then this change is not needed…and all traffic should be bound. i tested only init-procedure (will be called if module loaded), because i don’t know how to debug it deeper
As far as i know,traffic is received by hnat-module,but i don’t know why it is unbind…there are several unclear checks (mtk_hnat_nf_post_routing) before bind is set (skb_to_hnat_info)
as you see the last message does not came up…so that condition seems to be the Problem…after adding a printk for the check-parts…i get much more messages (also the missing “from_wan/lan”)…seems previous test has cached something on client-side
i tested only over wifi-device because i need my laptop to build kernel…i think IS_LAN should be changed to include ap0 and wlan* devices or maybe !wan (but how about the unknown-devices - last step in prerouting)…
so i assume that hnat works, @rainfall83 am i right? how can we add this behaviour to ap0 and wlanx?
so everything that is not wan (dts-setting), lan (first 3 letters from interface name, so also lanbrx) and bridge-device (first 2 letters “br”) get tagging invalid…maybe we can create a additional tag (e.g. FOE_WIFI) and add a IS_WIFI-macro (check if devicename is ap0 or contains “wlan”).
btw. in /proc/interrupts i see no decisive difference between with and without mtkhnat-module
ok, it takes some time…i started a download (ubuntu-image) and after some seconds, the interrupts counting ~4/second…in debugfs i see more bind than unbind-entries
to get it running for wifi maybe we can change the code to check only for wan (because traffic should not go from wan to wan…and wan is always part of the check):
if (FROM_GE_WAN(skb) || IS_WAN(out)) {
instead of
if ((FROM_GE_WAN(skb) || FROM_GE_LAN(skb)) &&
and
instead of
if ((IS_LAN(out) && FROM_GE_WAN(skb)) || (IS_WAN(out) && FROM_GE_LAN(skb))) {
but first i want to merge current version, if someone confirm it is working
maybe then we can merge the block to only check once for wan-port and make additional checks inside
only check for wan seems not to work at least without tagging in mtk_hnat_nf_pre_routing
this is what i tried (no traffic with this patch on top of 4.14-hnat-branch): hnat_test_wifi.diff (2,5 KB) i have bind-entries for ap0-connection, but traffic seems to routed wrong or dropped
current hnat-code depends on second gmac. I don’t know if it is implemented same as in 4.9/4.14. also forwarding saves sourceport which needs name lanx or wan (needs dsa-driver).
Why do you put such effort in old kernel 4.4?
can you help me with uboot (mmc-offset) and bluetooth (also not working in 4.4) and wifi (wmt-tools)?
Per my understanding, framework support software acceleration and openwrt community enhanced it to support hardware acceleration in openwrt trunk. we should wait until upstream framework support hw acceleration before sending patch, thanks.
We are studying upstream framework and just found hnat feature can only be supported in openwrt trunk. After we have overview about framework, we will discuss with netfilter core developer about hw nat plan, and hope mt7623 can be the first platform to support upstream hnat feature, thanks.
We have sent 3 patches to openwrt and kernel.org to fix mt7621 hnat issues. All patches were merged, but OpenWRT user reported system become unstable and we are trying to find the root cause, thanks.
How many connection supported by hnat?
I tests BPI-R2 by ixia, one UDP flow it works good. But I saw only 4 records in debug/hnat/all_entry when run test with 128 UDP flows.
Which kernel have you tested? Old hnat-code in 4.14/4.9 from my repo or the new code in openwrt? remember hnat only works between lanx and wan,no bridge and no wifi
