Thanks for your help, but where can I download the rest of the bin files?
Thank you so much for your help. So now i have boot from mtk_uartboot.exe Everything looks fine but⦠Now Iām stuck here⦠i Have (i think) all files in USB, but what is next?
BPI-R3M> fatls usb 0:1
System Volume Information/
200072 bl2_emmc-r3mini.img
88256491 mtk-bpi-r3mini-EMMC-20231115.img
57933824 mtk-bpi-r3mini-NAND-20231115-single-image.bin
1166121 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-emmc-bl31-uboot.fip
17408 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-emmc-gpt.bin
200793 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-emmc-preloader (1).bin
200793 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-emmc-preloader.bin
9437184 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb
1130193 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip
15990784 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-factory.bin
217824 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-preloader.bin
11796799 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb
12 file(s), 1 dir(s)
BPI-R3M>
Afaik you can start the initramfs image to get into openwrt itself and follow install like described in their wiki
https://openwrt.org/toh/sinovoip/bananapi_bpi_r3_mini#installation
Have only found openwrt boot for r4 but r3 should be similar
dumpimage -l openwrt-24.10.0-mediatek-filogic-bananapi_bpi-r4-initramfs-recovery.itb
tftpboot 0x50000000 openwrt-mediatek-filogic-bananapi_bpi-r4-initramfs-recovery.itb
bootm 0x50000000#config-mt7988a-bananapi-bpi-r4#mt7988a-bananapi-bpi-r4-sd
maybe you do not need the first command for r3mini, as there are imho no additional overlays
so only loading the initramfs itb and the boot it without passing overlay (skip from #, only address)
and of course use āfatload usb 0:1 ā¦ā instead of tftpboot ![]()
Im stuck in here as well ![]()
what should be the command
for my R3_Mini ?
Usage:
fatls <interface> [<dev[:part]>] [directory]
- list files from 'dev' on 'interface' in a 'directory'
BPI-R3M> fatload usb 0:1 0x50000000 openwrt-24.10.0-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb
9306112 bytes read in 271 ms (32.7 MiB/s)
BPI-R3M> bootm 0x50000000#config-mt7988a-bananapi-bpi-r4#mt7988a-bananapi-bpi-r4-sd
## Loading kernel from FIT Image at 50000000 ...
Could not find configuration node
ERROR -2: can't get kernel image!
BPI-R3M>
Maybe there is some specific step-by-step instructions, with all the commands typical for R3_Mini? Then it would be easier for me, I didnāt think it was that complicated, and I still have to start the Quectel_Rm520 modem on this R3_Mini
Regards and sorry for my lack of knowledge, but I really want to start this router.
just try
bootm 0x50000000
here, imho no config/overlay name required on r3mini
thank You so much
It started working, now I will try to upgrade nand/mmc to version 24
What is the next step? i Will try this, from this page - but problem is not solved⦠https://openwrt.org/toh/sinovoip/bananapi_bpi_r3_mini#supported_versions
from this as well https://wiki.banana-pi.org/Getting_Started_with_BPI-R3_MINI
ImmortalWrt SNAPSHOT, r33471-6b3e77778f
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
OpenWrt recently switched to the "apk" package manager!
OPKG Command APK Equivalent Description
opkg install <pkg> apk add <pkg> Install a package
opkg remove <pkg> apk del <pkg> Remove a package
opkg upgrade apk upgrade Upgrade all packages
opkg files <pkg> apk info -L <pkg> List package contents
opkg list-installed apk info List installed packages
opkg update apk update Update package lists
opkg search <pkg> apk search <pkg> Search for packages
For more https://openwrt.org/docs/guide-user/additional-software/opkg-to-apk-cheatsheet
root@ImmortalWrt:~# mtd write /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-preloader.bin /dev/mtd0
ubiformat /dev/mtd1
ubiattach -m 1
volsize=$(wc -c < /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip)
ubimkvol /dev/ubi0 -N fip -n 0 -s $volsize -t static
Could not open mtd device: /dev/mtd0
Can't open device for writing!
