missing capacitors on tx lines (causing some cards not detected,maybe depend on bus speed)
limited current (causing tx power limited on mt7615)
Maybe you fall into one of these.they are known and should be fixed in next hw-rev,but idk if this hardware is ready
there is a limitation that only one pcie-slot supports usb passthrough (afair the one shared with sata). So if card needs this (like some 4g modems) cards do not work correctly (but should shown up in lspci)
I know it has been discussed before, but the Sinovoip support pages disappeared, so I canāt find the method for setting permanent eth1 (wan) and eth0 (br-lan) MAC address.
Is there any way to set it in U-boot or elsewhere?
Thanks, but unfortunately I couldnāt make it in OpenWRT. There was a setenv command in previous u-boot menu, for setting mac address, but it is gone.
I applied the fw_setenv ethaddr command, and it changed the MAC address indeed (after rebooting). Now every interface has the same MAC address. I think it changed the internal bridge address. Is there any way to specify it separately for the wan/eth1 also? Perhaps it is not so important, because br-lan and wan are on different segments, so there should be no ARP conflict.
I upgraded luci-mod-network and it handles the bridge interface differently that it used before.
But now the LAN bridge does not have any fixed IP address and it does not act as a DHCP server. What should I change in the new config? Here is the bridge related section in the /etc/network/config:
config interface 'lan'
option proto 'static'
option ipaddr '192.168.0.1'
option netmask '255.255.255.0'
option ip6assign '60'
option ifname 'br-lan'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
If I add Option type 'bridge' to the config interface 'lan' section, it already gets IP address, but still not leasing DHCP addresses to clientsā¦
I wonder if there is a comprehensive description of the network config options, or at least a sample configuration with the changed syntax.
Edit: I can add br-lan and the ports manually with brctl. Then it works. But when I open the Network - Interfaces configuration page, it says:
The existing network configuration needs to be changed for LuCi to function properly. Upon pressing āContinueā, bridges configuration will be moved from āinterfaceā sections to ādeviceā sections the network will be restarted to apply the updated configuration.
But after this change the lan1ā¦lan4 ports are not bridged to eth0, and the bridged ports are down. I can restore it only if I add option type 'bridge to the config interface ālanā section, and add the lan1 ⦠lan4 interfaces to the bridge manually with brctl addif br-lan lan1 and same for lan2 lan3 lan4. However, this is not compatible with LuCi.
LuCi version: git-21.140.43486-398982f
After upgrading the kernel to 5.10.39 it works fine.
Edit: it worked fine, but today my wan6 interface ādisappearedā. It is present in LuCi, but not showing up by ifconfig:
root@OpenWrt:/sys/class/net# ifconfig | grep Link
`br-lan Link encap:Ethernet HWaddr 6A:55:75:51:DE:5A`
inet6 addr: fe80::6855:75ff:fe51:de5a/64 Scope:Link
eth0 Link encap:Ethernet HWaddr 6A:55:75:51:DE:5A
ifb4eth1 Link encap:Ethernet HWaddr 4A:80:25:54:53:95
inet6 addr: fe80::4880:25ff:fe54:5395/64 Scope:Link
lan1 Link encap:Ethernet HWaddr 6A:55:75:51:DE:5A
lan2 Link encap:Ethernet HWaddr 6A:55:75:51:DE:5A
lan3 Link encap:Ethernet HWaddr 6A:55:75:51:DE:5A
lan4 Link encap:Ethernet HWaddr 6A:55:75:51:DE:5A
lo Link encap:Local Loopback
wan Link encap:Ethernet HWaddr 6A:55:75:51:DE:5B
inet6 addr: fe80::6855:75ff:fe51:de5b/64 Scope:Link
root@OpenWrt:/sys/class/net# ls
6in4-WAN6 br-lan eth1 lan1 lan3 lo wan
6in4-wan6 eth0 ifb4eth1 lan2 lan4 sit0 wlan0
Also I created a second 6in4-WAN6 device by mistake. Maybe this caused the confusion. Is there any way to remove it? And how could I restore the wan6 interface?
My kernel is 5.10.39 from snapshot image.
For those who interested in fully-working internal Wi-Fi - since mt76 driver loads EEPROM data for MT7622 from MTD partition, itās possible to place this data into SPI-NAND chip where mt76 driver can found it.
This patches adds partition with eeprom (called ārfā) to SPI-NAND/mtd. After building and installing youāll need to flash MT7622_EEPROM.bin (1 ŠŠ) into ārfā partition:
mtd erase rf
mtd write MT7622_EEPROM.bin rf
After reboot youāll get fully-working internal Wi-Fi with fixed MAC-address.
Is there a way to add rf only to spi-nand without touching gpt from sdcard/emmc? I do not see link to spi-nandā¦it seems to use current bootdevice as bootargs are changed too
How do mt76 driver search in spi nandā¦afair it looks only in current devices mtd partitions which is sd/emmc
