Yes, but the file I mentioned is corrupted. I’ll have to use an alternative and see if it works, but that will have to wait until tomorrow. It’s 5 AM here.
You do not need ramboot when you can bootup openwrt on emmc…just bootup this system and do the steps for nand from there…but of course you can continue “tomorrow”
But now i understand why you are in openwrt without loading the initramfs itb in uboot manually. That will not work for nand because there is no fixed offset kernel position because of ubifs. But you have emmc running which allows you to create all parts now.
Hello everyone, thank you for the previous explanations and help.
I can confirm that OpenWrt is booting correctly from eMMC, without using ramboot or manually loading the initramfs from U-Boot.
I now understand that since the system is already running from eMMC, the NAND can be prepared directly from within OpenWrt, and there is no need for a fixed kernel offset due to UBI/UBIFS.
Current status:
- OpenWrt 24.10.5 booting from eMMC
- NAND detected (
mtd0: bl2,mtd1: ubi) - UBI is working correctly (
ubinfolooks good, no bad blocks)
Goal:
- Properly prepare the NAND (UBI)
- Create the required volumes (kernel / rootfs / rootfs_data)
- Leave the NAND ready for booting
I would appreciate guidance on the correct steps and recommended volume sizes to prepare the NAND on the R3 Mini.
Thanks in advance for your help.
I’m waiting to find out the next steps.
Just read the next section of the instructions i’ve posted
https://openwrt.org/toh/sinovoip/bananapi_bpi_r3_mini#installation
But just do it from serial and for bl2 se PS with mtd-rw
OpenWrt 24.10.5, r29087-d9c5716d1d
- root@Home2:~# mtd write /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mi ni-snand-preloader.bin /dev/mtd0
- Could not open mtd device: /dev/mtd0
- Can’t open device for writing!
- root@Home2:~#
root@OpenWrt:~# cat /proc/mtd
dev: size erasesize name
mtd0: 00200000 00020000 “bl2”
mtd1: 07e00000 00020000 “ubi”
…for bl2 see PS with mtd-rw
root@Home2:~# cat /proc/mtd
root@Home2:~#
Post is unrelated to my guidance…just recall my information about mapping mtd numbers to partition names
And atill without code tags…
I refer to this section in the openwrt wiki aka PS section
P.S.: in case write to MTD results in error, apply the following:
insmod mtd-rw.ko i_want_a_brick=1
opkg update
opkg install kmod-mtd-rw
insmod mtd-rw i_want_a_brick=1
mtd write archivo.bin bl2
root@Home2:~# opkg update
Downloading https://downloads.openwrt.org/releases/24.10.5/targets/mediatek/filo gic/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_core
Downloading https://downloads.openwrt.org/releases/24.10.5/targets/mediatek/filo gic/packages/Packages.sig
Signature check passed.
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/base/Packages.sig
Downloading https://downloads.openwrt.org/releases/24.10.5/targets/mediatek/filo gic/kmods/6.6.119-1-6a9e125268c43e0bae8cecb014c8ab03/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_kmods
Downloading https://downloads.openwrt.org/releases/24.10.5/targets/mediatek/filo gic/kmods/6.6.119-1-6a9e125268c43e0bae8cecb014c8ab03/Packages.sig
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/luci/Packages.sig
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/packages/Packages.sig
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/routing/Packages.sig
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Downloading https://downloads.openwrt.org/releases/24.10.5/packages/aarch64_cort ex-a53/telephony/Packages.sig
root@Home2:~#
root@Home2:~# opkg install kmod-mtd-rw
Package kmod-mtd-rw (6.6.119.2021.02.28~e8776739-r1) installed in root is up to date.
root@Home2:~# insmod mtd-rw i_want_a_brick=1
root@Home2:~# mtd write archivo.bin bl2
Couldn’t open image file: archivo.bin!
