It works, if kernel modules like described HERE are enabled.
Hi, everyone!
Today i got my R2 halted with 5.8 kernel for 1st time ever.
- Firstly network gone down (wifi, i didnāt test ethernet)
- I got dmesg dump using serial console: 5.8-dmesg.txt (72.9 ŠŠ) (dump started from 1st trace after reboot, tha last one is incomplete)
- After reboot everything seems good for now, i cant reproduce the bug.
No 3rd party modules/drivers were used.
uptime 1 day and ~1 hr
[90769.755898] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[90769.755915] rcu: 0-....: (3 GPs behind) idle=962/0/0x1 softirq=2280595/2280595 fqs=3892
[90769.755922] (detected by 1, t=8407 jiffies, g=5917193, q=141)
[90769.755930] Sending NMI from CPU 1 to CPUs 0:
[90769.756369] NMI backtrace for cpu 0
[90769.756374] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 5.8.0-rc6-arm+ #1
[90769.756376] Hardware name: Mediatek Cortex-A7 (Device Tree)
[90769.756378] PC is at mt76_rx_aggr_reorder+0x4/0x2dc [mt76]
[90769.756380] LR is at mt76_rx_poll_complete+0x2e8/0x454 [mt76]
seems like rcu-stall bug in mt76 wifi-driver, some before are warnings in clock/reset-driver caused by lima_clk_disable
[45565.315187] WARNING: CPU: 1 PID: 20682 at drivers/reset/core.c:358 reset_control_assert+0x198/0x200
[45565.316034] WARNING: CPU: 1 PID: 20682 at drivers/clk/clk.c:958 clk_core_disable+0xec/0x28c
[45565.316040] g3d_core already disabled
[45565.317631] WARNING: CPU: 1 PID: 20682 at drivers/clk/clk.c:958 clk_core_disable+0xec/0x28c
[45565.317636] mmpll_ck already disabled
i see you have 5.8.0-rc6, could you try with 5.8-main tree?
Sure, Iāll try to update it nearest weekend.
A couple of errors with self-reboot in 2 days 5.8-rc-fails.txt (23.1 ŠŠ)
Now downgraded to 5.5, and 5.8-main compilation in progressā¦
P.S. Not actively used (as a PC ;)), not even logged in, just acted as a router (3-6 wifi clients both internal wifi and mt76), with serial console attached.
P.P.S BPI-MT7615 wifi card ( MT7612 wifi card replacement) is on the way, and as i understood it uses the same wifi driver as MT7612, is it correct?
Mt7615 uses also mt76 wifi driver right,but separate folder/CONFIG_option/module
I hope error is fixed in 5.8 final⦠maybe this: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/commit/drivers/net/wireless/mediatek/mt76?h=linux-5.8.y&id=4ac668a3b8c9d3477a3fe162c1cfeb867dd65de8
else it will be interesting if error is in 5.7,5.6,⦠just to get the breaking commit
For lima i guess we need the power-commit i added to 5.4-main
Iāve switched to 5.8.0 release. Iāll update on any errors/stability issues.
Yep, or dts-mod from 4.4 kernel which is in my 5.5-lima branch, Iām not sure which way is better, but both seems to be working.
Better is find bugs in most recent version
5 days of uptime with 5.8-main without any errors/TraceBacks/etc, interrupted by accidently pulled power cord
P.S. Without usb-wifi.
good to hear
and is usb-wifi still buggy? if there is a problem it should be reported to fix it mainline
My LTE modem with wifi-hotspot is buggy ;), so rolled back to USB LTE modem plugged in-to R2, usb-wifi dogle was used before as wifi-client. Iāll test usb wifi ASAP, but right now there is no use for it.
P.S. After modem+wifi replacement iāll be able to place R2 near TV, so hdmi/lima related stuff is going to be back in buisness soon
Hdmi is working in 5.8, but lima (power changes) is not ported to it
I started work on 5.9
This commit breaks bootup of r2 and r64 f97dbf48ca43009e8b8bcdf07f47fc9f06149b36 irqchip/mtk-sysirq: Convert to a platform driver
I got this fix that works https://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms.git/commit/?h=irq/irqchip-next&id=7828a3ef8646fb2e69ed45616c8453a037ca7867 but leaves some errors in bootlogā¦it looks like the full irq-series gets reverted in one of the next rcās
Updated 5.9-rc branch. Hdmi and wifi are working so far (5.9-hdmi, 5.9-wifi)
Got new traceback on 5.8-main: dmesg.txt (7.0 ŠŠ)
It appears on large file copying using mc (tens on GB), swap presence and amount doesnāt has any effect.
Looks like it doesnāt affects the OS.
