As I mentioned in the other thread, I’m getting slow speeds. I’ll put my network configuration details in here.
My main router is a Netgear WNDR3800 running OpenWRT. I was testing out the banana pi r2, hoping it could replace the netgear. The netgear has an internal IP address of 192.168.15.1. It connects to my ISP using PPPOE. I posted details of its configuration on the OpenWRT board.
One of the lan ports of my router is connected to a switch. I am running the test between 2 computers. One of the computers, mihoshi is connected to that switch, and has an IP of 192.168.15.2. Because my main internet connection goes through PPPoE, mihoshi’s MTU is 1492.
The wan port of the Banana PI R2 is connected to the switch. The other computer, ryoko is connected to lan3 of the Banana Pi R2. The Banana Pi is performing a NAT translation between the two computers. I’ve set ryoko’s MTU to 1492 to match mihoshi’s.
Here’s how I’m measuring the speed:
$ ssh [email protected] 'cat /dev/zero' | pv >/dev/null
^C02GiB 0:01:29 [37.3MiB/s]
I think mihoshi and ryoko’s network settings are correct, because the gets about 90MiB/s when I use an expressobin instead of the banana pi.
Here is the configuration of my banana pi:
root@bpi-r2:~# uname -a
Linux bpi-r2 4.14.80-bpi-r2-main #177 SMP Sun Nov 11 10:03:58 CET 2018 armv7l GNU/Linux
root@bpi-r2:~# iptables-save
# Generated by iptables-save v1.6.0 on Sun Jan 20 09:26:23 2019
*filter
:INPUT ACCEPT [8827:730234]
:FORWARD ACCEPT [54709:25786012]
:OUTPUT ACCEPT [9931:1198866]
COMMIT
# Completed on Sun Jan 20 09:26:23 2019
*nat
:PREROUTING ACCEPT [6742:849916]
:INPUT ACCEPT [3444:241724]
:OUTPUT ACCEPT [2492:166578]
:POSTROUTING ACCEPT [11:1615]
-A POSTROUTING -o wan -j MASQUERADE
COMMIT
root@bpi-r2:~# ip a
    inet6 ::1/128 scope host
    link/ether 3e:8c:11:69:29:8e brd ff:ff:ff:ff:ff:ff
    inet6 fe80::3c8c:11ff:fe69:298e/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 52:b1:52:1b:25:98 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::50b1:52ff:fe1b:2598/64 scope link
4: wan@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 10000
    inet 192.168.15.140/24 brd 192.168.15.255 scope global wan
    inet6 2602:ae:1592:e100:50b1:52ff:fe1b:2598/64 scope global mngtmpaddr dynamic
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
7: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
8: lan3@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
9: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.2.1/24 brd 192.168.2.255 scope global br0
root@bpi-r2:~# lsmod
Module                  Size  Used by
iptable_filter         16384  0
mtkhnat                24576  0
ipt_MASQUERADE         16384  1
nf_nat_masquerade_ipv4    16384  1 ipt_MASQUERADE
iptable_nat            16384  1
nf_conntrack_ipv4      16384  2
nf_defrag_ipv4         16384  1 nf_conntrack_ipv4
nf_nat_ipv4            16384  1 iptable_nat
nf_nat                 32768  2 nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack          126976  5 nf_conntrack_ipv4,ipt_MASQUERADE,nf_nat_masquerade_ipv4,nf_nat_ipv4,nf_nat
bridge                151552  0
mtk_thermal            16384  0
thermal_sys            61440  1 mtk_thermal
spi_mt65xx             20480  0
pwm_mediatek           16384  0
mt6577_auxadc          16384  0
nvmem_mtk_efuse        16384  0
mtk_pmic_keys          16384  0
rtc_mt6397             16384  1
ip_tables              24576  2 iptable_filter,iptable_nat
x_tables               28672  3 ip_tables,iptable_filter,ipt_MASQUERADE
ipv6                  409600  23 bridge
Since you said you had difficulty reproducing this, I ran a speed test to the internet from ryoko. Strangely, I am getting 355Mb/s download  and 308Mb/s upload, which is much higher than I expected considering the problems talking to a much closer computer. When ryoko connects directly to the switch, it gets 553Mb/s download and 451Mb/s upload.