root@ImmortalWrt:~# ubidetach -m 1
ubiupdatevol /dev/ubi0_0 /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip
cd /lib/firmware/airoha
cat EthMD32.dm.bin EthMD32.DSP.bin > /tmp/en8811h-fw.bin
ubimkvol /dev/ubi0 -N en8811h-firmware -n 1 -s 147456 -t static
ubiupdatevol /dev/ubi0_1 /tmp/en8811h-fw.bin
ubimkvol /dev/ubi0 -n 2 -N ubootenv -s 126976
ubimkvol /dev/ubi0 -n 3 -N ubootenv2 -s 126976
volsize=$(wc -c < /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb)
ubimkvol /dev/ubi0 -n 4 -N recovery -s $volsize
ubiupdatevol /dev/ubi0_4 /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb
volsize=$(wc -c < /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb)
ubimkvol /dev/ubi0 -n 5 -N fit -s $volsize
ubiupdatevol /dev/ubi0_5 /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itbroot@ImmortalWrt:~# ubiformat /dev/mtd1
ubiformat: mtd1 (nand), size 132120576 bytes (126.0 MiB), 1008 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 1007 -- 100 % complete
ubiformat: 1008 eraseblocks have valid erase counter, mean value is 5
ubiformat: formatting eraseblock 1007 -- 100 % complete
root@ImmortalWrt:~# ubiattach -m 1
UBI device number 0, total 1008 LEBs (127991808 bytes, 122.0 MiB), available 982 LEBs (124690432 bytes, 118.9 MiB), LEB size 126976 bytes (124.0 KiB)
root@ImmortalWrt:~# volsize=$(wc -c < /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip)
root@ImmortalWrt:~# ubimkvol /dev/ubi0 -N fip -n 0 -s $volsize -t static
Volume ID 0, size 9 LEBs (1142784 bytes, 1.0 MiB), LEB size 126976 bytes (124.0 KiB), static, name "fip", alignment 1
root@ImmortalWrt:~# ubiupdatevol /dev/ubi0_0 /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip
root@ImmortalWrt:~# cd /lib/firmware/airoha
root@ImmortalWrt:/lib/firmware/airoha# cat EthMD32.dm.bin EthMD32.DSP.bin > /tmp/en8811h-fw.bin
root@ImmortalWrt:/lib/firmware/airoha# ubimkvol /dev/ubi0 -N en8811h-firmware -n 1 -s 147456 -t static
Volume ID 1, size 2 LEBs (253952 bytes, 248.0 KiB), LEB size 126976 bytes (124.0 KiB), static, name "en8811h-firmware", alignment 1
root@ImmortalWrt:/lib/firmware/airoha# ubiupdatevol /dev/ubi0_1 /tmp/en8811h-fw.bin
root@ImmortalWrt:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 2 -N ubootenv -s 126976
Volume ID 2, size 1 LEBs (126976 bytes, 124.0 KiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "ubootenv", alignment 1
root@ImmortalWrt:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 3 -N ubootenv2 -s 126976
Volume ID 3, size 1 LEBs (126976 bytes, 124.0 KiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "ubootenv2", alignment 1
root@ImmortalWrt:/lib/firmware/airoha# volsize=$(wc -c < /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb)
root@ImmortalWrt:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 4 -N recovery -s $volsize
Volume ID 4, size 107 LEBs (13586432 bytes, 12.9 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "recovery", alignment 1
root@ImmortalWrt:/lib/firmware/airoha# ubiupdatevol /dev/ubi0_4 /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb
root@ImmortalWrt:/lib/firmware/airoha# volsize=$(wc -c < /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb)
root@ImmortalWrt:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 5 -N fit -s $volsize
Volume ID 5, size 134 LEBs (17014784 bytes, 16.2 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "fit", alignment 1
root@ImmortalWrt:/lib/firmware/airoha# ubiupdatevol /dev/ubi0_5 /tmp/immortalwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb
I wonder about immortalwrtā¦i thought you use openwrtā¦you should not mix images and instructions as they may vary.
But after flashing all, it should boot so just type ārebootā.
