2024 daemon.info dhcpcd[1999]: phy0-ap0: soliciting a DHCP lease
Wed Mar 13 22:51:49 2024 daemon.info hostapd: phy0-ap0: STA 00:06:78:c7:a0:a7 IEEE 802.11: authenticated
Wed Mar 13 22:51:49 2024 daemon.info hostapd: phy0-ap0: STA 00:06:78:c7:a0:a7 IEEE 802.11: associated (aid 1)
Wed Mar 13 22:51:49 2024 daemon.info dhcpcd[1999]: phy1-ap0: soliciting a DHCP lease
Wed Mar 13 22:51:49 2024 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 00:06:78:c7:a0:a7 auth_alg=open
Wed Mar 13 22:51:49 2024 daemon.info hostapd: phy0-ap0: STA 00:06:78:c7:a0:a7 WPA: pairwise key handshake completed (RSN)
Wed Mar 13 22:51:49 2024 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 00:06:78:c7:a0:a7
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: started, version 2.90 cachesize 1000
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack no-ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Wed Mar 13 22:51:49 2024 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 2 names
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 2 names
Wed Mar 13 22:51:49 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Wed Mar 13 22:51:51 2024 daemon.info dhcpcd[1999]: eth2: leased xx.195.252.6 for 4000 seconds
Wed Mar 13 22:51:51 2024 daemon.info dhcpcd[1999]: eth2: adding route to xx.195.252.0/24
Wed Mar 13 22:51:51 2024 daemon.info dhcpcd[1999]: eth2: adding default route via xx.195.252.1
Wed Mar 13 22:51:52 2024 daemon.info dhcpcd[1999]: eth0: probing for an IPv4LL address
Wed Mar 13 22:51:52 2024 daemon.info dhcpcd[1999]: lan2: probing for an IPv4LL address
Wed Mar 13 22:51:52 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 available DHCP range: 192.168.1.100 -- 192.168.1.249
Wed Mar 13 22:51:52 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 vendor class: yealink
Wed Mar 13 22:51:52 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 client provides name: W52P
Wed Mar 13 22:51:52 2024 daemon.info dhcpcd[1999]: wan: probing for an IPv4LL address
Wed Mar 13 22:51:53 2024 daemon.info dhcpcd[1999]: phy0-ap0: probing for an IPv4LL address
Wed Mar 13 22:51:54 2024 daemon.info dhcpcd[1999]: phy1-ap0: probing for an IPv4LL address
Wed Mar 13 22:51:55 2024 daemon.info dhcpcd[1999]: eth2: Router Advertisement from fe80::200:f7ff:fef7:256
Wed Mar 13 22:51:55 2024 daemon.info dhcpcd[1999]: eth2: adding address 2a02:168:2000:22:e983:46a:beb7:ca9a/64
Wed Mar 13 22:51:55 2024 daemon.info dhcpcd[1999]: eth2: adding route to 2a02:168:2000:22::/64
Wed Mar 13 22:51:55 2024 daemon.info dhcpcd[1999]: eth2: adding default route via fe80::200:f7ff:fef7:256
Wed Mar 13 22:51:55 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Wed Mar 13 22:51:55 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 DHCPDISCOVER(br-lan) 00:15:65:ac:82:fc
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 tags: lan, cpewan-id, br-lan
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 DHCPOFFER(br-lan) 192.168.1.146 00:15:65:ac:82:fc
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 1:netmask, 2:time-offset, 3:router, 4, 6:dns-server,
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 7:log-server, 12:hostname, 15:domain-name,
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 28:broadcast, 42:ntp-server, 66:tftp-server,
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 67:bootfile-name, 43:vendor-encap, 132, 133
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 next server: 192.168.1.1
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 1 option: 53 message-type 2
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 54 server-identifier 192.168.1.1
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 51 lease-time 12h
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 58 T1 6h
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 59 T2 10h30m
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 1 netmask 255.255.255.0
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 28 broadcast 192.168.1.255
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 3 router 192.168.1.1
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 6 dns-server 192.168.1.1
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 3 option: 15 domain-name lan
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 available DHCP range: 192.168.1.100 -- 192.168.1.249
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 vendor class: udhcp 1.29.3
Wed Mar 13 22:51:55 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 client provides name: Marantz-CINEMA-50
Wed Mar 13 22:51:56 2024 daemon.info dhcpcd[1999]: eth0: using IPv4LL address 169.254.231.8
Wed Mar 13 22:51:56 2024 daemon.info dhcpcd[1999]: eth0: adding route to 169.254.0.0/16
Wed Mar 13 22:51:56 2024 daemon.warn odhcpd[2053]: A default route is present but there is no public prefix on lan thus we don't announce a default route by overriding ra_lifetime!
