Hi found one think. On previous firmware internet appear when appear lusi network interface, but now internet appear after 1 or 2 minute. This is my system log:
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043030000-0x000000007fffffff]
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.000000] On node 0 totalpages: 262144
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.000000]   DMA zone: 4096 pages used for memmap
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.000000]   DMA zone: 0 pages reserved
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.000000]   DMA zone: 262144 pages, LIFO batch:63
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] psci: probing for conduit method from DT.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] psci: PSCIv1.1 detected in firmware.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] psci: SMC Calling Convention v1.2
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] percpu: Embedded 20 pages/cpu s44632 r8192 d29096 u81920
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.000000] pcpu-alloc: s44632 r8192 d29096 u81920 alloc=20*4096
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] Detected VIPT I-cache on CPU0
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] CPU features: detected: ARM erratum 845719
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] CPU features: detected: ARM erratum 843419
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x11002000 console=ttyS0,115200n1 swiotlb=512 root=/dev/mmcblk0p5
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] Memory: 1016440K/1048576K available (7742K kernel code, 866K rwdata, 2188K rodata, 448K init, 303K bss, 32136K reserved, 0K cma-reserved)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Sat Jan  1 00:00:07 2000 kern.warn kernel: [    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x340/0x48c with crng_init=0
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.000003] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.008501] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=50000)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.019142] pid_max: default: 32768 minimum: 301
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.024022] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.031693] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.040791] rcu: Hierarchical SRCU implementation.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.045887] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.054155] smp: Bringing up secondary CPUs ...
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.059174] Detected VIPT I-cache on CPU1
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.059224] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.059292] smp: Brought up 1 node, 2 CPUs
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.074452] SMP: Total of 2 processors activated.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.079323] CPU features: detected: 32-bit EL0 Support
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.084645] CPU features: detected: CRC32 instructions
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.090085] CPU: All CPU(s) started at EL2
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.094334] alternatives: patching kernel code
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.102326] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.112452] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.119570] pinctrl core: initialized pinctrl subsystem
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.125791] NET: Registered protocol family 16
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.130856] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.138219] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.146266] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.154794] thermal_sys: Registered thermal governor 'fair_share'
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.154803] thermal_sys: Registered thermal governor 'bang_bang'
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.161141] thermal_sys: Registered thermal governor 'step_wise'
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.167371] thermal_sys: Registered thermal governor 'user_space'
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.173885] ASID allocator initialised with 65536 entries
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.206220] gpio-499 (asm_sel): hogged as output/high
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    0.224536] SCSI subsystem initialized
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.228721] libata version 3.00 loaded.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.232995] usbcore: registered new interface driver usbfs
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.238782] usbcore: registered new interface driver hub
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.244337] usbcore: registered new device driver usb
Sat Jan  1 00:00:07 2000 kern.warn kernel: [    0.250199] workqueue: max_active 576 requested for napi_workq is out of range, clamping between 1 and 512
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.261620] clocksource: Switched to clocksource arch_sys_counter
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.268671] NET: Registered protocol family 2
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.273769] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.282471] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.290546] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.298136] TCP: Hash tables configured (established 8192 bind 8192)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.304846] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.311728] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.319166] NET: Registered protocol family 1
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.323700] PCI: CLS 0 bytes, default 64
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.328920] workingset: timestamp_bits=46 max_order=18 bucket_order=0
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.338430] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.344490] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.387655] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Sat Jan  1 00:00:07 2000 kern.err kernel: [    0.395856] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
Sat Jan  1 00:00:07 2000 kern.err kernel: [    0.407614] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.422488] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.431316] printk: console [ttyS0] disabled
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.435845] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 23, base_baud = 1562500) is a 16550A
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.445071] printk: console [ttyS0] enabled
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.453445] printk: bootconsole [uart8250] disabled
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.463891] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 24, base_baud = 1562500) is a 16550A
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.473707] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 30, base_baud = 17499995) is a MediaTek BTIF
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.483436] serial serial0: tty port ttyS2 registered
Sat Jan  1 00:00:07 2000 kern.warn kernel: [    0.488936] cacheinfo: Unable to detect cache hierarchy for CPU 0
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.498505] loop: module loaded
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.501678] Loading iSCSI transport class v2.0-870.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.510303] libphy: Fixed MDIO Bus: probed
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.538207] libphy: mdio: probed
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.542390] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc0119e0000, irq 39
Sat Jan  1 00:00:07 2000 kern.err kernel: [    0.551507] mtk_soc_eth 1b100000.ethernet: generated random MAC address aa:54:cd:70:d1:42
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.560030] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc0119e0000, irq 39
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.571035] rtc_mt7622 10212800.rtc: registered as rtc0
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.576335] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.586480] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.597906] mtk-msdc 11240000.mmc: Got CD GPIO
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.597976] NET: Registered protocol family 10
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.607677] Segment Routing with IPv6
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.611417] NET: Registered protocol family 17
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.615909] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.629166] 8021q: 802.1Q VLAN Support v1.8
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.643635] mtk-pcie 1a143000.pcie: host bridge /pcie@1a143000 ranges:
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.650211] mtk-pcie 1a143000.pcie: Parsing ranges property...
