Banana Pi BPI-R4 heatsink and Case design
50mm x 50mm, and ~2mm of the ram/emmc aren’t covered, which are accounted for via a thermal pad
unfortunately, there is 0mm of space between the heatsink and fan header, so in order to align with the mounting holes + fully cover ram/emmc it would need to be an asymmetrical shape
I have a decent camera, and a tripod, but no automated means of rotating the device itself at the moment - when I have a moment I will check out meshroom, as it could be quite generally helpful if I can use it to generate models that could be sliced for my printer; thanks for the share
Banana Pi BPI-R4 Opensource Router board case design,sample ready.
How does it look from other sides? Imho some ventilation holes are needed
This is the result of stressing all cores with these heatsinks. I’m using Daniel’s repo. I also ported LVTS driver to 6.1 kernel for the thermal sensors to work
But without having the board in a closed case,right? I remember some users uad issues with r3 case too because of missing ventilation holes
Right, without case. I assume closed case would add another 10 degrees
I think more if you use also SFP+, specially 10BaseT transceiver (they can reach 70C).
Right, adding more peripherals would increase the heat significantly
My modification is here
@dangowrt do you want to add this to your PR?
Could you try using the mainline-version of lvts driver? It makes backporting other changes easier.
Also i miss the infracfg reset,but afair this was not needed in sdk version
I didn’t even check if there’s a mainline version! Did some unnecessary work. Never mind. Ignore the commit
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/thermal/mediatek/lvts_thermal.c
Should have mt7988 parts since 6.6
I have to rework the ifracfg reset part as the main resets start at 0x70 but you can start using the current version from daniels wip tree or from patchwork
https://patchwork.kernel.org/project/linux-mediatek/patch/[email protected]/
Yea I saw that now. I should have looked first. Never mind, it was easy
new BPI-R4 case sample :slight_smile:
This is a full metal case?? How about heat sink & fan?
Looks nice ! Now i want one! :smiling_face_with_three_hearts: I personalny like the look of espressobin ultra design.
Question is how are you going to cool the daughter board, I think it’s better if you went abs instead of full metal and made a mesh grille at the top for better airflow
Maybe you could utilise peltier cooling with a fan, these should work quite well on both motherboard and daughter board or even air jets
I definitely need one of these! Any ETA on it?
