BPI-Pico-S3 is the same size as Raspberry Pi Pico board, equipped with ESP32S3 chip, 8M flash, 4-layer PCB, electroplated half-hole process, ceramic antenna, supports 2.4 GHz Wi-Fi and Bluetooth® LE dual-mode wireless communication, is a development board designed for IoT development and Maker DIY.
Hardware interface
CircuitPython with Mu Editor
CircuitPython is a programming language designed to simplify experimenting and learning to code on low-cost microcontroller boards.
CircuitPython programming with Mu editor is the easiest way to get started. Install the software and connect the device to start using it.
Hardware Preparation
Mu editor supports Windows x64, Mac OSX, Linux operating systems, prepare a computer running one of these operating systems.
A development board that supports CircuitPython, such as BPI-PicoW-S3.
A USB cable that can connect the development board to the computer.
Download and install Mu Editor
- Enter Mu Editor , click the Download button to enter the new page.
- Select the operating system currently used by your computer, and click the Download button of the corresponding operating system to start downloading the installation package.
- Click the Instuctions button of the corresponding operating system to view the detailed installation steps, and install according to the instructions.
Establish the connection
- Start the Mu editor and change the mode to CircuitPython, if you have connected the CircuitPython development board correctly, you will be prompted whether to switch to this mode directly.
- Click the Serial button and press any key to enter the CircuitPython REPL.
Edit code.py to make the LED blink
Click the Load button, select the code.py file on the CircuitPython development board, and click Open to start editing code.py .
Enter the following code in the editor:
import time
import board
import neopixel
pixels = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.1)
while 1:
pixels[0] = (255,0,0)
pixels.show()
time.sleep(0.5)
pixels[0] = (0,255,0)
pixels.show()
time.sleep(0.5)
pixels[0] = (0,0,255)
pixels.show()
time.sleep(0.5)
pixels[0] = (255,255,255)
pixels.show()
time.sleep(0.5)
- Click the Save button, and the edited content will be saved to the CircuitPython development board.
Reference Resources
video demo on youtube:
OEM&OEM customized service: [email protected]
