Banana Pi BPI-W3 with Rockchip RK3588 ,8G DDR and 32G eMMC flash
Banana%20Pi%20BPI-W3%20LGA%2010
The Banana Pi BPI-W3 is a router based development board, it design with Rochchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor. ,6Tops@INT8 NPU,8G memory,32G eMMC storage on board .which can run on a variety of open source operating systems including OpenWrt, Android, and linux. It has 1 Gigabit LAN ports, 1 Gigabit WAN., it also with 2 HDMI out and 1 HDMI in port.
Banana%20Pi%20BPI-W3%201
Key Features:
Rockchip RK3588 quad ARM Cortex-A76 and quad Cortex-A55 consists of an eight-core CPU processor
  • ARM Mali-G610 MP4,
  • NPU for AI : 6Tops@INT8
  • 8G RAM and 32G eMMC flash onbord
  • support HDMI in and HDMI out
Hardware interface:
Banana%20Pi%20BPI-W3%20interface
Banana Pi BPI-W3 base on BPI-RK3588 Core board and development Kit use BPI-RK3588-LGA core board. so you can easy to do new design with BPI-W3, just need to development a new base board.
Banana%20Pi%20BPI-RK3588-LGA%201
Banana Pi BPi-W3 RK3588 open source board Review
wiki online documents : https://wiki.banana-pi.org/Banana_Pi_BPI-W3
When will the product be available?
you can contace [email protected] to order sample
Really like the look of that board for all sorts of low energy server based applications. Please ditch the onboard switches and just plain old jumpers that can also be wired switches like a server mobo. If its at the right price that is definitely looking like a great server board with many applications.
Are BOTH Ethernet ports working and tested ?
I guess only hardware is available for internal testing yet. There are some patches on mailinglist for rk3588,afair ethernet too (they should not differ much from rk356x). So i see no big problem here…compared to mtk boards gmacs are 1g only (not bad here because only 1 port per gmac).
Only 1 lan is working as the other one is using pcie2. So we will have to wait for pcie bringup for rk3588
as far as i found out there are 2 variants of rk3588…one rk3588S with only pcie2 and one rk3588 (without letter) having pcie3x4 which seems the case here…so we need support in pcie3 driver for rk3588…imho it was partially available (but had not tested it due missing hardware) and maybe needs only compatible (which afair i have removed when sending driver upstream).
Banana Pi BPI-W3 (RK3588) local video play 8K with gstreamer , not mpv (debian 11):
Negs ot pcie3 working on rk3588 already i didn’t get time to test it myself but he is already working on it.
Thanks to you pcie3 patch.
So far I have only tested 2 rk3588 boards with 1 rk3588s and both can boot with upstream kernel and have sdcard, emmc, lan and uart support only.
Banana Pi BPI-W3 RK3588 dual hdmi display and dual hdmi display + hdim in function test
Are you going to share base board schematics?
yes , have update to wiki page ,you can download frome wiki page
https://wiki.banana-pi.org/Banana_Pi_BPI-W3#Documents
Banana Pi BPI-W3 with Rockchip RK3588 board Public sale,8GB RAM and 32GB eMMC
Banana Pi BPI-W3 SBC features Rockchip RK3588 SoM, M.2 NVMe socket, 2.5GbE, HDMI output and input
#sbc #bananapi #RK3588 #bananapi #orangepi #RaspberryPi
Do you know what software do I need to inspect the schematics of the Banana pi BPI-W3 ? In particular I’m interested in how to view the schematics of the carrier board and the pinout of the stamp board (core)
You mean this file from wiki? Banana Pi BPI-W3 base board 1V1 SCH.pdf - Google Drive
This is a pdf and can be viewed dirctly in google drive or downloaded and openwd with every pdf reader e.g. adobe acrobat reader
Talking about the .pcb files , .dxf files and .asc files that are inside the RAR archive in google drive, link on the wiki.
