I’m trying to get Wifi6 working on @danpawlik Build not Wifi7.
Am I confused or missing something?
Two posts above is an answer. It is on the openwrt forum.
trace above is caused by
and it seems interface is in state NL80211_IFTYPE_ADHOC
if (WARN_ON(types & BIT(NL80211_IFTYPE_ADHOC) &&
c->beacon_int_min_gcd)) {
return -EINVAL;
not sure why only 1 phy is affected here (the other 2 are probed completely).
added a revert in my 6.11-rc tree and of course reported back to submitter.
Also got info that mainline patches/firmware for be14 (233) and others are prepared by mtk
You got info that they are working on the mainline patches for the BE14? That’s great news
Did you got info about what kernel they are working for? Public repo indicates that they are still working/developing for 5.4 …
Yes they talked about mainline support…downstream support (5.4) is already there.
5.4? That’s that old firmware they put out isn’t it? It’ll be great when something 6.1 or newer comes out, but it’s great they are working on it. Also thanks for all you’ve done as well.
WiFi 7 board doesn’t work for me both in MTK MP3.1 and MTK MP4.0 official builds. Radio devices always stay inactive (didn’t do anything else beside restarting devices in LuCi). I’ve got it partially working (2.4 GHz only) in a custom build by @danpawlik, so the board is at least somewhat functional. Does anyone have an idea how to get it working in Sinovoip’s OpenWrt?
Kernel log of the MTK MP3.1 build attached.
kernlog.txt (125.3 KB)
I believe you have to activate the wifi through the MTK menu instead of the network->wireless menu…
Is it just me or are the SnapShot Builds on OpenWrt faulty.
Using their link - https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=mediatek%2Ffilogic&id=bananapi_bpi-r4
and downloading the SNAPSHOT (r27283-85f0128851) build to SDCard.
I can’t get any combination of enabling 2.4GHz and/or 5GHz Wifi working at all.
longterm 5.4 support ends in Dec 25 hopefully will be quicker their upgrade to 6.1 (not 5.10 nor 5.15
I am using latest openwrt/main and
My config:
root@bpi-r4-9611025bdb3d:~# cat /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0'
option band '2g'
option channel '1'
option htmode 'EHT20'
option country 'JP'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'OpenWrt'
option encryption 'sae'
option key 'testtest'
config wifi-device 'radio1'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+1'
option band '5g'
option channel '36'
option htmode 'EHT80'
option country 'JP'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
config wifi-device 'radio2'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+2'
option band '6g'
option channel '1'
option htmode 'EHT320'
option country 'JP'
config wifi-iface 'default_radio2'
option device 'radio2'
option mode 'ap'
And iw output:
root@bpi-r4-9611025bdb3d:~# iw dev
phy#2
Interface phy2-ap0
ifindex 14
wdev 0x200000002
addr 96:11:02:5b:db:41
ssid OpenWrt
type AP
channel 1 (5955 MHz), width: 320 MHz, center1: 6105 MHz
txpower 23.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
phy#1
Interface phy1-ap0
ifindex 16
wdev 0x100000002
addr 96:11:02:5b:db:40
ssid OpenWrt
type AP
channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
phy#0
Interface phy0-ap0
ifindex 15
wdev 0x2
addr 96:11:02:5b:db:3f
ssid OpenWrt
type AP
channel 1 (2412 MHz), width: 20 MHz, center1: 2412 MHz
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
On your log, there is no traffic recorded. It cannot say the 6GHz band is working. If it is working, should expect some log like this:
so far just checked beacons contain EHT - stations will be next step
And here station BE200:
phy#2
Interface phy2-ap0
ifindex 32
wdev 0x200000008
ssid OpenWrt
type AP
txpower 23.00 dBm
multicast TXQ:
0 0 14 0 0 0 0 1500 14
phy#1
Interface phy1-ap0
ifindex 34
wdev 0x100000008
ssid OpenWrt
type AP
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
phy#0
Interface phy0-ap0
ifindex 33
wdev 0x8
ssid OpenWrt
type AP
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
root@bpi-r4-9611025bdb3d:~# iw phy2-ap0 station dump
Station a0:02:a5:5f:e0:65 (on phy2-ap0)
inactive time: 460 ms
rx bytes: 4584
rx packets: 102
tx bytes: 1844
tx packets: 18
tx retries: 17
tx failed: 17
rx drop misc: 0
signal: -42 [-46, -45, -48] dBm
signal avg: -39 [-43, -43, -46] dBm
tx bitrate: 288.2 MBit/s 320MHz EHT-MCS 0 EHT-NSS 2 EHT-GI 0
tx duration: 104259 us
rx bitrate: 980.0 MBit/s 320MHz EHT-MCS 3 EHT-NSS 2 EHT-GI 2
rx duration: 12014 us
last ack signal:-42 dBm
avg ack signal: -41 dBm
airtime weight: 256
authorized: yes
authenticated: yes
associated: yes
preamble: long
WMM/WME: yes
MFP: yes
TDLS peer: no
DTIM period: 2
beacon interval:100
short slot time:yes
connected time: 67 seconds
associated at [boottime]: 5788.042s
associated at: 1725213233393 ms
current time: 1725213299973 ms
Could you share the image of the SD?
Thanks, all three APs work that way. Although, I can only join them so long as encryption is off…
wpa2 + sae - my clients have fresh supplicant
option band '2g'
option channel '1'
option country 'JP'
option mode 'ap'
option encryption 'sae-mixed'
option band '5g'
option channel '36'
option country 'JP'
option mode 'ap'
option band '6g'
option channel '1'
option country 'JP'
option mode 'ap'
option sae_pwe '2'