Unlocking /dev/mtd0 …
Writing from /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-snand-preloader.bin to /dev/mtd0 …
root@Home2:~#
root@Home2:~# ubidetach -m 1
root@Home2:~# ubiformat /dev/mtd1
ubiformat: mtd1 (nand), size 132120576 bytes (126.0 MiB), 1008 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 1007 – 100 % complete
ubiformat: 1008 eraseblocks have valid erase counter, mean value is 9
ubiformat: formatting eraseblock 1007 – 100 % complete
root@Home2:~# ubiattach -m 1
UBI device number 0, total 1008 LEBs (127991808 bytes, 122.0 MiB), available 982 LEBs (124690432 bytes, 118.9 MiB), LEB size 126976 bytes (124.0 KiB)
root@Home2:~# volsize=$(wc -c < /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip)
root@Home2:~# ubimkvol /dev/ubi0 -N fip -n 0 -s $volsize -t static
Volume ID 0, size 9 LEBs (1142784 bytes, 1.0 MiB), LEB size 126976 bytes (124.0 KiB), static, name “fip”, alignment 1
root@Home2:~# ubiupdatevol /dev/ubi0_0 /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip
root@Home2:~# cd /lib/firmware/airoha
root@Home2:/lib/firmware/airoha#
root@Home2:/lib/firmware/airoha# cat EthMD32.dm.bin EthMD32.DSP.bin > /tmp/en8811h-fw.bin
root@Home2:/lib/firmware/airoha# ubimkvol /dev/ubi0 -N en8811h-firmware -n 1 -s 147456 -t static
Volume ID 1, size 2 LEBs (253952 bytes, 248.0 KiB), LEB size 126976 bytes (124.0 KiB), static, name “en8811h-firmware”, alignment 1
root@Home2:/lib/firmware/airoha# ubiupdatevol /dev/ubi0_1 /tmp/en8811h-fw.bin
root@Home2:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 2 -N ubootenv -s 126976
Volume ID 2, size 1 LEBs (126976 bytes, 124.0 KiB), LEB size 126976 bytes (124.0 KiB), dynamic, name “ubootenv”, alignment 1
root@Home2:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 3 -N ubootenv2 -s 126976
Volume ID 3, size 1 LEBs (126976 bytes, 124.0 KiB), LEB size 126976 bytes (124.0 KiB), dynamic, name “ubootenv2”, alignment 1
root@Home2:/lib/firmware/airoha# volsize=$(wc -c < /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb)
root@Home2:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 4 -N recovery -s $volsize
Volume ID 4, size 74 LEBs (9396224 bytes, 8.9 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name “recovery”, alignment 1
root@Home2:/lib/firmware/airoha# ubiupdatevol /dev/ubi0_4 /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb
root@Home2:/lib/firmware/airoha# volsize=$(wc -c < /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb)
root@Home2:/lib/firmware/airoha# ubimkvol /dev/ubi0 -n 5 -N fit -s $volsize
Volume ID 5, size 93 LEBs (11808768 bytes, 11.2 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name “fit”, alignment 1
root@Home2:/lib/firmware/airoha# ubiupdatevol /dev/ubi0_5 /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb
Then I restart and this happens
F0: 102B 0000
FA: 1040 0000
FA: 1040 0000 [0200]
F9: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 2400 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [1000]
T0: 0000 0217 [010F]
Jump to BL
NOTICE: BL2: v2.10.0 (release):OpenWrt v2024.01.17~bacca82a-3 (mt7986-spim-nand-ubi-ddr4)
NOTICE: BL2: Built : 21:08:22, Dec 17 2025
NOTICE: WDT: Cold boot
NOTICE: WDT: disabled
NOTICE: CPU: MT7986 (2000MHz)
NOTICE: EMI: Using DDR4 settings
NOTICE: EMI: Detected DRAM size: 2048MB
NOTICE: EMI: complex R/W mem test passed
NOTICE: SPI_NAND parses attributes from parameter page.