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.656054] mtk-pcie 1a143000.pcie:      MEM 0x0020000000..0x0027ffffff -> 0x0020000000
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.704171] mtk-msdc 11230000.mmc: phase: [map:fffffff] [maxlen:28] [final:9]
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.712415] mmc0: new HS200 MMC card at address 0001
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.718642] mmcblk0: mmc0:0001 008G30 7.28 GiB
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.724131] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.731090] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.737107] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (249:0)
Sat Jan  1 00:00:07 2000 kern.warn kernel: [    0.746814] Alternate GPT is invalid, using primary GPT.
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.752965] FIT: volume size: 2007040 sectors (1027604480 bytes)
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.758979] FIT: FDT structure size: 4096 bytes
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.763535] FIT: Default configuration: config-1 (OpenWrt bananapi_bpi-r64)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.764346] mtk-pcie 1a143000.pcie: Port0 link down
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.770505] FIT:           kernel sub-image 0x00001000 - 0x004ddddb 'kernel-1' (ARM64 OpenWrt Linux-5.10.20)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.775582] mtk-pcie 1a143000.pcie: PCI host bridge to bus 0000:00
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.785289] FIT:          flat_dt sub-image 0x004de000 - 0x004e420d 'fdt-1' (ARM64 OpenWrt bananapi_bpi-r64 device tree blob)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.791464] pci_bus 0000:00: root bus resource [bus 00-ff]
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.802846] FIT:       filesystem sub-image 0x004e5000 - 0x0090a000 'rootfs-1' (ARM64 OpenWrt bananapi_bpi-r64 rootfs)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.808314] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff]
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.819092] FIT: selecting configured loadable rootfs-1 to be root filesystem
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.825951] pci_bus 0000:00: scanning bus
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.833095]  mmcblk0: p1 p2 p3 p4 p5(rootfs-1) p6(rootfs_data) p130
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.838303] pci_bus 0000:00: fixups for bus
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.847538] pci_bus 0000:00: bus scan returning with max=00
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.853667] mtk-pcie 1a145000.pcie: host bridge /pcie@1a145000 ranges:
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.860234] mtk-pcie 1a145000.pcie: Parsing ranges property...
