Seems like partitions have same size in your images only ext4 filesystem is resized which leads to this error:
So fdisk-params in buildscript seems wrong.
You need to modify partition table inside https://github.com/graphine27/openwrt/blob/r64-emmc/target/linux/mediatek/image/mtk-bin-r64/GPT_EMMC You can do it by booting a distribution from SD, then use fdisk/gdisk to modify. Then use the backup partition table function to replace GPT_EMMC with modified one.
Yes, ptgen generates a (DOS) partition table. That script is creating the full device image, with preloader, U-Boot in the first partition (at the fixed location because we havenât fixed the preloader to use the partition table yet), etc.
Thank you. But I think easier change it in HexEditor
01 00 01 = 10001hex = 65537 dec = beginning of section
00 20 04 = 42000hex=270337dec = end of section or beginning of next section + 1
105 Mb * 1024 *1024 = 110100480 byte / 512 (size of sector) =215040 + 65537 = 280577 dec = 44801hex - 1 = 44800 = 00 48 04
00 20 04 need change to 00 48 04
Mainline openwrt creates a mbr only partition table? Where does @deema gets the gpt (from @graphine s repo)? I did not see the gpt file in upstream
Hi. I have create GPT_EMMC with 7Gb root partition. Now you can set root section size up to 7Gb.
But I want notice that just resize partition not enough. You need change header CRC32 and partition table CRC32. Here they are:
Gpt file locate in r64-emmc branch.
i donât see it: https://github.com/openwrt/openwrt/branches
so i guess you talk about graphines repo (topic is âMainline Openwrtâ): https://github.com/graphine27/openwrt/tree/r64-emmc/target/linux/mediatek/image/mtk-bin-r64
The ptgen utility can generate GPT too, but doesnât for Banana Pi. It generates MBR for the Banana Pi R2 image, and I havenât finished adding full-image support for Banana Pi R64 yet because I need to get a workable build of ATF and other things (isnât there an open source one now?). But R64 probably would use GPT, when I get there.
Iâve rebased the repo to the latest openwrt sources. I also see in nbdâs staging tree there is WIP support for linux 5.10 on mediatek target, looking good. Firewall4 is also introduced in jowâs staging tree, which uses nftables, this should allow better flow offloading without that many patches (like iptables has now).
5.10 has a unfixed issue for bpi-r2 pcie. My repo is fixed, maybe you can add the 2 Patches if 5.10 is still unfixed
Whoever tried to try to build with the overlays section? This is very critical. If a failure occurs while writing, mmcblk0p7 is in read-only mode. This causes a number of problems that will not allow the router to work fully.
But this is flash memory nature. If you shat down electricity when writing occurs it can be fail. So there is a safe extraction in windows.
How to get the SATA port worked?
itâs said in the Wiki that it needs to to give GPIO90 low level
the gpio chip is visible but not accessible for me
root@OpenWrt:~# cat /sys/kernel/debug/gpio gpiochip0: GPIOs 409-511, parent: platform/10211000.pinctrl, pinctrl_moore: gpio-409 ( |factory ) in hi IRQ gpio-463 ( |mt753x-reset ) out hi gpio-490 ( |cd ) in hi IRQ ACTIVE LOW gpio-497 ( |bpi-r64:pio:red ) out lo gpio-498 ( |bpi-r64:pio:green ) out lo gpio-499 ( |asm_sel ) in lo gpio-511 ( |wps ) in hi IRQ
root@OpenWrt:~# echo 499 > /sys/class/gpio/export ash: write error: Resource busy
any idea?
Just like @frank-w said. The dts used in my repo is https://github.com/graphine27/openwrt/blob/r64-emmc/target/linux/mediatek/files-5.4/arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64-rootdisk.dts
But you have sata and sata_phy still disabled (any asm_sel needs to be output-low). I see i have ok instead of okayâŚit needs to be âokayâ
btw. your âresource busyâ is because the gpio is blocked by gpio-hog driver so you cannot access it via sysfs or similar
thank you, it works!
