I have not enabled it,maybe it is enabled by default. If you boot efi stack,maybe it is part of this. Virtio is because of qemu,right?
Is it required that efi file is on an efi partition when directly booting it?
Yes, virtio because of the QEMU, othewise this would be simply usb.
Good question. In this case, the EFI payload bootaa64.efi memory mapped from the ISO to the 0x4b000000 address. My guess this is not required for the installer, but might be required if you boot from NVMe or eMMC.
Do we need efi at all? Basicly kernel+dtb+initrd should be enough,except installer requires efi,but on arm(64) efi is not standard.
No, I just dumped my notes into this comment if you or someone else want to experiment with EFI booting. āLegacyā (kernel+dtb+initrd) boot work just as fine.
I just tried it and no luck ![]()
I confirmed the clock drivers all in their place but we does not reach initrd loading without the clock driver init. So looks like it makes no sense to build these as modulesā¦
Iām not sure autoloading modules works with clock drivers and in initrd. Afaik they have to be builtin.
Maybe it makes aense for debian team providing a per-vendor kernel binary to not increase the size too much if this is the argument for make clock drivers as modules.
Or just use my kernel and booting only the initrd to have installer (for e.g. different partition scheme than my images)ā¦could this work?
I like the idea. This should be enough to install Debian but then we still have the same problem when we want to boot it if I understand correctly. Iām may be wrong about this, but the installer built from the upstream kernel, so it may fail to load rootfs at the first bootā¦
I think I ask them to have this module builtin. This is around ~13kb which should not be an issue. Also 7988, 7981, 8195 and 8173 clock drivers are all builtins. This justify to have 7986 builtin as well in my opinion.
I mean not using debian kernel entirelyā¦only the rootfs
I continued the experiments with diferent installers. I expected little bit more responsiveness or quicker merge of the =y clockdriver change at Debian, lets hope they merge the PR sonner than later. Until that happens, I checked on which major distro config have it:
As turned out, Ubuntu since 24.10 and Oracle Linux 10 have it. So I tried both.
Ubuntu 25.04 successfully boot with bootefi. (Consider enabling bootefi for your u-boot builds as well). Unfortunately it is unable to initialize the a PCI subsystem, so lspciās output literally empty. At least it can reach init, unpack initramfs and I only stuck at the point when it probe the block devices. eMMC not visible as a install target disk (even though lsblk see it), and NVMe not visible since the PCI subsystem not initialized. Your u-boot build see the NVMe, list its content, etc. so the device is fineā¦
Oracle Linux boot up as well and it is also reach the init successfully. Well, then something fails, the installer abort with a huge error banner in infinite loop.
Regarding the PCI: in your config, there were some extra config to bring up the PCI subsystem? My assumption Iāll run into this in the future with Debian installer as well.
Pcie nodes are still missing in upstream uboot because they want to switch dts to of_upatream first. But this requires having dts in linux also for mt7988 and some driver changes in uboot to be compatible with linux dts
Iām curious about PCIe in Linux, this is not in upstream for MT7986?
Linux should work. Any messages in dmesg different to working system?
Yes there were some anomalies. Iāll get back to that tomorrow I did not saved the dmesg output. thanks for the confirmation about the PCI
I managed to save out a bootlog, here it is: ubuntu_bootlog.txt (48.3 KB). Also included some output from the initās output, but there are some stackdump from UBSAN.