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.866076] mtk-pcie 1a145000.pcie:      MEM 0x0028000000..0x002fffffff -> 0x0028000000
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.974271] mtk-pcie 1a145000.pcie: Port1 link down
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.979288] mtk-pcie 1a145000.pcie: PCI host bridge to bus 0001:00
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.985484] pci_bus 0001:00: root bus resource [bus 00-ff]
Sat Jan  1 00:00:07 2000 kern.info kernel: [    0.990971] pci_bus 0001:00: root bus resource [mem 0x28000000-0x2fffffff]
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    0.997842] pci_bus 0001:00: scanning bus
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.003071] pci_bus 0001:00: fixups for bus
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.007256] pci_bus 0001:00: bus scan returning with max=00
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.013188] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.021480] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.066239] libphy: dsa slave smi: probed
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.071175] mt7530 mdio-bus:00 wan (uninitialized): PHY [dsa-0.0:00] driver [Generic PHY] (irq=POLL)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.081746] mt7530 mdio-bus:00 lan1 (uninitialized): PHY [dsa-0.0:01] driver [Generic PHY] (irq=POLL)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.092379] mt7530 mdio-bus:00 lan2 (uninitialized): PHY [dsa-0.0:02] driver [Generic PHY] (irq=POLL)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.103031] mt7530 mdio-bus:00 lan3 (uninitialized): PHY [dsa-0.0:03] driver [Generic PHY] (irq=POLL)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.113685] mt7530 mdio-bus:00 lan4 (uninitialized): PHY [dsa-0.0:04] driver [Generic PHY] (irq=POLL)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.123978] mt7530 mdio-bus:00: configuring for fixed/2500base-x link mode
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.131565] mt7530 mdio-bus:00: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.132225] DSA: tree 0 setup
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.142683] xhci-mtk 1a0c0000.usb: xHCI Host Controller
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.147965] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.157023] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.166123] xhci-mtk 1a0c0000.usb: irq 35, io mem 0x1a0c0000
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.172289] hub 1-0:1.0: USB hub found
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.176092] hub 1-0:1.0: 2 ports detected
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.180382] xhci-mtk 1a0c0000.usb: xHCI Host Controller
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.185635] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.193044] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.199360] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.207780] hub 2-0:1.0: USB hub found
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.211576] hub 2-0:1.0: 1 port detected
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.220317] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.227669] Freeing unused kernel memory: 448K
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.237733] Run /sbin/init as init process
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.241831]   with arguments:
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.244789]     /sbin/init
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.247490]   with environment:
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.250624]     HOME=/
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    1.252974]     TERM=linux
Sat Jan  1 00:00:07 2000 user.info kernel: [    1.400286] init: Console is alive
Sat Jan  1 00:00:07 2000 user.info kernel: [    1.403838] init: - watchdog -
Sat Jan  1 00:00:07 2000 user.info kernel: [    1.603197] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.647637] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.654932] ehci-fsl: Freescale EHCI Host controller driver
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.661337] ehci-platform: EHCI generic platform driver
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.668471] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.675366] ohci-platform: OHCI generic platform driver
Sat Jan  1 00:00:07 2000 user.info kernel: [    1.683194] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Sat Jan  1 00:00:07 2000 user.info kernel: [    1.699607] init: - preinit -
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    1.861867] random: fast init done
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.949194] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.957613] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.975175] mt7530 mdio-bus:00 lan1: configuring for phy/gmii link mode
Sat Jan  1 00:00:07 2000 kern.info kernel: [    1.982341] 8021q: adding VLAN 0 to HW filter on device lan1
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    1.996776] random: procd: uninitialized urandom read (4 bytes read)
Sat Jan  1 00:00:07 2000 kern.info kernel: [    5.047456] mt7530 mdio-bus:00 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Sat Jan  1 00:00:07 2000 kern.info kernel: [    5.054978] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.066760] mount_root: loading kmods from internal overlay
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.077338] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.084565] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.274381] block: attempting to load /etc/config/fstab
Sat Jan  1 00:00:07 2000 user.err kernel: [    6.281517] block: unable to load configuration (fstab: Entry not found)
Sat Jan  1 00:00:07 2000 user.err kernel: [    6.288342] block: no usable configuration
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    6.450613] F2FS-fs (mmcblk0p6): Mounted with checkpoint version = 250188f1
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.459516] mount_root: loading kmods from internal overlay
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.469526] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.478982] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.573264] block: attempting to load /etc/config/fstab
Sat Jan  1 00:00:07 2000 user.err kernel: [    6.578612] block: unable to load configuration (fstab: Entry not found)
Sat Jan  1 00:00:07 2000 user.err kernel: [    6.585336] block: no usable configuration
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.591013] mount_root: switching to f2fs overlay
Sat Jan  1 00:00:07 2000 kern.info kernel: [    6.598736] overlayfs: "xino" feature enabled using 32 upper inode bits.
