i dont know, can i test that? i did not activate it, afaik.
do not know all ways openwrt do this stuff…maybe you can look on “nft list ruleset” and look if there is a flowtable with offload-flag
root@OpenWrt:~# nft list ruleset| grep offload
prints nothing
does it print anything when leaving the grep? you use the vendors openwrt based on sdk, right?
i created my own image from the dangowrt branch. i deleted my old .config and let make menuconfig create everything.
when i leave the grep there is a lot printed, yes.
table inet fw4 {
chain input {
type filter hook input priority filter; policy drop;
iif "lo" accept comment "!fw4: Accept traffic from loopback"
ct state vmap { established : accept, related : accept } comment "!fw4: Handle inbound flows"
tcp flags syn / fin,syn,rst,ack jump syn_flood comment "!fw4: Rate limit TCP syn packets"
iifname "br-lan" jump input_lan comment "!fw4: Handle lan IPv4/IPv6 input traffic"
iifname "eth2" jump input_wan comment "!fw4: Handle wan IPv4/IPv6 input traffic"
jump handle_reject
chain forward {
type filter hook forward priority filter; policy drop;
ct state vmap { established : accept, related : accept } comment "!fw4: Handle forwarded flows"
iifname "br-lan" jump forward_lan comment "!fw4: Handle lan IPv4/IPv6 forward traffic"
iifname "eth2" jump forward_wan comment "!fw4: Handle wan IPv4/IPv6 forward traffic"
jump handle_reject
chain output {
type filter hook output priority filter; policy accept;
oif "lo" accept comment "!fw4: Accept traffic towards loopback"
ct state vmap { established : accept, related : accept } comment "!fw4: Handle outbound flows"
oifname "br-lan" jump output_lan comment "!fw4: Handle lan IPv4/IPv6 output traffic"
oifname "eth2" jump output_wan comment "!fw4: Handle wan IPv4/IPv6 output traffic"
chain prerouting {
type filter hook prerouting priority filter; policy accept;
iifname "br-lan" jump helper_lan comment "!fw4: Handle lan IPv4/IPv6 helper assignment"
chain handle_reject {
meta l4proto tcp reject with tcp reset comment "!fw4: Reject TCP traffic"
reject comment "!fw4: Reject any other traffic"
chain syn_flood {
limit rate 25/second burst 50 packets return comment "!fw4: Accept SYN packets below rate-limit"
drop comment "!fw4: Drop excess packets"
chain input_lan {
jump accept_from_lan
chain output_lan {
jump accept_to_lan
chain forward_lan {
jump accept_to_wan comment "!fw4: Accept lan to wan forwarding"
jump accept_to_lan
chain helper_lan {
chain accept_from_lan {
iifname "br-lan" counter packets 172 bytes 20257 accept comment "!fw4: accept lan IPv4/IPv6 traffic"
chain accept_to_lan {
oifname "br-lan" counter packets 55 bytes 9666 accept comment "!fw4: accept lan IPv4/IPv6 traffic"
chain input_wan {
meta nfproto ipv4 udp dport 68 counter packets 0 bytes 0 accept comment "!fw4: Allow-DHCP-Renew"
icmp type echo-request counter packets 2 bytes 168 accept comment "!fw4: Allow-Ping"
meta nfproto ipv4 meta l4proto igmp counter packets 51 bytes 1632 accept comment "!fw4: Allow-IGMP"
meta l4proto udp ip daddr 224.0.0.0/4 counter packets 0 bytes 0 accept comment "!fw4: Allow-IGMP-Broadcast"
meta nfproto ipv6 udp dport 546 counter packets 0 bytes 0 accept comment "!fw4: Allow-DHCPv6"
ip6 saddr fe80::/10 icmpv6 type . icmpv6 code { mld-listener-query . no-route, mld-listener-report . no-route, mld-listener-done . no-route, mld2-listener-report . no-route } counter packets 24 bytes 1824 accept comment "!fw4: Allow-MLD"
icmpv6 type { destination-unreachable, time-exceeded, echo-request, echo-reply, nd-router-solicit, nd-router-advert } limit rate 1000/second burst 5 packets counter packets 344 bytes 49536 accept comment "!fw4: Allow-ICMPv6-Input"
icmpv6 type . icmpv6 code { packet-too-big . no-route, parameter-problem . no-route, nd-neighbor-solicit . no-route, nd-neighbor-advert . no-route, parameter-problem . admin-prohibited } limit rate 1000/second burst 5 packets counter packets 4 bytes 256 accept comment "!fw4: Allow-ICMPv6-Input"
jump reject_from_wan
chain output_wan {
jump accept_to_wan
chain forward_wan {
icmpv6 type { destination-unreachable, time-exceeded, echo-request, echo-reply } limit rate 1000/second burst 5 packets counter packets 0 bytes 0 accept comment "!fw4: Allow-ICMPv6-Forward"