The output of lsmod:
root@ubuntu-server:/# lsmod
Module Size Used by
qrtr 49152 2
mt7915e 229376 0
mt76_connac_lib 106496 1 mt7915e
mt76 159744 2 mt7915e,mt76_connac_lib
mac80211 1658880 3 mt76,mt7915e,mt76_connac_lib
cfg80211 1306624 4 mt76,mt7915e,mac80211,mt76_connac_lib
libarc4 12288 1 mac80211
at24 32768 0
ofpart 16384 0
crypto_safexcel 172032 0
cmdlinepart 16384 0
spinand 86016 0
authenc 12288 1 crypto_safexcel
nandcore 69632 1 spinand
bch 28672 1 nandcore
mtd 106496 5 cmdlinepart,ofpart,nandcore,spinand
pwm_fan 24576 0
libdes 36864 1 crypto_safexcel
auxadc_thermal 24576 0
ramoops 40960 0
pwm_mediatek 12288 1
reed_solomon 28672 1 ramoops
leds_gpio 12288 0
uio_pdrv_genirq 16384 0
uio 28672 1 uio_pdrv_genirq
binfmt_misc 28672 1
sch_fq_codel 24576 1
nvme_fabrics 36864 0
nvme_keyring 20480 1 nvme_fabrics
nvme_core 225280 1 nvme_fabrics
nvme_auth 28672 1 nvme_core
efi_pstore 12288 0
dm_multipath 49152 0
nfnetlink 24576 1
dmi_sysfs 24576 0
ip_tables 36864 0
x_tables 65536 1 ip_tables
autofs4 61440 2
overlay 208896 1
nls_iso8859_1 12288 0
raid10 81920 0
raid456 217088 0
async_raid6_recov 24576 1 raid456
async_memcpy 16384 2 raid456,async_raid6_recov
async_pq 16384 2 raid456,async_raid6_recov
async_xor 16384 3 async_pq,raid456,async_raid6_recov
async_tx 16384 5 async_pq,async_memcpy,async_xor,raid456,async_raid6_recov
xor 12288 1 async_xor
xor_neon 16384 1 xor
raid6_pq 110592 3 async_pq,raid456,async_raid6_recov
raid1 61440 0
raid0 28672 0
linear 16384 0
uas 32768 0
usb_storage 90112 2 uas
phy_mtk_tphy 49152 3
xhci_mtk_hcd 40960 0
nvmem_mtk_efuse 12288 0
spi_mt65xx 32768 0
pcie_mediatek_gen3 32768 0
mtk_rng 12288 0
polyval_ce 12288 0
polyval_generic 12288 1 polyval_ce
i2c_mt65xx 36864 0
ghash_ce 24576 0
sm4 12288 0
sha2_ce 20480 0
sha256_arm64 24576 1 sha2_ce
sha1_ce 12288 0
gpio_keys 24576 0
fixed 16384 4
aes_neon_bs 24576 0
aes_neon_blk 28672 1 aes_neon_bs
aes_ce_blk 36864 0
aes_ce_cipher 12288 1 aes_ce_blk
For verification, here is a good bootlog with a recent OpenWRT snapshot: openwrt_bootlog.txt (26.5 KB)
And the lsmod from OpenWRT:
air_en8811h 16384 2
aquantia 24576 0
at24 16384 0
authenc 12288 2 crypto_safexcel,authencesn
authencesn 12288 0
cfg80211 315392 4 mt7915e,mt76_connac_lib,mt76,mac80211
compat 12288 2 mac80211,cfg80211
crypto_safexcel 98304 0
des_generic 12288 0
geniv 12288 1 seqiv
gpio_button_hotplug 16384 0
leds_gpio 12288 0
libcrc32c 12288 1 nf_tables
libdes 20480 2 crypto_safexcel,des_generic
mac80211 618496 3 mt7915e,mt76_connac_lib,mt76
md5 12288 1 crypto_safexcel
mt76 77824 2 mt7915e,mt76_connac_lib
mt76_connac_lib 49152 1 mt7915e
mt7915e 139264 0
nf_conntrack 98304 7 nft_redir,nft_nat,nft_masq,nft_flow_offload,nft_ct,nf_nat,nf_flow_table
nf_defrag_ipv4 12288 1 nf_conntrack
nf_defrag_ipv6 16384 1 nf_conntrack
nf_flow_table 28672 2 nf_flow_table_inet,nft_flow_offload
nf_flow_table_inet 12288 0
nf_log_syslog 16384 0
nf_nat 36864 4 nft_redir,nft_nat,nft_masq,nft_chain_nat
nf_reject_ipv4 12288 2 nft_reject_ipv4,nft_reject_inet
nf_reject_ipv6 12288 2 nft_reject_ipv6,nft_reject_inet
nf_tables 196608208 nft_fib_inet,nf_flow_table_inet,nft_reject_ipv6,nft_reject_ipv4,nft_reject_inet,nft_reject,nft_redir,nft_quota,nft_numgen,nft_nat,nft_masq,nft_log,nft_limit,nft_hash,nft_flow_offload,nft_fib_ipv6,nft_fib_ipv4,nft_fib,nft_ct,nft_chain_nat