Sat Jan  1 00:00:07 2000 kern.err kernel: [    6.624101] /dev/mmcblk0p6: Can't open blockdev
Sat Jan  1 00:00:07 2000 user.debug kernel: [    6.633955] urandom-seed: Seeding with /etc/urandom.seed
Sat Jan  1 00:00:07 2000 kern.info kernel: [    6.674915] mt7530 mdio-bus:00 lan1: Link is Down
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.685978] procd: - early -
Sat Jan  1 00:00:07 2000 user.info kernel: [    6.688898] procd: - watchdog -
Sat Jan  1 00:00:07 2000 user.info kernel: [    7.228458] procd: - watchdog -
Sat Jan  1 00:00:07 2000 user.info kernel: [    7.232525] procd: - ubus -
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    7.258547] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    7.285821] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    7.303091] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Jan  1 00:00:07 2000 user.info kernel: [    7.310685] procd: - init -
Sat Jan  1 00:00:07 2000 user.info kernel: [    7.562979] urngd: v1.0.2 started.
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    7.596986] random: crng init done
Sat Jan  1 00:00:07 2000 kern.notice kernel: [    7.600432] random: 6 urandom warning(s) missed due to ratelimiting
Sat Jan  1 00:00:07 2000 user.info kernel: [    7.676626] kmodloader: loading kernel modules from /etc/modules.d/*
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.764072] Loading modules backported from Linux version v5.10.16-0-gde53befa79cf
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.771757] Backport generated by backports.git v5.10.16-1-0-g21d2a1d2
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.825969] xt_time: kernel timezone is -0000
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.866827] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 7a:df:27:46:25:bb
Sat Jan  1 00:00:07 2000 kern.debug kernel: [    7.877249] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.893052] PPP generic driver version 2.4.2
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.898213] NET: Registered protocol family 24
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.908845] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
Sat Jan  1 00:00:07 2000 user.info kernel: [    7.935457] kmodloader: done loading kernel modules from /etc/modules.d/*
Sat Jan  1 00:00:07 2000 kern.info kernel: [    7.974816] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
Sat Jan  1 00:00:08 2000 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sat Jan  1 00:00:08 2000 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: Connected to system UBus
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: started, version 2.84 cachesize 150
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: DNS service limited to local subnets
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: UBus support enabled: connected to system bus
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: using only locally-known addresses for domain test
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: using only locally-known addresses for domain onion
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: using only locally-known addresses for domain localhost
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: using only locally-known addresses for domain invalid
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: using only locally-known addresses for domain bind
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: using only locally-known addresses for domain lan
Sat Jan  1 00:00:08 2000 daemon.warn dnsmasq[1490]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: read /etc/hosts - 4 addresses
Sat Jan  1 00:00:08 2000 daemon.info dnsmasq[1490]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Sat Jan  1 00:00:08 2000 authpriv.info dropbear[1557]: Not backgrounding
Sat Jan  1 00:00:09 2000 daemon.notice wpa_supplicant[1685]: Successfully initialized wpa_supplicant
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: 8021ad
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: 8021q
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: macvlan
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: veth
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: bridge
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: Network device
Sat Jan  1 00:00:09 2000 user.notice : Added device handler type: tunnel
Sat Jan  1 00:00:09 2000 daemon.notice procd: /etc/rc.d/S50uhttpd: 4+0 records in
Sat Jan  1 00:00:09 2000 daemon.notice procd: /etc/rc.d/S50uhttpd: 4+0 records out
Sat Jan  1 00:00:09 2000 daemon.debug dnsmasq[1490]: stopped listening on eth0(#2): fe80::1001:45ff:fe43:418d%eth0 port 53
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.228827] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.238905] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.247361] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.250580] mt7530 mdio-bus:00 lan1: configuring for phy/gmii link mode
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.267517] 8021q: adding VLAN 0 to HW filter on device lan1
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Successfully dropped root privileges.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: avahi-daemon 0.8 starting up.
Sat Jan  1 00:00:09 2000 daemon.warn avahi-daemon[1997]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.281890] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.288591] br-lan: port 1(lan1) entered blocking state
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.293894] br-lan: port 1(lan1) entered disabled state
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: No service file found in /etc/avahi/services.
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.302363] device lan1 entered promiscuous mode
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.307063] device eth0 entered promiscuous mode
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::1001:45ff:fe43:418d.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: New relevant interface eth0.IPv6 for mDNS.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Network interface enumeration completed.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Registering new address record for fe80::1001:45ff:fe43:418d on eth0.*.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Registering HINFO record with values 'AARCH64'/'LINUX'.