Average free mem:
top - 23:16:34 up 1 day, 2:13, 4 users, load average: 1,26, 0,92, 1,39
Tasks: 152 total, 1 running, 151 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0,5 us, 18,3 sy, 0,0 ni, 61,2 id, 18,7 wa, 0,0 hi, 1,3 si, 0,0 st
MiB Mem : 2008,0 total, 6,7 free, 110,4 used, 1890,9 buff/cache
MiB Swap: 0,0 total, 0,0 free, 0,0 used. 1834,7 avail Mem
P.S. I do not remember such messages on earlier kernels, but i canāt exclude that.
P.S.S. Looks like some general kernel issue, not R2 specific,
Looks like bug in mt76 driver
mt76x02_update_beacon_iter [mt76x02_lib]
You can try opening issue on github.com/openwrt/mt76 but write that youāre using mainline 5.9-rc1ā¦i donāt know if they snc mt76 on every mergewindow
Mhmā¦you copy locally? Should not be affected by mc file copyā¦i guess it is caused by any limitation (cpu/ram) if related to copy
Btw for git i have created swap file to extend ramā¦else i got oom reaper messages. Tried different git configs (windowsize,threads,ā¦) but only swapfile works
Dts-patches (hdmi and pause fix) are now merged to linux-next.
mtk drm patches afaik need to be merged to drm-next first => done, waiting to be visible in linux-next
as the tdms patch is based on hdmi-phy-move file drivers/phy/mediatek/phy-mtk-hdmi.c does not exit yet, so we can use mtk_dpi.c to show changes done by commit āChange the getting possible_crtc wayā
Edit: linux-next from 2020-09-29 contains the mtk-drm patches
hi, i booted 5.10 the first time after adding the basic patches (adding build.sh,defconfigs,ā¦) and noticed at leats a warning
[ 6.151110] ahci 0000:02:00.0: version 3.0
[ 6.151136] ahci 0000:02:00.0: enabling device (0140 -> 0143)
[ 6.157056] ------------[ cut here ]------------
[ 6.161730] WARNING: CPU: 2 PID: 73 at include/linux/msi.h:213 pci_msi_setup_
msi_irqs.constprop.0+0x78/0x80
[ 6.724607] WARNING: CPU: 2 PID: 73 at include/linux/msi.h:219 free_msi_irqs+
https://elixir.bootlin.com/linux/v5.10-rc1/source/include/linux/msi.h#L219
which comes from commit 077ee78e392869e46ae6bdc6ba2a3c4249d0b5e1 (PCI/MSI: Make arch_.*_msi_irq[s] fallbacks selectable)
dmesg_5.10.log (47,6 KB)
I send patch for fixing itā¦patchwork => Patch only suppress warning, but does not fix the root causeā¦see comment from Thomas Gleixnerā¦have not found the root-cause yet ;( i guess ahci/mtk_pcie-driver or missing option in dts It looks like pcie driver does not setup a msi-domain for mt7623/mt2701, reverted my patch and booted on bpi-r64, and got no warningā¦this confirms my assumption, that this warning is caused only on mt2701/mt7623 where no msi-domain is setup.
Patch from Marc Zyngier seems to work, at least i get no warning
after getting hnat working on last lts (5.10) i got also second gmac working with the help of deng qingfang and Marek BehĆŗn. Switching CPU-Port of ports needs modified ip-tool (iproute2)
root@bpi-r2:~# ip link show wan
5: wan@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
link/ether 08:00:00:00:00:01 brd ff:ff:ff:ff:ff:ff
root@bpi-r2:~# ip link set wan link eth1
5: wan@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
root@bpi-r2:~#
references:
- https://github.com/openwrt/openwrt/pull/4036/commits
- https://github.com/LGA1150/openwrt/blob/exp/target/linux/ramips/patches-5.10/999-multicpu.patch
modified iproute2-tool can be found here:
second gmac is working on both devices (r2+r64) on quick-test, now also with default-cpu via dts, changing gmac via IP works
have uploaded compiled iproute2 binaries here: https://drive.google.com/drive/folders/1Zkxs_gglxxWCvVyY3HwPNNUmhR3DqW_h?usp=sharing
i have uploaded compiled kernel 5.10 with hnat+gmac patches here:
https://drive.google.com/drive/folders/17MoFc3vIuGHDEV5SsCmGegJDr009IXls?usp=sharing
compiled nftables can be found here: https://drive.google.com/drive/folders/1hajKvqQa96WRrAy52fQX90i59I1s0h-i?usp=sharing
second gmac seems to not work stableā¦i see massive retransmitts when doing iperf3.asked network-specialists from mtk if they can help
Does R64openwrt source(https://wiki.banana-pi.org/Banana_Pi_BPI-R64) support HW NAT? I can only find it in R2, how to add this module, throughput test is not high
You should use newer source,not the old vendor openwrt. Afaik hw-nat ia mainline till 5.12. My 5.10-hnat branch has support but it is no openwrt,but you can use the commits to add patches to openwrtā¦maybe mainline openwrt has already backported it to 5.10
Btw.this thread is about r2,not r64