icmpv6 type . icmpv6 code { packet-too-big . no-route, parameter-problem . no-route, parameter-problem . admin-prohibited } limit rate 1000/second burst 5 packets counter packets 0 bytes 0 accept comment "!fw4: Allow-ICMPv6-Forward"
meta l4proto esp counter packets 0 bytes 0 jump accept_to_lan comment "!fw4: Allow-IPSec-ESP"
udp dport 500 counter packets 0 bytes 0 jump accept_to_lan comment "!fw4: Allow-ISAKMP"
jump reject_to_wan
chain accept_to_wan {
meta nfproto ipv4 oifname "eth2" ct state invalid counter packets 34355 bytes 1427155 drop comment "!fw4: Prevent NAT leakage"
oifname "eth2" counter packets 940 bytes 285783 accept comment "!fw4: accept wan IPv4/IPv6 traffic"
chain reject_from_wan {
iifname "eth2" counter packets 41141 bytes 2274747 jump handle_reject comment "!fw4: reject wan IPv4/IPv6 traffic"
chain reject_to_wan {
oifname "eth2" counter packets 0 bytes 0 jump handle_reject comment "!fw4: reject wan IPv4/IPv6 traffic"
chain dstnat {
type nat hook prerouting priority dstnat; policy accept;
chain srcnat {
type nat hook postrouting priority srcnat; policy accept;
oifname "eth2" jump srcnat_wan comment "!fw4: Handle wan IPv4/IPv6 srcnat traffic"
chain srcnat_wan {
meta nfproto ipv4 masquerade comment "!fw4: Masquerade IPv4 wan traffic"
chain raw_prerouting {
type filter hook prerouting priority raw; policy accept;
chain raw_output {
type filter hook output priority raw; policy accept;
chain mangle_prerouting {
type filter hook prerouting priority mangle; policy accept;
chain mangle_postrouting {
type filter hook postrouting priority mangle; policy accept;
oifname "eth2" tcp flags syn / fin,syn,rst tcp option maxseg size set rt mtu comment "!fw4: Zone wan IPv4/IPv6 egress MTU fixing"
chain mangle_input {
type filter hook input priority mangle; policy accept;
chain mangle_output {
type route hook output priority mangle; policy accept;
chain mangle_forward {
type filter hook forward priority mangle; policy accept;
iifname "eth2" tcp flags syn / fin,syn,rst tcp option maxseg size set rt mtu comment "!fw4: Zone wan IPv4/IPv6 ingress MTU fixing"
ok, daniels version does not support flow offloading yet as we are working on more basic tasks ![]()
then it looks that software thinks it sends packets out of lan2, but not really sending (right)
Yeah, PPE needs more work to support 4 GiB of RAM. If you want to test PPE you can limit RAM to 2 GiB in the meantime (ie. fw_setenv bootargs "$(fw_printenv -n bootargs) mem=2048M").
Regarding 100M: I can confirm 100M and 10M modes indeed don’t work with OpenWrt Linux 6.1 build. For starters, can you @frank-w test if 100M or 10M links on the switch ports work with your build?
I’m not sure i find 10/100 Equipment anywhere as i dropped such parts from my network over time…imho all is GBE
doesnt need to be 100/10mbit devices, just set it with ethtool to 100mbit and see if dhcp works. i am able to reproduce the bug with my laptop, connected via usb-c->rj45 to the banana pi
yes i know that i can manipulate the speed with ethtool, but this works ![]()
made a connection on wan in 1G-Mode to have working start, then change speed to 100M, still works
#get a working state first
root@bpi-r4-v11:~# ip a a 192.168.0.10/24 dev wan
root@bpi-r4-v11:~# ip link set wan up
[ 48.826375] DEBUG: Passed mtk_dma_init 3522 maybe call hwlro_rx_init
[ 48.834447] DEBUG: Passed mtk_hwlro_rx_init 2948 hwlro_rx_init
[ 48.840285] DEBUG: Passed mtk_hwlro_rx_init 2992 >=netsys_v2
[ 48.845931] DEBUG: Passed mtk_hwlro_rx_init 3016 set perLRO GRP INT
[ 48.852195] mtk_soc_eth 15100000.ethernet: mtk_rx_alloc 1 MTK_RX_FLAGS_NORMAL
[ 48.859769] mtk_soc_eth 15100000.ethernet: mtk_rx_alloc 2 MTK_RX_FLAGS_NORMAL
[ 48.867440] mtk_soc_eth 15100000.ethernet: mtk_rx_alloc 3 MTK_RX_FLAGS_NORMAL
[ 48.875010] DEBUG: Passed mtk_rss_init 3335
[ 48.879184] DEBUG: Passed mtk_rss_init 3401 netsysv2:1
[ 48.884612] DEBUG: Passed mtk_open 3874 enable napi and irq for lro
[ 48.890879] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[ 48.899002] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[ 48.899453] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[ 48.916276] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
root@bpi-r4-v11:~# ping 192.168.0.10
PING 192.168.0.10 (192.168.0.10) 56(84) bytes of data.