NOTICE: SPI_NAND Detected ID 0xef
NOTICE: Page size 2048, Block size 131072, size 134217728
NOTICE: UBI: scanning [0x200000 - 0x8000000] …
NOTICE: UBI: scanning is finished
NOTICE: UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
NOTICE: UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
NOTICE: UBI: Volume fip (Id #0) size is 1127961 bytes
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.10.0 (release):OpenWrt v2024.01.17~bacca82a-3 (mt7986-spim-nand-ubi-ddr4)
NOTICE: BL31: Built : 21:08:22, Dec 17 2025
U-Boot 2024.10-OpenWrt-r29087-d9c5716d1d (Dec 17 2025 - 21:08:22 +0000)
CPU: MediaTek MT7986
Model: Bananapi BPi-R3 Mini
DRAM: 2 GiB
Core: 54 devices, 23 uclasses, devicetree: embed
MMC: mmc@11230000: 0
Loading Environment from UBI… spi-nand: spi_nand spi_nand@0: Winbond SPI NAND was found.
spi-nand: spi_nand spi_nand@0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Read 126976 bytes from volume ubootenv to 00000000bf7c1c00
Read 126976 bytes from volume ubootenv2 to 00000000bf7e0c40
*** Warning - bad CRC, using default environment
In: serial@11002000
Out: serial@11002000
Err: serial@11002000
reset button found
Loading Environment from UBI… UBI partition ‘ubi’ already selected
Net: Volume en8811h-fw not found!
[Airoha] read firmware from UBI failed.
“Synchronous Abort” handler, esr 0x96000004, far 0x110214bfb096c2
elr: 0000000041e59dd0 lr : 0000000041e59dbc (reloc)
elr: 00000000bff31dd0 lr : 00000000bff31dbc
x0 : fffffffffffffffe x1 : 00000000000003e8
x2 : 0000000024040000 x3 : 0000000000000000
x4 : 0000000000000001 x5 : 00000000a4e50000
x6 : 00000000bff2e0a8 x7 : 00000000bfb6a490
x8 : 00000000000016c4 x9 : 00000000bf7ff91c
x10: 0000000000000002 x11: 0000000000000a84
x12: 0000000000000000 x13: 0000000041ee23d0
x14: 00000000ffffffff x15: 00000000bf7ffc28
x16: 00000000bff2e0a8 x17: 0000000000000000
x18: 00000000bf7ffd80 x19: 0000000000000000
x20: 00000000bfb1bad0 x21: 0000000000000000
x22: 0000000000000000 x23: 0000000000004000
x24: 00110214bfb096c2 x25: ffeefdeb404f693e
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 00000000bf7ffb30
Code: 37f80460 91000b38 92800020 cb190019 (39400300)
Resetting CPU …
resetting …
F0: 102B 0000
FA: 1040 0000
F9: 0000 0000
00: 0000 0000
G0: 1190 0000
Jump to BL
NOTICE: WDT: [40000000] Software reset (reboot)
DRAM: 2 GiB
In: serial@11002000
reset button found
Resetting CPU …
resetting …
F0: 102B 0000
FA: 1040 0000
F9: 0000 0000
00: 0000 0000
G0: 1190 0000
Jump to BL
DRAM: 2 GiB
In: serial@11002000
reset button found
Resetting CPU …
resetting …
F0: 102B 0000
FA: 1040 0000
F9: 0000 0000
00: 0000 0000
G0: 1190 0000
Jump to BL
NOTICE: CPU: MT7986 (2002MHz)
DRAM: 2 GiB
In: serial@11002000
reset button found
Resetting CPU …
resetting …
F0: 102B 0000
FA: 1040 0000
F9: 0000 0000
00: 0000 0000
G0: 1190 0000
Jump to BL
DRAM: 2 GiB
In: serial@11002000
reset button found
Resetting CPU …
resetting …
F0: 102B 0000
FA: 1040 0000
F9: 0000 0000
00: 0000 0000
G0: 1190 0000
T0: 0000 0218 [010F]
Jump to BL
Read your error messages and put output in code tags!
For this boot again emmc create this ubi partition (described later in wiki) and flash needed files there.
[quote=“frank-w, post:88, topic:21821”]
[/quote]
root@Home2:~#
root@Home2:~#
It didn’t give any errors this time.
