I reverted back to the original wlan1.conf. I used channel 36 instead of channel 149. I measured about 50Mbps. Unfortunately, it is not possible to connect an iPhone to the AP set in this way - Raspberry and lenovo motebooks have no connection problem.
I do not have anything in dmesg or output from hostapd. It just fails.
However, it does look like timeout related. If the AP or the (last) STA times out, maybe it does shut down to save energy? So maybe some unwanted energy saving behavior? But I’m still just guessing…
Edit:
In the middle of doing an iperf3, I got:
Sep 03 08:55:41 bpir3 systemd-networkd[2980]: wlan1: Lost carrier
Nothing else, also not in dmesg output. So it is not timeout related (or this is another bug).
I have a fairly complete Linux router. There are about 7 LAN devices running on it. One of them is Raspberry Pi 5. I am currently solving this problem:
About one in 7 RPI5 boots won’t get a LAN connection. The RPI5 receives an IP address from the DHCP server, but cannot ping anywhere. Conversely, it is possible to ping RPI5 from the router. The fault is likely to be on the RPI side. I just want to make sure there is no setting on the BPI-R3 that can fix this.
Moved the repo server and image-files server over to Oracle always-free-services tier, which has a static ip. There should be no problems migrating. It may be better reachable, perhaps even through the great wall of china.
Ftp and http servers are up, https is to follow up.
is it possible to advise on my case please? trying on bpi-r4 board
Got one of the ready images also used your script to create a new sdcard both AP and router but I cant set the interfaces up due to memory and apparently something is wrong with the system not recognizing the memory correctly
[root@bpir4 ~]# free -hm
total used free shared buff/cache available
Mem: 231Mi 165Mi 14Mi 684Ki 66Mi 66Mi
Swap: 0B 0B 0B
Also during boot there are sine services failing.
[**FAILED**] Failed to start **Setup MAC addresses**.
See 'systemctl status setmac.service' for details.
[**FAILED**] Failed to start **Netfilter Tables**.
See 'systemctl status nftables.service' for details.
It is possible to build an image with Ubuntu instead. Only the bananapi archlinuxarm custom packages are maintained through archlinux packages. These are linux-bpir-git, bpir-atf-git, bpir-toolbox, bpir-initrd, bpir-flash2emmc, hostapd-launch, ssh-fix-reboot and optional bpir-uboot-git package. Any executables within these packages are build as static binaries, so they can be executed independantly.
On Ubuntu there is a small script to help upgrade these packages:
Only bpir-atf-git and bpir-uboot-git are normally excluded from upgrade. They need to be upgraded manually.
All other packages in the rootfs are the normal Ubuntu packages. The setup is practically the same as the ArchlinuxARM setup. Since it is mostly based on systemd, there are hardly any differences. It is still in the experimental phase.
But there are more options when using the script instead.
Note: bpir-uboot-git package has not really been maintained, since the normal boot sequence is from atf directly into kernel. I wrote it more as an example of how to setup the bootchain with uboot. One can edit the package to custom needs.
My bridge-fastpath patch-set is now added to my rolling-stable branch for the bpi-r3/r64. However, one does need to add the nftables rules manually.
Note that there are also some fixes that apply to the normal (forward-) fastpath. Also, the L2-roaming issue is addressed.
Note: To bridged-fastpath pppoe, pppoe-in-q and q-in-q, one needs to add a conntrack zone to the traffic, helping conntrack to know that all used vlan’s and all pppoe traffic are separated. This should actually already be done for normal vlan traffic, but there is no hard restriction.
I think I will continue upstreaming after the coming merge window, it may take quite some time, so I’ve added it to my kernel fork, not waiting for the upstream…