Wed Mar 13 22:51:57 2024 daemon.info dhcpcd[1999]: lan2: using IPv4LL address 169.254.231.8
Wed Mar 13 22:51:57 2024 daemon.info dhcpcd[1999]: lan2: adding route to 169.254.0.0/16
Wed Mar 13 22:51:57 2024 daemon.info dhcpcd[1999]: phy0-ap0: using IPv4LL address 169.254.55.90
Wed Mar 13 22:51:57 2024 daemon.info dhcpcd[1999]: phy0-ap0: adding route to 169.254.0.0/16
Wed Mar 13 22:51:58 2024 daemon.info dhcpcd[1999]: wan: using IPv4LL address 169.254.231.8
Wed Mar 13 22:51:58 2024 daemon.info dhcpcd[1999]: wan: adding route to 169.254.0.0/16
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 DHCPDISCOVER(br-lan) 00:06:78:c7:a0:a7
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 tags: lan, br-lan
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 DHCPOFFER(br-lan) 192.168.1.158 00:06:78:c7:a0:a7
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 requested options: 1:netmask, 3:router, 6:dns-server, 12:hostname,
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 requested options: 15:domain-name, 28:broadcast, 42:ntp-server
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 next server: 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 1 option: 53 message-type 2
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 54 server-identifier 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 51 lease-time 12h
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 58 T1 6h
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 59 T2 10h30m
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 1 netmask 255.255.255.0
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 28 broadcast 192.168.1.255
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 3 router 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 4 option: 6 dns-server 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 3 option: 15 domain-name lan
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 available DHCP range: 192.168.1.100 -- 192.168.1.249
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 vendor class: yealink
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 client provides name: W52P
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 DHCPREQUEST(br-lan) 192.168.1.146 00:15:65:ac:82:fc
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 tags: lan, cpewan-id, br-lan
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 DHCPACK(br-lan) 192.168.1.146 00:15:65:ac:82:fc W52P
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 1:netmask, 2:time-offset, 3:router, 4, 6:dns-server,
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 7:log-server, 12:hostname, 15:domain-name,
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 28:broadcast, 42:ntp-server, 66:tftp-server,
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 requested options: 67:bootfile-name, 43:vendor-encap, 132, 133
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 next server: 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 1 option: 53 message-type 5
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 54 server-identifier 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 51 lease-time 12h
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 58 T1 6h
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 59 T2 10h30m
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 1 netmask 255.255.255.0
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 28 broadcast 192.168.1.255
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 3 router 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 6 dns-server 192.168.1.1
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 3 option: 15 domain-name lan
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 sent size: 4 option: 12 hostname W52P
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 available DHCP range: 192.168.1.100 -- 192.168.1.249
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 vendor class: udhcp 1.29.3
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 client provides name: Marantz-CINEMA-50
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 DHCPREQUEST(br-lan) 192.168.1.158 00:06:78:c7:a0:a7
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 DHCPACK(br-lan) 192.168.1.158 00:06:78:c7:a0:a7 Marantz-CINEMA-50
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 1 option: 53 message-type 5
Wed Mar 13 22:51:58 2024 daemon.info dnsmasq-dhcp[1]: 1904663902 sent size: 17 option: 12 hostname Marantz-CINEMA-50
Wed Mar 13 22:51:59 2024 daemon.warn dhcpcd[1999]: eth0: no IPv6 Routers available
Wed Mar 13 22:51:59 2024 daemon.info dhcpcd[1999]: phy1-ap0: using IPv4LL address 169.254.55.90
Wed Mar 13 22:51:59 2024 daemon.info dhcpcd[1999]: phy1-ap0: adding route to 169.254.0.0/16
Wed Mar 13 22:52:01 2024 daemon.warn dhcpcd[1999]: phy1-ap0: no IPv6 Routers available
Wed Mar 13 22:52:01 2024 daemon.warn dhcpcd[1999]: phy0-ap0: no IPv6 Routers available
Wed Mar 13 22:52:01 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 available DHCP range: 192.168.1.100 -- 192.168.1.249
Wed Mar 13 22:52:01 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 vendor class: yealink
Wed Mar 13 22:52:01 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 client provides name: W52P
Wed Mar 13 22:52:01 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 DHCPINFORM(br-lan) 0.0.0.0 00:15:65:ac:82:fc
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using nameserver 213.144.129.20#53
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using nameserver 77.109.128.2#53
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Thu Mar 14 11:18:40 2024 daemon.notice netifd: Interface 'wan6' is now up
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using nameserver 2001:1620:2777:1::10#53
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq[1]: using nameserver 2001:1620:2777:2::20#53
Thu Mar 14 11:18:40 2024 user.notice firewall: Reloading firewall due to ifup of wan6 (eth2)
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 available DHCP range: 192.168.1.100 -- 192.168.1.249
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 vendor class: yealink
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 client provides name: W52P
Thu Mar 14 11:18:40 2024 daemon.info dnsmasq-dhcp[1]: 2348803950 DHCPINFORM(br-lan) 0.0.0.0 00:15:65:ac:82:fc
Thu Mar 14 11:18:41 2024 daemon.warn odhcpd[2053]: A default route is present but there is no public prefix on lan thus we don't announce a default route by overriding ra_lifetime!