Sat Jan  1 00:00:09 2000 daemon.notice netifd: Interface 'lan' is enabled
Sat Jan  1 00:00:09 2000 daemon.notice netifd: Interface 'lan' is setting up now
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface br-lan.IPv4 with address 192.168.1.1.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: New relevant interface br-lan.IPv4 for mDNS.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Registering new address record for 192.168.1.1 on br-lan.IPv4.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface br-lan.IPv6 with address fd06:9b3c:a457::1.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: New relevant interface br-lan.IPv6 for mDNS.
Sat Jan  1 00:00:09 2000 daemon.info avahi-daemon[1997]: Registering new address record for fd06:9b3c:a457::1 on br-lan.*.
Sat Jan  1 00:00:09 2000 daemon.notice netifd: Interface 'lan' is now up
Sat Jan  1 00:00:09 2000 daemon.debug dnsmasq[1490]: listening on br-lan(#10): 192.168.1.1 port 53
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.327724] mt7530 mdio-bus:00 lan2: configuring for phy/gmii link mode
Sat Jan  1 00:00:09 2000 kern.info kernel: [   10.345230] 8021q: adding VLAN 0 to HW filter on device lan2
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.356699] br-lan: port 2(lan2) entered blocking state
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.362021] br-lan: port 2(lan2) entered disabled state
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.368715] device lan2 entered promiscuous mode
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.382872] mt7530 mdio-bus:00 lan3: configuring for phy/gmii link mode
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.394502] 8021q: adding VLAN 0 to HW filter on device lan3
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.403502] br-lan: port 3(lan3) entered blocking state
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.408798] br-lan: port 3(lan3) entered disabled state
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.415433] device lan3 entered promiscuous mode
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.426924] mt7530 mdio-bus:00 lan4: configuring for phy/gmii link mode
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.440367] 8021q: adding VLAN 0 to HW filter on device lan4
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.451818] br-lan: port 4(lan4) entered blocking state
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.457126] br-lan: port 4(lan4) entered disabled state
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.463507] device lan4 entered promiscuous mode
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: New relevant interface lo.IPv4 for mDNS.
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'loopback' is enabled
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'loopback' is setting up now
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: New relevant interface lo.IPv6 for mDNS.
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: Registering new address record for ::1 on lo.*.
Sat Jan  1 00:00:10 2000 daemon.debug dnsmasq[1490]: listening on lo(#1): 127.0.0.1 port 53
Sat Jan  1 00:00:10 2000 daemon.debug dnsmasq[1490]: listening on lo(#1): ::1 port 53
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'loopback' is now up
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.475130] mt7530 mdio-bus:00 wan: configuring for phy/gmii link mode
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.482280] 8021q: adding VLAN 0 to HW filter on device wan
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.491261] mt7530 mdio-bus:00 wan: Link is Up - 100Mbps/Full - flow control off
Sat Jan  1 00:00:10 2000 kern.info kernel: [   10.500810] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'wan' is enabled
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Network device 'eth0' link is up
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Network device 'lo' link is up
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'loopback' has link connectivity
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Network device 'wan' link is up
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'wan' is setting up now
Sat Jan  1 00:00:10 2000 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Sat Jan  1 00:00:10 2000 daemon.notice netifd: wan (2164): udhcpc: started, v1.33.0
Sat Jan  1 00:00:10 2000 daemon.notice netifd: wan (2164): udhcpc: sending discover
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Sat Jan  1 00:00:10 2000 daemon.notice netifd: wan (2164): udhcpc: sending select for 192.168.100.2
Sat Jan  1 00:00:10 2000 daemon.notice netifd: wan (2164): udhcpc: lease of 192.168.100.2 obtained, lease time 122
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface wan.IPv4 with address 192.168.100.2.
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: New relevant interface wan.IPv4 for mDNS.
Sat Jan  1 00:00:10 2000 daemon.info avahi-daemon[1997]: Registering new address record for 192.168.100.2 on wan.IPv4.
Sat Jan  1 00:00:10 2000 daemon.debug dnsmasq[1490]: listening on wan(#4): 192.168.100.2 port 53
Sat Jan  1 00:00:10 2000 daemon.notice netifd: Interface 'wan' is now up
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Sat Jan  1 00:00:10 2000 user.notice firewall: Reloading firewall due to ifup of wan (wan)
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Sat Jan  1 00:00:10 2000 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Sat Jan  1 00:00:11 2000 daemon.info procd: - init complete -
Sat Jan  1 00:00:11 2000 daemon.info avahi-daemon[1997]: Server startup complete. Host name is OpenWrt.local. Local service cookie is 3653281885.