nfnetlink 16384 1 nf_tables
nft_chain_nat 12288 2
nft_ct 16384 4
nft_fib 12288 3 nft_fib_inet,nft_fib_ipv6,nft_fib_ipv4
nft_fib_inet 12288 0
nft_fib_ipv4 12288 1 nft_fib_inet
nft_fib_ipv6 12288 1 nft_fib_inet
nft_flow_offload 12288 0
nft_hash 12288 0
nft_limit 12288 5
nft_log 12288 0
nft_masq 12288 1
nft_nat 12288 0
nft_numgen 12288 0
nft_quota 12288 0
nft_redir 12288 0
nft_reject 12288 3 nft_reject_ipv6,nft_reject_ipv4,nft_reject_inet
nft_reject_inet 12288 2
nft_reject_ipv4 12288 0
nft_reject_ipv6 12288 0
ppp_async 16384 0
ppp_generic 40960 3 pppoe,ppp_async,pppox
pppoe 20480 0
pppox 12288 1 pppoe
pwm_fan 12288 0
seqiv 12288 0
sha1_ce 12288 0
sha1_generic 12288 2 crypto_safexcel,sha1_ce
sha512_arm64 16384 0
slhc 12288 1 ppp_generic
usb_common 12288 3 xhci_plat_hcd,xhci_hcd,usbcore
usbcore 192512 4 xhci_plat_hcd,xhci_pci,xhci_mtk_hcd,xhci_hcd
xhci_hcd 135168 3 xhci_plat_hcd,xhci_pci,xhci_mtk_hcd
xhci_mtk_hcd 20480 0
xhci_pci 16384 0
xhci_plat_hcd 12288 0
Yeah something is strange with clkmux,not sure where the 255 shift comes from
[ 0.445882] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.464264] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.476942] ------------[ cut here ]------------
[ 0.476961] UBSAN: shift-out-of-bounds in /build/linux-VHJeXi/linux-6.14.0/drivers/clk/mediatek/clk-mux.c:44:8
[ 0.476971] shift exponent 255 is too large for 64-bit type 'long unsigned int'
[ 0.476978] CPU: 2 UID: 0 PID: 1 Comm: swapper/0 Not tainted 6.14.0-15-generic #15-Ubuntu
Possibly ubuntu changed something in kernel which break here.
Can you try without usbsan (idk what exactly this is atm without googling for)?
Why mixing ubuntu with debian?
Is it possible this come from a incompatible device tree? Iām using the Debian devicetree, since I cannot find any devicetree binaries for Ubuntu.
At the moment, Iām not mixing it, only the devicetree. This is stock Ubuntu 25.04 ARM64 ISO, and itās contenct copied to an Ext4 partiton in a USB stick. So R3mini booting from that, and both initrd and kernel are what provided by Ubuntu.
Device tree normally should be from upstream linux except fixes done by distribution itself. As i said no idea where the error is caused,but it happens in clk-mux driver and so posibly break more than only the unknown usbsan.
I see, thank you. Peeking into the installerās grub.cfg they actually provide some dtb-s for a few platform so I keep searching.
cat boot/grub/grub.cfg
set timeout=30
loadfont unicode
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
set dtb=
set cmdline=
smbios --type 1 --get-string 5 --set system_product_name
smbios --type 1 --get-string 6 --set system_product_version
smbios --type 1 --get-string 19 --set system_sku_number
regexp "ThinkPad X13s.*" "$system_product_version"
if [ $? = 0 ]; then
cmdline="clk_ignore_unused pd_ignore_unused arm64.nopauth"
dtb="devicetree /casper/dtbs/sc8280xp-lenovo-thinkpad-x13s.dtb"
fi
if [ "$system_product_version" == "ThinkPad T14s Gen 6" ]; then
# Workaround for 64GB crashes on T14s
cutmem 0x8800000000 0x8fffffffff
cmdline="clk_ignore_unused pd_ignore_unused cma=128M"
dtb="devicetree /casper/dtbs/x1e78100-lenovo-thinkpad-t14s.dtb"
fi
if [ "$system_product_version" == "Yoga Slim 7 14Q8X9" ]; then
dtb="devicetree /casper/dtbs/x1e80100-lenovo-yoga-slim7x.dtb"