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 available DHCP range: 192.168.1.100 -- 192.168.1.249
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 client provides name: DESKTOP-RA0V02P
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 DHCPREQUEST(br-lan) 192.168.1.225 9c:6b:00:2d:c6:af
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 tags: lan, br-lan
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 DHCPACK(br-lan) 192.168.1.225 9c:6b:00:2d:c6:af DESKTOP-RA0V02P
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 requested options: 1:netmask, 2:time-offset, 6:dns-server, 12:hostname,
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 requested options: 15:domain-name, 26:mtu, 28:broadcast, 121:classless-static-route,
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 requested options: 3:router, 33:static-route, 40:nis-domain,
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 requested options: 41:nis-server, 42:ntp-server, 119:domain-search,
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 requested options: 249, 252, 17:root-path
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 next server: 192.168.1.1
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 1 option: 53 message-type 5
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 54 server-identifier 192.168.1.1
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 51 lease-time 12h
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 58 T1 6h
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 59 T2 10h30m
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 1 netmask 255.255.255.0
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 28 broadcast 192.168.1.255
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 3 router 192.168.1.1
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 4 option: 6 dns-server 192.168.1.1
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 3 option: 15 domain-name lan
Thu Mar 14 11:18:42 2024 daemon.info dnsmasq-dhcp[1]: 1166211992 sent size: 15 option: 12 hostname DESKTOP-RA0V02P
Thu Mar 14 11:18:43 2024 daemon.warn odhcpd[2053]: A default route is present but there is no public prefix on lan thus we don't announce a default route by overriding ra_lifetime!
Thu Mar 14 11:18:44 2024 authpriv.info dropbear[4431]: Child connection from 192.168.1.225:33028
Thu Mar 14 11:18:46 2024 authpriv.notice dropbear[4431]: Password auth succeeded for 'root' from 192.168.1.225:33028
Thu Mar 14 11:18:49 2024 user.debug adblock-4.1.5[1938]: f_dnsup ::: dns: dnsmasq, cache_cmd: -, lookup_cmd: /usr/bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_flush: 0, dns_timeout: 20, dns_cnt: 3, in_rc: 0, out_rc: 0
Thu Mar 14 11:18:49 2024 user.debug adblock-4.1.5[1938]: f_jsnup ::: status: enabled, cnt: 0, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Thu Mar 14 11:18:49 2024 user.info adblock-4.1.5[1938]: blocklist with overall 0 blocked domains loaded successfully (Bananapi BPI-R4, OpenWrt SNAPSHOT r25540-7b89388674)
Thu Mar 14 11:18:49 2024 user.debug adblock-4.1.5[1938]: f_rmtemp ::: tmp_dir: /tmp/tmp.nMBNkc, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Thu Mar 14 11:18:50 2024 daemon.notice netifd: Interface 'wan6' has lost the connection
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using nameserver 213.144.129.20#53
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using nameserver 77.109.128.2#53
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Thu Mar 14 11:18:50 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:18:50 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:18:50 2024 daemon.info dhcpcd[1999]: eth2: pid 1789 deleted route to 2a02:168:2000:22::/64
Thu Mar 14 11:18:50 2024 daemon.info dhcpcd[1999]: eth2: pid 1789 deleted default route via fe80::200:f7ff:fef7:256
Thu Mar 14 11:18:50 2024 daemon.notice netifd: Interface 'wan6' is now up
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using nameserver 2001:1620:2777:1::10#53
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: using nameserver 2001:1620:2777:2::20#53
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 2 names
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 4 names
Thu Mar 14 11:18:50 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Thu Mar 14 11:18:50 2024 user.notice firewall: Reloading firewall due to ifup of wan6 (eth2)
Thu Mar 14 11:18:54 2024 daemon.info procd: Instance unbound::unbound s in a crash loop 6 crashes, 0 seconds since last crash
Thu Mar 14 11:18:58 2024 daemon.info dhcpcd[1999]: eth2: adding route to 2a02:168:2000:22::/64
Thu Mar 14 11:18:58 2024 daemon.info dhcpcd[1999]: eth2: adding default route via fe80::200:f7ff:fef7:256
Thu Mar 14 11:18:58 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:18:58 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:19:06 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:19:06 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:19:14 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:19:14 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:19:40 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:19:40 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:19:49 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:19:49 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:19:59 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:19:59 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:20:03 2024 daemon.info hostapd: phy1-ap0: STA c0:ee:fb:e2:ec:08 IEEE 802.11: authenticated
