Hi all,
I was able to build my SPI FLASH Firmware U-Boot using EFI and then I’ve install Debian 13 Trixie on SSD NVMe.
U-Boot EFI detects the EFI partition on NVMe (of course, U-Boot needs to be last version or with PCIe patches) and then I’m booting GRUB EFI.
In GRUB I’ve added devicetree /boot/… to load the DTB.
Is working very nice.
I’m working o a BASH script which builds the firmware and the rootfs for NVMe, but is not finish yet.
frank-w
(Frank W.)
July 21, 2025, 5:21pm
23
Which dtb? There are some overlays which are probed in the fit approach. Thats why i think extlinux and efi is not the best way…you are fixed to 1 config and if e.g. on R3 the other spi/mmc device is active it does not work.
frank-w
(Frank W.)
July 21, 2025, 5:23pm
24
Btw. Just a note for others: Debian trixie is not yet released (date 2025-08-09), it is freezed and can be tested,but it is not yet defined as stable.
https://wiki.debian.org/DebianTrixie
Even is not relaaed yet, is in testing, I’ve created a rootfs.
For DTB I’m using the one based on eMMC.
Now I’m testing dtoverlay tool from RaspberryPi to build a new DTB from base DTB + DTBO.
The apply to GRUB “devicetree” and reboot de device.
Example of DTB + DTBO merged by dtoverlay:
dtmerge
dtoverlay
dtparam
libdtovl.a
mt7988a-bananapi-bpi-r4-emmc.dtb
mt7988a-bananapi-bpi-r4-emmc.dtbo
mt7988a-bananapi-bpi-r4-sd.dtb
mt7988a-bananapi-bpi-r4-sd.dtbo
mt7988a-bananapi-bpi-r4.dtb
I used this command:
# ./dtmerge ./mt7988a-bananapi-bpi-r4.dtb mt7988a-bananapi-bpi-r4-emmc.dtb ./mt7988a-bananapi-bpi-r4-emmc.dtbo
# ./dtmerge ./mt7988a-bananapi-bpi-r4.dtb mt7988a-bananapi-bpi-r4-sd.dtb ./mt7988a-bananapi-bpi-r4-sd.dtbo
# ls -1 /boot/dtb-6.16.0-rc1-EasyOS-bpi-r4/mediatek/
mt7986a-bananapi-bpi-r3-emmc.dtbo
mt7986a-bananapi-bpi-r3-mini.dtb
mt7986a-bananapi-bpi-r3-nand.dtbo
mt7986a-bananapi-bpi-r3-nor.dtbo
mt7986a-bananapi-bpi-r3-sata.dtbo
mt7986a-bananapi-bpi-r3-sd.dtbo
mt7986a-bananapi-bpi-r3.dtb
mt7988a-bananapi-bpi-r4-2g5.dtb
And here is the GRUB config:
menuentry 'Debian GNU/Linux' --class debian --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-05329a7f-410a-419b-840b-2fde100897cc' {
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root 05329a7f-410a-419b-840b-2fde100897cc
echo 'Loading Linux 6.16.0-rc1-EasyOS-bpi-r4 ...'
linux /boot/vmlinux-6.16.0-rc1-EasyOS-bpi-r4 root=UUID=05329a7f-410a-419b-840b-2fde100897cc ro console=ttyS0,115200n1 earlycon=uart8250,mmio32,0x11000000
echo 'Loading initial ramdisk ...'
initrd /boot/initrd.img-6.16.0-rc1-EasyOS-bpi-r4
echo 'Loading devicetree ...'
devicetree /boot/dtb-6.16.0-rc1-EasyOS-bpi-r4/mediatek/mt7988a-bananapi-bpi-r4-emmc.dtb
And this is the OS:
# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 13 (trixie)"
NAME="Debian GNU/Linux"
VERSION_ID="13"
VERSION="13 (trixie)"
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.0
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
And here is the OS booted with the merged DTBO to DTB with eMMC:
# ls -1 /dev/mmcblk0*
/dev/mmcblk0
/dev/mmcblk0boot0
/dev/mmcblk0boot1
/dev/mmcblk0p1
/dev/mmcblk0p2
/dev/mmcblk0p3
/dev/mmcblk0p4
/dev/mmcblk0p5
/dev/mmcblk0rpmb
I think is enough flexible also the solution U-Boot EFI + GRUB EFI.
Source for dtoverlay can be found here:
ericwoud
(Eric W.)
July 22, 2025, 10:28am
27
I am using the standard Linux commands
fdtoverlay
fdtput
Good tip! Thanks. I will give it a try.
//LE: is working perfect with fdtoverlay. Thanks for this.
rmandrad
(rmandrad)
November 2, 2025, 8:17am
29
@EasyNet you mentioned a script etc do you have a repo I can look at ?
thank you
EasyNet
November 2, 2025, 9:35am
30
Hi @rmandrad ,
Is not yet released. I will try to release it to GitLab.
I’m still working on it.
rmandrad
(rmandrad)
November 2, 2025, 10:33am
31
if you can share anything even if wip that will be great instead of starting from scratch setting up grub/efi
ericwoud
(Eric W.)
November 2, 2025, 12:45pm
32
Are you looking for booting from nvme, or specially using efi?
