as per the following comment on size variable Which documentation is to be referred?
Presumably you know the size of the BAR because that’s fixed by the hardware and documented in the spec. You should do something like this so you don’t depend on what the BAR contains, e.g.,
res->end = res->start + size - 1;
Additionally to the need_fix_device_id and DEVICE_Id I have also added the functions as follows. Size I have currently assume 32 MB. And BAR 0 not assigned is the error.
static void mtk_fixup_bar_size(struct pci_dev *dev)
struct resource *dev_res = &dev->resource[0];
/* 32bit resource length will calculate size to 0, set it smaller */
//dev_res->end = 0xfffffffe;
dev_res->end = dev_res->start + 0x10000000 - 1;
DECLARE_PCI_FIXUP_HEADER(PCI_VENDOR_ID_MEDIATEK, PCI_DEVICE_ID_MEDIATEK_7622, mtk_fixup_bar_size);
Have you tried adding mt7622 to v2 (which is merged to mainline and do not contain the fixup function)? So only trigger the writew with mt7622 device-id
As per the link the function is added in struct mtk_pcie_soc.
Whereas in the 5.4 release that I am working has the function already assigned to .startup struct member when creating the structure object.
However the error still exist
BAR 0: no space for [mem size 0x10000000 64bit pref]
I have observed that in ./kernel/resources.c allocate_resource() is unable to find and request resource. As a Result of which we are getting this error.
There is some issue with the memory range. I am trying to still dig in and understand the memory mapping. In Case you find something related please post.
At boot up when trying to allocate resources OS tries to allocate the resource in 3 attempts in__pci_assign_resource()
First attempt : call pci_bus_alloc_resource() with Flags IORESOURCE_PREFETCH | IORESOURCE_MEM_64
Second Attempt : call pci_bus_alloc_resource() with Flags IORESOURCE_PREFETCH
Third Attempt : Attempt : call pci_bus_alloc_resource() with Flags 0
Only in the 3rd attempt pci_bus_alloc_from_region() calls allocate_resource. It fails as cant find the resource. All this happens when allocating with BAR 0.
However when allocating for BAR 8 the Resource is allocated in first attempt successfully.
Does it have to do anything with 64bit or 32 bit address mapping? Does it have to do something with the initial value of the address map?
Just an update. When the PCI card is inserted on x86 based Laptop, the card works fine.
Do we need to reconfigure the configuration registers on the card so that it should work on ARM based system.
Using setpci like command
@Frank,
Any update from PCI-expert regarding PCI ?
Do you think switching to a different kernel version may help ?
If yes , Can you suggest the kernel version that we can try.
I just have a wondering. The 5.4 version of OS at https://github.com/frank-w/BPI-R2-4.14/tree/5.4-r64-dsa is giving me a indication that this version might have been developed for BPi R2 with base 4.14 kernel version of OS. Hopefully this issue is not arising due to using memory mapping of R2 on R64?
