Have you tried the patch i suggested (using different top clock)? Which kernel (5.15 vs. 6.1).
I thought this patch was included in the last snapshot. Should I build an image with the patch? Otherwise the kernel is 5.15.126.
No, we have to know first if it solves your issueā¦have you tried kernel 6.1?
How to try kernel 6.1? master is 5.15.
Same problem here with the RC3
And i donāt know how to build a firmware, so even less how to apply a patch
You mean PWM doesnāt work for you either. Right?
5.15 is known not working
I guess because backported pwm/clock support is different to mainline
The pwm node i upstreamed works for me in mainline kernel without openwrt. So we need someone who can test pwm with openwrt with kernel 6.1 which (hopefully) does not have any openwrt-specific backports for r3
The fan start runing when i boot the BPI, after 10/15 seconds it stop. i can start/stop the fan by sending some echo commands, so i donāt know if it is runing as expected, i mean starting alone when the temp is high.
Hi @frank-w, I can change the clock in 5.15 dts, but I need some instructions? Do I have to build new image?
Iām experienced in Linux.
Yes you have to build openwrt from code and stop after patches are applied and then change the clock in dts and continue build-process. I do not know openwrt build tools enough if this is possible without adding an own patch file in the folder structure
Maybe @dangowrt can explain steps? Or maybe test this and add the patch?
Try
echo 2 > /sys/class/thermal/cooling_device0/cur_state
Does it turn on the fan? Can you post your boot log?
@Dale Nope. It does not start.
And some more info:
root@openwrt:~# cat /sys/kernel/debug/pwm
platform/10048000.pwm, 2 PWM devices
pwm-0 (pwm-fan ): requested enabled period: 10000 ns duty: 9999 ns polarity: normal
pwm-1 ((null) ): period: 0 ns duty: 0 ns polarity: normal
Can you run the same command right after you run the command I suggested?
yes, it turns about 5s and stop.
I use openwrt 23.05.0 RC3 with kernel 5.15.127
Then you have no problem, the thing is the trip points has changed and the fan will only start at 85c⦠it has to be changed
Do you use snapshot or 23-rc?
i did it already and the fan turns indefinitly (i think)
@frank-w , as you can see this guy has the pwm clk error on boot log and it still works for him. Perhaps the init has retries? I havenāt looked at the code