Sat Jan  1 00:00:11 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface wan.IPv6 with address fe80::1001:45ff:fe43:418d.
Sat Jan  1 00:00:11 2000 daemon.info avahi-daemon[1997]: New relevant interface wan.IPv6 for mDNS.
Sat Jan  1 00:00:11 2000 daemon.info avahi-daemon[1997]: Registering new address record for fe80::1001:45ff:fe43:418d on wan.*.
Sat Jan  1 00:00:11 2000 daemon.debug dnsmasq[1490]: listening on wan(#4): fe80::1001:45ff:fe43:418d%wan port 53
Sat Jan  1 00:00:11 2000 daemon.err odhcpd[1791]: Failed to send to ff02::1%lan@br-lan (Address not available)
Sat Jan  1 00:00:11 2000 daemon.err nmbd[2534]: [2000/01/01 00:00:11.445340,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
Sat Jan  1 00:00:11 2000 daemon.err nmbd[2534]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Sat Jan  1 00:00:11 2000 daemon.err smbd[2533]: [2000/01/01 00:00:11.564568,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
Sat Jan  1 00:00:11 2000 daemon.err smbd[2533]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Sat Jan  1 00:00:11 2000 daemon.err smbd[2533]: [2000/01/01 00:00:11.565072,  0] ../../source3/smbd/server.c:1077(smbd_open_one_socket)
Sat Jan  1 00:00:11 2000 daemon.err smbd[2533]:   smbd_open_one_socket: open_socket_in: Address not available
Sat Jan  1 00:00:11 2000 daemon.err smbd[2533]: [2000/01/01 00:00:11.565301,  0] ../../source3/smbd/server.c:1077(smbd_open_one_socket)
Sat Jan  1 00:00:11 2000 daemon.debug dnsmasq[1490]: listening on eth0(#2): fe80::1001:45ff:fe43:418d%eth0 port 53
Sat Jan  1 00:00:12 2000 kern.info kernel: [   13.335443] mt7530 mdio-bus:00 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Sat Jan  1 00:00:12 2000 kern.info kernel: [   13.342974] br-lan: port 1(lan1) entered blocking state
Sat Jan  1 00:00:12 2000 kern.info kernel: [   13.348208] br-lan: port 1(lan1) entered forwarding state
Sat Jan  1 00:00:12 2000 daemon.notice netifd: Network device 'lan1' link is up
Sat Jan  1 00:00:13 2000 kern.info kernel: [   13.354335] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Sat Jan  1 00:00:13 2000 daemon.notice netifd: bridge 'br-lan' link is up
Sat Jan  1 00:00:13 2000 daemon.notice netifd: Interface 'lan' has link connectivity
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[1490]: exiting on receipt of SIGTERM
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: Connected to system UBus
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: started, version 2.84 cachesize 150
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: DNS service limited to local subnets
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: UBus support enabled: connected to system bus
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq-dhcp[2820]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain test
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain onion
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain localhost
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain invalid
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain bind
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain lan
Sat Jan  1 00:00:13 2000 daemon.warn dnsmasq[2820]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: read /etc/hosts - 4 addresses
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq[2820]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Jan  1 00:00:13 2000 daemon.info dnsmasq-dhcp[2820]: read /etc/ethers - 0 addresses
Sat Jan  1 00:00:14 2000 daemon.err odhcpd[1791]: Failed to send to ff02::1%lan@br-lan (Address not available)
Sat Jan  1 00:00:14 2000 daemon.info dnsmasq[2820]: read /etc/hosts - 4 addresses
Sat Jan  1 00:00:14 2000 daemon.info dnsmasq[2820]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Jan  1 00:00:14 2000 daemon.info dnsmasq-dhcp[2820]: read /etc/ethers - 0 addresses