Still same error and still no code tags…
This is what I’m putting and it keeps going in an infinite loop.
opkg update
mtd write /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-snand-preloader.bin /dev/mtd0
ubidetach -m 1
ubiformat /dev/mtd1
ubiattach -m 1
You are right — that error is expected.
archivo.bin was only a placeholder in the example.
The real command I used (and that works) is:
mtd write /tmp/openwrt-24.10.5-mediatek-filogic-bananapi_bpi-r3-mini-snand-preloader.bin bl2
After loading kmod-mtd-rw and running:
the write to the bl2 partition succeeds.
So the error shown above is simply because the file archivo.bin
does not exist, not because of an MTD or permission issue.
Thanks for pointing out the importance of mapping MTD names correctly and for the reminder about using code tags.
But you still not follow it…
For the crash you have to flash the phy firmware to the right ubi volume…
Followed by
ubimkvol /dev/ubi0 -N en8811h-fw -n 1 -s 147456 -t static
Possibly you have to delete partition 1 if you created with the other name before doing above commands
ubirmvol /dev/ubi0 -N en8811h-firmware
Solved: U-Boot loop caused by wrong EN8811H UBI volume name
The issue was not a broken NAND, OpenWrt bug, or temporary firmware loss.
The boot loop and crash:
Synchronous Abort
were caused by a wrong UBI volume name for the EN8811H PHY firmware.
I originally created the volume as:
en8811h-firmware
but U-Boot 24.10.x expects the volume name to be exactly:
en8811h-fw
Because of this mismatch, U-Boot could not load the PHY firmware and crashed during early boot.
Fix (booted into OpenWrt with NAND selected)
ubirmvol /dev/ubi0 -N en8811h-firmware 2>/dev/null
sync
reboot
Result
- U-Boot successfully loads the EN8811H PHY firmware
- Boot loop is gone
- System boots normally from NAND
- NAND and eMMC are both in a good state
Root cause: incorrect UBI volume name for the PHY firmware.
Now the NAND and eMMC are working. I’d like it to have the 8GB on the eMMC
What should I do now?
Hi everyone,
I’m trying to get 2.5Gb/s speed on my BPI-R3 Mini running OpenWrt 24.10.5.
- PHY: Airoha EN8811H
- Driver:
mtk_soc_eth - Using Cat8 cables
- Connected to a 2.5Gb/s switch
Right now, the link only reaches 1Gb/s, even though the hardware supports 2.5Gb/s. I tried using ethtool to force it, but it still shows 1Gb/s.
Has anyone successfully enabled 2.5Gb/s on the EN8811H with OpenWrt? Is there a driver update or workaround?
Any help or guidance would be greatly appreciated!
For 8gb there are many threads for each board…just read there. It is not recommended to increase rootfs to 8gb because it may break sysupgrade. Add an additional partition and mount it for data.
For speed 2500 i have no idea, you can look with ethtool what is advertised local and from remote side…
opkg update
opkg install ethtool
ethtool eth0
ethtool eth1
ethtool -i eth0
ethtool -i eth1
#!/bin/sh
Script para diagnosticar la negociación 2.5G en BPI-R3 Mini
echo “=== STATUS ACTUAL DE ETH0 ===”
ethtool eth0
echo “=== STATUS ACTUAL DE ETH1 ===”
ethtool eth1
echo “=== ADVERTISED Y LINK PARTNER INFO ===”
echo “— ETH0 —”
ethtool -a eth0
ethtool -i eth0
echo “— ETH1 —”
ethtool -a eth1
ethtool -i eth1
echo “=== FORZAR AUTONEGOCIACIÓN y MODO 2.5G ===”
echo “Intentando autoneg on, advertir 2.5G…”
ip link set eth0 down
ethtool -s eth0 autoneg on advertise 0x80000000002
ip link set eth0 up
ip link set eth1 down
ethtool -s eth1 autoneg on advertise 0x80000000002
ip link set eth1 up
echo “=== NUEVO STATUS DESPUÉS DE INTENTO ===”
ethtool eth0 | grep -i speed
ethtool eth1 | grep -i speed
echo “=== PHY LOGS RECIENTES ===”
dmesg | tail -n 30 | grep -i en8811h
