You either seem to lack kmod-phy-realtek package or the SFP doesn’t expose the PHY.
I’m using TP-LINK TL-SM410U, ONTi ONT-C2GE-R10 and some other TP-LINK and ONTi modules. I had the same problem with Openwrt going from kernel 6.1 to 6.6 on R3. Everything was working fine before, but after the update:
[ 15.141286] sfp sfp-2: module rev 1.0 sn 2208180027 dc 220818
[ 15.150776] mt7530-mdio mdio-bus:1f sfp2: unsupported SFP module: no common interface modes
[ 15.206232] sfp sfp-1: module TP-LINK TL-SM410U rev 2.0 sn 12260M4000737 dc 220621
[ 15.208117] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 15.215705] mtk_soc_eth 15100000.ethernet eth1: unsupported SFP module: no common interface modes
Then I did a sfp-bus.c diff from kernel 6.9.1 and put the patch in target/linux/mediatek/patches-6.6
--- a/drivers/net/phy/sfp-bus.c
+++ b/drivers/net/phy/sfp-bus.c
@@ -151,10 +151,6 @@
unsigned int br_min, br_nom, br_max;
__ETHTOOL_DECLARE_LINK_MODE_MASK(modes) = { 0, };
- phylink_set(modes, Autoneg);
- phylink_set(modes, Pause);
- phylink_set(modes, Asym_Pause);
/* Decode the bitrate information to MBd */
br_min = br_nom = br_max = 0;
if (id->base.br_nominal) {
@@ -328,7 +324,7 @@
* modules use 2500Mbaud rather than 3100 or 3200Mbaud for
* 2500BASE-X, so we allow some slack here.
- if (bitmap_empty(modes, __ETHTOOL_LINK_MODE_MASK_NBITS) && br_nom) {
+ if (linkmode_empty(modes) && br_nom) {
if (br_min <= 1300 && br_max >= 1200) {
phylink_set(modes, 1000baseX_Full);
__set_bit(PHY_INTERFACE_MODE_1000BASEX, interfaces);
@@ -339,6 +335,10 @@
+ phylink_set(modes, Autoneg);
+ phylink_set(modes, Pause);
+ phylink_set(modes, Asym_Pause);
if (bus->sfp_quirk && bus->sfp_quirk->modes)
bus->sfp_quirk->modes(id, modes, interfaces);
And It seems to be working fine again
[ 15.391245] sfp sfp-2: module rev 1.0 sn 2208180027 dc 220818
[ 15.442338] sfp sfp-1: module TP-LINK TL-SM410U rev 2.0 sn 12260M4000737 dc 220621
[ 15.452578] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 15.643208] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
Sorry if it is a noob-question…
I am using trunk OpenWrt (version 6.6.30) and have a GPON-ONU-34-20BI module. The module is detected at boot and link is also detected.
[ 58.082859] sfp sfp2: module FS GPON-ONU-34-20BI rev 01 sn G2410075131 dc 240301
Settings for eth1:
Supported ports: [ FIBRE ]
1000baseX/Full
Speed: 2500Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Link detected: yes
However the speed is 2500Mb and I have to change it to 1000Mb (ethtool speed) does not work so I have to log into the module. The IP address according to HackGPON is 192.168.1.10, but I cannot connect to it. Am I missing something…?
Ok, found the solution… that works.
Now I am trying to set the speed to 1000.
fw_setenv sgmii_mode 4
After reading the sgmii mode, link_status (onu lanpsg 0) is still unchanged (5). Or do I need to unlock the bootloader?
Hello @wvdakker
I have the same sfp receiver, and my R4 détective it in dmesg.
However the link is not detected in ethtool since I haven’t Connect the fiber in it since I have to configure the ont before.
But I’m not able to connect to 192.168.1.10 how did you do it please ?
Hi, Be sure your bpi has ip 192.168.1.1
then
ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 -oHostKeyAlgorithms=+ssh-dss [email protected]
And you are in. (note: after filling in your password) https://hack-gpon.org/ont-fs-com-gpon-onu-stick-with-mac/
I noticed you have to have a link before you can log in.
My BPI has the ip 192.168.1.1
I have connect the ONT on sfp lan and it is detected
Thu May 30 09:49:46 2024 kern.info kernel: [ 105.202018] sfp sfp2: module FS GPON-ONU-34-20BI rev 01 sn G2410318799 dc 240327
Thu May 30 09:49:46 2024 kern.info kernel: [ 105.211440] mtk_soc_eth 15100000.ethernet eth1: switched to inband/2500base-x link mode
With ethtool I can see it has negotiated the speed
root@OpenWrt:~# ethtool eth1
Settings for eth1:
1000baseX/Full
Speed: 2500Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Auto-negotiation: on
Link detected: no
But I cannot ping nor ssh from the BPI or a device connected on LAN.
I have to connect the fiber even if I haven’t configure anything on ONT if I understand ?
Most ont need link up to access their webinterface/internal ip
I noticed I only can ping/ssh the sfp if there is a link. If I remove the link I cannot access the sfp. Inserting, then I can.
There is somewhere on this forum a discussion to modify the source so you can also access it without a link. I think it was in the BPIR3-SFP forum.
You use an devicetree-overlay to change the los-gpio so that you can simulate a link-up without having fibre connected.
it looks like @dangowrt did a nice job with openwrt’s commits for the past few days … the sfp module works without any hacks and right from the start. Thank you @dangowrt !
Yes I confirm that after the fiber is in the ONT the link is detected and that works perfectly. My R4 is now my router instead of the ISP one, thank you !
Ok found my problem. The ISP doesnt use GPON but AON. Therefor the TX didnt match and not came up. Switching to FS fiber module SFP-GE-BX (be sure to install the right one) works out of the box and the link came up directly.
Settings for eth1:
Supported link modes: 1000baseX/Full
Advertised link modes: 1000baseX/Full
Link partner advertised link modes: 1000baseX/Full
Link partner advertised pause frame use: No
Speed: 1000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Cannot get wake-on-lan settings: Operation not permitted
Link detected: yes
This module can be added to the ones which work with the bpi-r4 SFP filber module
This one?
No that is the older one I used.
This one works for my ISP:
sfp sfp1: module FS SFP-GE-BX rev A0 sn F2130219083 dc 220922
I have this one and it works with the R4 btw
THANK YOU for writing about AON fiber networks! As I remember you are the first one who wrote about it.
In the next months I also get a new AON FFTH activated. It’s a new installed Network → AON lives …
I also decided for the SFP-GE-BX.
My problem:
FS delivers by default LC PC or UPC.
But after calling Service, they deliver a LC APC to me.
The behavoiur “work out of the box” looks normal for AON and was also described in the commends of the SFP modul.
Got 2 of them in my BPI-R4. One to the ISP and one uplink to the internal switch. Works ok.
I have LEOX LXT-010S-H and BPP-R4 and I have the same problem as bqbq had: the led is blinking when inserting/removing the module. There are no logs in dmesg, I have checked both leox (on a mikrotik router) and Banana PI (with other SFP+ device) and they are working there so its not a hardware issue. It seems to be the same problem as Vasya described. Did anyone managed to get it to work?
What is the problem? Just use a patch cable from UPC to APC?