Sat Jan  1 00:00:14 2000 daemon.debug dnsmasq[2820]: listening on br-lan(#10): fe80::1001:45ff:fe43:418d%br-lan port 53
Sat Jan  1 00:00:14 2000 daemon.debug dnsmasq[2820]: listening on br-lan(#10): fd06:9b3c:a457::1 port 53
Sat Jan  1 00:00:22 2000 daemon.info dnsmasq[2820]: read /etc/hosts - 4 addresses
Sat Jan  1 00:00:22 2000 daemon.info dnsmasq[2820]: read /tmp/hosts/odhcpd - 0 addresses
Sat Jan  1 00:00:22 2000 daemon.info dnsmasq[2820]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Jan  1 00:00:22 2000 daemon.info dnsmasq-dhcp[2820]: read /etc/ethers - 0 addresses
Sat Jan  1 00:00:23 2000 daemon.info dnsmasq[2820]: read /etc/hosts - 4 addresses
Sat Jan  1 00:00:23 2000 daemon.info dnsmasq[2820]: read /tmp/hosts/odhcpd - 1 addresses
Sat Jan  1 00:00:23 2000 daemon.info dnsmasq[2820]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Jan  1 00:00:23 2000 daemon.info dnsmasq-dhcp[2820]: read /etc/ethers - 0 addresses
Sat Jan  1 00:00:26 2000 daemon.err uhttpd[1931]: luci: accepted login on / for root from 192.168.1.254
Sat Jan  1 00:00:33 2000 daemon.err nmbd[2534]: [2000/01/01 00:00:33.459073,  0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Sat Jan  1 00:00:33 2000 daemon.err nmbd[2534]:   *****
Sat Jan  1 00:00:33 2000 daemon.err nmbd[2534]:   Samba name server OPENWRT is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
Sat Jan  1 00:01:11 2000 daemon.notice netifd: wan (2164): udhcpc: sending renew to 192.168.100.1
Sat Jan  1 00:01:11 2000 daemon.notice netifd: wan (2164): udhcpc: received DHCP NAK
Sat Jan  1 00:01:11 2000 daemon.notice netifd: Interface 'wan' has lost the connection
Sat Jan  1 00:01:11 2000 daemon.debug dnsmasq[2820]: stopped listening on wan(#4): 192.168.100.2 port 53
Sat Jan  1 00:01:11 2000 daemon.info avahi-daemon[1997]: Withdrawing address record for 192.168.100.2 on wan.
Sat Jan  1 00:01:11 2000 daemon.info avahi-daemon[1997]: Leaving mDNS multicast group on interface wan.IPv4 with address 192.168.100.2.
Sat Jan  1 00:01:11 2000 daemon.info avahi-daemon[1997]: Interface wan.IPv4 no longer relevant for mDNS.
Sat Jan  1 00:01:14 2000 daemon.notice netifd: wan (2164): udhcpc: sending discover
Sat Jan  1 00:01:14 2000 daemon.notice netifd: wan (2164): udhcpc: sending select for 10.31.172.29
Sat Jan  1 00:01:14 2000 daemon.notice netifd: wan (2164): udhcpc: lease of 10.31.172.29 obtained, lease time 86400
Sat Jan  1 00:01:14 2000 daemon.debug dnsmasq[2820]: listening on wan(#4): 10.31.172.29 port 53
Sat Jan  1 00:01:14 2000 daemon.info avahi-daemon[1997]: Joining mDNS multicast group on interface wan.IPv4 with address 10.31.172.29.
Sat Jan  1 00:01:14 2000 daemon.info avahi-daemon[1997]: New relevant interface wan.IPv4 for mDNS.
Sat Jan  1 00:01:14 2000 daemon.info avahi-daemon[1997]: Registering new address record for 10.31.172.29 on wan.IPv4.
Sat Jan  1 00:01:14 2000 daemon.notice netifd: Interface 'wan' is now up
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain test
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain onion
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain localhost
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain invalid
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain bind
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using only locally-known addresses for domain lan
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using nameserver 88.201.160.54#53
Sat Jan  1 00:01:14 2000 daemon.info dnsmasq[2820]: using nameserver 88.201.160.55#53
Sat Jan  1 00:01:14 2000 user.notice firewall: Reloading firewall due to ifup of wan (wan)
You can see when I enter in luci interface Sat Jan  1 00:00:26 2000 daemon.err uhttpd[1931]: luci: accepted login on / for root from 192.168.1.254. But from this to end of log intenet don’t appear.