Thu Mar 14 11:20:03 2024 daemon.info hostapd: phy1-ap0: STA c0:ee:fb:e2:ec:08 IEEE 802.11: associated (aid 1)
Thu Mar 14 11:20:04 2024 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED c0:ee:fb:e2:ec:08 auth_alg=open
Thu Mar 14 11:20:04 2024 daemon.info hostapd: phy1-ap0: STA c0:ee:fb:e2:ec:08 WPA: pairwise key handshake completed (RSN)
Thu Mar 14 11:20:04 2024 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED c0:ee:fb:e2:ec:08
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 available DHCP range: 192.168.1.100 -- 192.168.1.249
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 vendor class: android-dhcp-11
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 client provides name: ONEPLUS-A3003
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 DHCPREQUEST(br-lan) 192.168.1.135 c0:ee:fb:e2:ec:08
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 tags: lan, br-lan
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 DHCPACK(br-lan) 192.168.1.135 c0:ee:fb:e2:ec:08 ONEPLUS-A3003
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 requested options: 1:netmask, 3:router, 6:dns-server, 15:domain-name,
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 requested options: 26:mtu, 28:broadcast, 51:lease-time, 58:T1,
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 requested options: 59:T2, 43:vendor-encap, 114
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 next server: 192.168.1.1
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 1 option: 53 message-type 5
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 54 server-identifier 192.168.1.1
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 51 lease-time 12h
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 58 T1 6h
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 59 T2 10h30m
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 1 netmask 255.255.255.0
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 28 broadcast 192.168.1.255
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 3 router 192.168.1.1
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 4 option: 6 dns-server 192.168.1.1
Thu Mar 14 11:20:04 2024 daemon.info dnsmasq-dhcp[1]: 1991518596 sent size: 3 option: 15 domain-name lan
Thu Mar 14 11:20:09 2024 daemon.info procd: Instance unbound::unbound s in a crash loop 6 crashes, 0 seconds since last crash
Thu Mar 14 11:20:34 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:20:34 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
Thu Mar 14 11:20:44 2024 daemon.err dhcpcd[1999]: dhcp6_openudp: Address in use
Thu Mar 14 11:20:44 2024 daemon.err dhcpcd[1999]: dhcp6_start1: Address in use
its the “wan” device that is used to connect to my workstation
It is enabled…thats what i meant…to be honest i do not know how to interpret it correctly. Looks like advertising (imho whats sent to the other side) is completely empty (and mode looks also wrong,but maybe at this stage ok).
I have the problem too, does anybody found something.
The workaround off disable and reenable auto negotiation seems to work
@frank-w I have found that the bug appear when I have a device that support only 100Mbit/s
When it is connected I have a performance problem when not connected there is no problem
Thought that this bug was already fixed in openwrt/mainline.
@dangowrt am i wrong here?
Have no 100mbit devices to test
Adjust the advertisement on either side to make it connect with 100Mbps…
my problem that i reported is fixed:
100mbit voip phone:
root@OpenWrt:~# ethtool lan2
Settings for lan2:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 2
Transceiver: external
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
my rpi5 (htpc) on lan1:
Settings for lan1:
1000baseT/Full
1000baseT/Full
1000baseT/Half 1000baseT/Full
Link partner advertised pause frame use: Transmit-only
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
dangowrt mentioned that some link partners might have problems, but i assume its something different then what i reported because i had problems on client side. guillo seems to have problems on all lan ports after using that 100mbit device?
Yes when a 100Mbits device is connected all the ports are limit to 100Mbits in upload (device to router)
@frank-w i’m on the latest snapshot
That would be bad and should probably be considered a bug. If you have one 100 Mbit device plugged into the switch, you’d normally expect other devices to still run a 1Gbit if they are capable.
who all have this issue can you please show ethtool like @oli did for the port having a 1G client while having 100M client on another port? just to nail this a bit down (advertisement issue should be fixed, but maybe it is another one)
@oli can you do 1G bidirectional traffic to the rpi5?
i dont know how, the rpi5 is running libreelec and i have no idea if they have an iper3 package. any idea how to verify that?
You can use also another device,just to make sure you can have ~940mbit/s bidirectional while havin the 100m device connected
