Banana Pi BPI-R4 Wifi 7 router board with MediaTek MT7988A (Filogic 880),4G RAM and 8G eMMC
About measured memory bandwidth on R4. I did some research and safe to conclude R4 is good here.
50-ish to 60-ish percent real bandwidth of the theoretical maximum is about the norm on ARM SBCs. For example, look at Raspberry Pi 4 and etc here: https://forums.raspberrypi.com/viewtopic.php?t=271121&sid=f771d50be99d55c700cd6aa9a14f36e1
So nothing to do with the memory traces. Nothing to worry about here. :wink:
Any news about wifi module ?
Take a look at here → Banana Pi BPI-R4 BPI-BE14 Wi-Fi7 NIC module - #52 by Lee-7723
Hey friends I recently purchased the WLE600VX (https://www.aliexpress.com/item/1005006980760083.html) wifi card to connect it to my router (banana pi bpi-r4) and the router fails to recognize it. when I run the command “lspci” the output return empty. I tried to install the following packages also without success: ath10k-firmware-qca988x kmod-ath10k.
Has anyone managed to solve this case by any chance?
they are incompatible, see also BPI R4 doesnt detect 2nd PCI card [solved] - #14 by oli
Please search in forum and do not use general threads for specific peripheral questions.
Ath cards are known not working
hey. version with 1xstp and 1x2.5gbe with poe is avaible in shop? or must solder yourself?
you can contact [email protected] ask support
How to setup or inplement the AFC(Automated Frequency Coordination) in 6GHz? Hardware:Banana pi R4+WiFi7:BPI-R4-NIC-BE14 We have already completed the AFC DUT test Harness on the computer(6 GHz AFC Resources | Wi-Fi Alliance). Is there any information about AFC?
AFC requires, well, automated frequency coordination. This entails something like running afcd (having it connect to the coordinating organization) and then hostapd (or equivalent) with its support.
I’m not aware of any publicly usable implementations of the former just yet. You have to use the low limits that are allowed without AFC.
Thanks,your answer is useful to me. Maybe the “afcd” is what i want. Like these features:[PATCH v7 1/4] hostapd: afcd: add AFC daemon support (Linux Host AP)
FYI. A different vendor’s board has similar, if not exactly same, traces between MT7988a and memory chips.
Atheros AR5BXB63 recycled here…ok, It Is really old, but works fine… Any info about the official wifi7 nic realase?
Just putting this out there as cannot find much information on it, other than SINOVOIP’s getting started wiki.
Has anyone managed to get a Quectel RM520N-GL module working in CN16 M.2 B slot?
Device does not appear to initialize upon boot, i’m not wanting to use an outdated verison of OpenWRT (sinivoip BPI-R4 images) due to not being able to install new drivers/packages etc…
please create own thread for special 3rd party hardware…this thread is about 355 posts log…so the answer gets lost for all who have same problem
I have two 5G modules from quectel (RM520N-GL & RM520N-EU), both works okay inside R4 board. BTW, using mainline openwrt not official image.
Do SFPs (I have DFP-34X-2C3) work in OpenWRT snapshot? I can’t log into the web interface, build 21.02 works without problems.
ethtool is the same in both versions:
please do specific extra hardware in separate threads…afaik there is already one for the DFP-34X-2C3 where someone created patches for (afair rejected upstream so far)
this thread goes very messy because of different topics mixed
Does someone have an issue in recent builds (since 2 weeks), that device freeze with kernel panic:
Thu Aug 22 17:57:24 2024 daemon.notice hostapd: phy1-ap0: BEACON-REQ-TX-STATUS 8c:7a:3d:aa:d7:aa 30 ack=1
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.777538] Unable to handle kernel paging request at virtual address ffffffffffffff98
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.785480] Mem abort info:
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.788264]   ESR = 0x0000000096000005
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.792016]   EC = 0x25: DABT (current EL), IL = 32 bits
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.797318]   SET = 0, FnV = 0
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.800361]   EA = 0, S1PTW = 0
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.803500]   FSC = 0x05: level 1 translation fault
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.808367] Data abort info:
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.811237]   ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.816714]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.821756]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.827056] swapper pgtable: 4k pages, 39-bit VAs, pgdp=0000000046b4c000
Thu Aug 22 17:57:25 2024 kern.alert kernel: [ 5520.833747] [ffffffffffffff98] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
and after reboot, it goes to the initramfs and only unplug power for few seconds and turn on works? I suspect that the microSD card is broken, but on second one (very old) issue comes again.
Please create new topic with operation system and version. For me it looks like an error-pointer is used as memory address.
0xf…f98 should be -104 which is “connection reset”