64 bytes from 192.168.0.10: icmp_seq=1 ttl=64 time=0.086 ms
64 bytes from 192.168.0.10: icmp_seq=2 ttl=64 time=0.017 ms
^C
--- 192.168.0.10 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1068ms
rtt min/avg/max/mdev = 0.017/0.051/0.086/0.034 ms
root@bpi-r4-v11:~# ethtool wan set speed 100
Settings for wan:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
master-slave cfg: preferred slave
master-slave status: master
Port: Twisted Pair
PHYAD: 0
Transceiver: external
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
#lets change the speed to 100Mbit
root@bpi-r4-v11:~# ethtool -s wan speed 100
[ 104.903290] mt7530-mmio 15020000.switch wan: Link is Down
root@bpi-r4-v11:~# [ 106.899487] mt7530-mmio 15020000.switch wan: Link is Up - 100Mbps/Full - flow control rx/tx
root@bpi-r4-v11:~#
64 bytes from 192.168.0.10: icmp_seq=1 ttl=64 time=0.056 ms
64 bytes from 192.168.0.10: icmp_seq=3 ttl=64 time=0.015 ms
64 bytes from 192.168.0.10: icmp_seq=4 ttl=64 time=0.015 ms
64 bytes from 192.168.0.10: icmp_seq=5 ttl=64 time=0.016 ms
^C
5 packets transmitted, 5 received, 0% packet loss, time 4136ms
rtt min/avg/max/mdev = 0.015/0.023/0.056/0.016 ms
Settings for wan:
1000baseT/Full
Advertised link modes: 100baseT/Half 100baseT/Full
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
64 bytes from 192.168.0.10: icmp_seq=1 ttl=64 time=0.058 ms
64 bytes from 192.168.0.10: icmp_seq=2 ttl=64 time=0.016 ms
^C
2 packets transmitted, 2 received, 0% packet loss, time 1006ms
rtt min/avg/max/mdev = 0.016/0.037/0.058/0.021 ms
#just to complete 10M too
[ 185.393294] mt7530-mmio 15020000.switch wan: Link is Down
root@bpi-r4-v11:~# [ 187.168545] mt7530-mmio 15020000.switch wan: Link is Up - 10Mbps/Full - flow control rx/tx
64 bytes from 192.168.0.10: icmp_seq=2 ttl=64 time=0.022 ms
^C
2 packets transmitted, 2 received, 0% packet loss, time 1016ms
rtt min/avg/max/mdev = 0.022/0.040/0.058/0.018 ms
Settings for wan:
1000baseT/Full
Speed: 10Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
root@bpi-r4-v11:~#
hmm, so that means, with your image it works. can you turn off auto negotiation? i dont think it has any influence but i had autoneg off, just to have the exact same settings.
same:
root@bpi-r4-v11:~# ethtool -s wan speed 100 autoneg off
[ 9029.483214] mt7530-mmio 15020000.switch wan: Link is Down
root@bpi-r4-v11:~# [ 9031.961636] mt7530-mmio 15020000.switch wan: Link is Up - 100Mbps/Full - flow control off
64 bytes from 192.168.0.10: icmp_seq=1 ttl=64 time=0.057 ms
64 bytes from 192.168.0.10: icmp_seq=2 ttl=64 time=0.018 ms
^C
2 packets transmitted, 2 received, 0% packet loss, time 1026ms
rtt min/avg/max/mdev = 0.018/0.037/0.057/0.019 ms
Settings for wan:
1000baseT/Full
Advertised link modes: 1000baseT/Full
Speed: 100Mb/s
Duplex: Full
Auto-negotiation: off
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
Thank you for testing. I’m relieved because that means the mt7530 driver support and phy driver which is already upstream is fine and working well so far.