fi
if [ "$system_product_name" == "XPS 13 9345" ]; then
# Workaround for 64GB crashes. Sigh...
dtb="devicetree /casper/dtbs/x1e80100-dell-xps13-9345.dtb"
fi
if [ "$system_product_name" == "Galaxy Book4 Edge" ]; then
dtb="devicetree /casper/dtbs/x1e80100-samsung-galaxy-book4-edge.dtb"
fi
if [ "$system_product_name" == "Swift SF14-11" ]; then
dtb="devicetree /casper/dtbs/x1p64100-acer-swift-sf14-11.dtb"
fi
if [ "$system_product_name" == "Swift SF14-11T" ]; then
fi
regexp "ASUS Vivobook S 15.*" "$system_product_name"
if [ $? == 0 ]; then
dtb="devicetree /casper/dtbs/x1e80100-asus-vivobook-s15.dtb"
fi
regexp "ASUS Zenbook A14 UX3407Q.*" "$system_product_name"
dtb="devicetree /casper/dtbs/x1p42100-asus-zenbook-a14.dtb"
fi
regexp "ASUS Zenbook A14 UX3407R.*" "$system_product_name"
dtb="devicetree /casper/dtbs/x1e80100-asus-zenbook-a14.dtb"
fi
regexp "HP OmniBook X Laptop 14-.*" "$system_product_name"
dtb="devicetree /casper/dtbs/x1e80100-hp-omnibook-x14.dtb"
fi
if [ "$system_sku_number" == "Surface_Laptop_7th_Edition_2036" ]; then
dtb="devicetree /casper/dtbs/x1e80100-microsoft-romulus13.dtb"
fi
if [ "$system_sku_number" == "Surface_Laptop_7th_Edition_2037" ]; then
dtb="devicetree /casper/dtbs/x1e80100-microsoft-romulus15.dtb"
fi
if [ "$system_product_name" == "CRD" ]; then
dtb="devicetree /casper/dtbs/x1e80100-crd.dtb"
fi
menuentry "Try or Install Ubuntu Server" {
set gfxpayload=keep
linux /casper/vmlinuz $cmdline --- console=tty0
initrd /casper/initrd
$dtb
menuentry 'Boot from next volume' {
exit 1
menuentry 'UEFI Firmware Settings' {
fwsetup
I was able to install Ubuntu 25.04 into the NVMe (screenshot below). The issue was not the kernel, but the missing devicetree. It turned out, GRUB cannot pass the devicetree (loaded by u-boot) to the kernel. So you have to manually configure the devicetree as done for ARM based notebooks in my previous comment. For some reason I assumed the devicetree passed througth all the way to the kernel like u-boot ā GRUB ā kernel but thats NOT the case. Interestingly, GRUB has a command to list efi memory maps which show the devicetree, but still not passed automatically.
So I made the following grub menuentry into the grub.cfg:
menuentry "Try or Install Ubuntu Server on MT7986" {
set gfxpayload=keep
linux /casper/vmlinuz $cmdline --- console=ttyS0,115200n8
devicetree /casper/dtbs/mt7986.dtb
The mt7986.dtb is just the copied/renamed from Debian, probably extracted from OpenWRT FIT image would do the trick as well. I made the casper/dtbs/ folder (playing safe, I was not sure what is GRUBās root or workdir, the casper folder was straightforward).
So I have Ubuntu installed on the NVMe, but unfortunately I canāt load it. OpenWRT u-boot does not support PCIe NVMe, and bootefi missing from your u-boot fork. Iāll try to load it manually with booti but it would be really convenient to use EFI for both installing and loading the installed Linux just like on a PC
I sent a PR (not tested) to your fork enabling the EFI options, consider merge it if its makes sense, thanks in advance!
Devicetree is board specific so it should not have the name of soc onlyā¦but your system is now boooting correctly?
