gpio-issue solved so far…gpio was blocked by activated i2c1…so if the special-function is enabled in dts, the direct gpio-access is blocked
How did you deactivate i2c?
But that doesn’t work for PWM. Changing the status to disable I have all the same error
[ 56.553047] mt7622-pinctrl 10211000.pinctrl: pin PWM7 already requested by 11006000.pwm; cannot claim for pinctrl_moore:510 [ 56.564211] mt7622-pinctrl 10211000.pinctrl: pin-101 (pinctrl_moore:510) status -22
maybe you need this:
Am I understanding correctly that the SATA and mPCIe (CN8 or CN25?) cannot both be used at the same time?
According to https://wiki.banana-pi.org/Getting_Started_with_R64#Sata needs echo 0 > /sys/class/gpio/gpio499/value while mPCIe (CN8 or CN25?) need echo 1 > /sys/class/gpio/gpio499/value which are opposing.
This would mean that it can’t do both WAN AND SATA at the same time? Or is CN8 the correct mPCIe port for WAN? Was CN25 meant for mPCIe SSD?
Also, I assume that the PoE module needs to be soldered on to the BPi-R64 board. Does this supply power to the ethernet ports, or only allow the board to be powered by the WAN port?
You can use PCIE1/cn8 or SATA by switching GPIO90 via gpio-hog (asm_sel) in dts,so it is blocked in userspace
Has anyone tried to attach multiple AX card like MT7915 non DBDC? or should i choose bpi-r3 route and add m.2 AX card? planning to make tri-radio AP.
thanks
