Banana Pi BPI-R4 BPI-BE14 Wi-Fi7 NIC module
Is it just me or are the SnapShot Builds on OpenWrt faulty.
Using their link - https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=mediatek%2Ffilogic&id=bananapi_bpi-r4
and downloading the SNAPSHOT (r27283-85f0128851) build to SDCard.
I can’t get any combination of enabling 2.4GHz and/or 5GHz Wifi working at all.
Yes, that is correct. @Betonmischer the Sinovoip’s OpenWrt is working but for me, quite buggy
longterm 5.4 support ends in Dec 25 hopefully will be quicker their upgrade to 6.1 (not 5.10 nor 5.15 :crossed_fingers:)
I am using latest openwrt/main and
My config:
root@bpi-r4-9611025bdb3d:~# cat /etc/config/wireless
config wifi-device 'radio0'
        option type 'mac80211'
        option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0'
        option band '2g'
        option channel '1'
        option htmode 'EHT20'
        option country 'JP'
config wifi-iface 'default_radio0'
        option device 'radio0'
        option network 'lan'
        option mode 'ap'
        option ssid 'OpenWrt'
        option encryption 'sae'
        option key 'testtest'
config wifi-device 'radio1'
        option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+1'
        option band '5g'
        option channel '36'
        option htmode 'EHT80'
        option country 'JP'
config wifi-iface 'default_radio1'
        option device 'radio1'
        option mode 'ap'
config wifi-device 'radio2'
        option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+2'
        option band '6g'
        option channel '1'
        option htmode 'EHT320'
        option country 'JP'
config wifi-iface 'default_radio2'
        option device 'radio2'
        option mode 'ap'
And iw output:
root@bpi-r4-9611025bdb3d:~# iw dev
phy#2
        Interface phy2-ap0
                ifindex 14
                wdev 0x200000002
                addr 96:11:02:5b:db:41
                ssid OpenWrt
                type AP
                channel 1 (5955 MHz), width: 320 MHz, center1: 6105 MHz
                txpower 23.00 dBm
                multicast TXQ:
                        qsz-byt qsz-pkt flows   drops   marks   overlmt hashcol tx-bytes        tx-packets
                        0       0       0       0       0       0       0       0               0
phy#1
        Interface phy1-ap0
                ifindex 16
                wdev 0x100000002
                addr 96:11:02:5b:db:40
                ssid OpenWrt
                type AP
                channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
                txpower 20.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
phy#0
        Interface phy0-ap0
                ifindex 15
                wdev 0x2
                addr 96:11:02:5b:db:3f
                ssid OpenWrt
                type AP
                channel 1 (2412 MHz), width: 20 MHz, center1: 2412 MHz
                txpower 20.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
On your log, there is no traffic recorded. It cannot say the 6GHz band is working. If it is working, should expect some log like this:
so far just checked beacons contain EHT - stations will be next step
And here station BE200:
phy#2
        Interface phy2-ap0
                ifindex 32
                wdev 0x200000008
                ssid OpenWrt
                type AP
                txpower 23.00 dBm
                multicast TXQ:
                        0       0       14      0       0       0       0       1500            14
phy#1
        Interface phy1-ap0
                ifindex 34
                wdev 0x100000008
                ssid OpenWrt
                type AP
                txpower 20.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
phy#0
        Interface phy0-ap0
                ifindex 33
                wdev 0x8
                ssid OpenWrt
                type AP
                txpower 20.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
root@bpi-r4-9611025bdb3d:~# iw phy2-ap0 station dump
Station a0:02:a5:5f:e0:65 (on phy2-ap0)
        inactive time:  460 ms
        rx bytes:       4584
        rx packets:     102
        tx bytes:       1844
        tx packets:     18
        tx retries:     17
        tx failed:      17
        rx drop misc:   0
        signal:         -42 [-46, -45, -48] dBm
        signal avg:     -39 [-43, -43, -46] dBm
        tx bitrate:     288.2 MBit/s 320MHz EHT-MCS 0 EHT-NSS 2 EHT-GI 0
        tx duration:    104259 us
        rx bitrate:     980.0 MBit/s 320MHz EHT-MCS 3 EHT-NSS 2 EHT-GI 2
        rx duration:    12014 us
        last ack signal:-42 dBm
        avg ack signal: -41 dBm
        airtime weight: 256
        authorized:     yes
        authenticated:  yes
        associated:     yes
        preamble:       long
        WMM/WME:        yes
        MFP:            yes
        TDLS peer:      no
        DTIM period:    2
        beacon interval:100
        short slot time:yes
        connected time: 67 seconds
        associated at [boottime]:       5788.042s
        associated at:  1725213233393 ms
        current time:   1725213299973 ms
Could you share the image of the SD?
Thanks, all three APs work that way. Although, I can only join them so long as encryption is off…
http://valhalla.bofh.pl/~l4mer/openwrt-mediatek-filogic-bananapi_bpi-r4-sdcard.img.gz
wpa2 + sae - my clients have fresh supplicant
        option band '2g'
        option channel '1'
        option country 'JP'
        option mode 'ap'
        option encryption 'sae-mixed'
        option band '5g'
        option channel '36'
        option country 'JP'
        option mode 'ap'
        option band '6g'
        option channel '1'
        option country 'JP'
        option mode 'ap'
        option sae_pwe '2'
Don’t know what happened, but now encryption works up to WPA3 after booting into a clean stock image.
Hi, which stock image have you used? I tried the SDK40 Version (BPI-R4-BE1350-WIFI_MP4_0 -SDK-20240620). Without authentication communication is running in 2.4, 5 and 6GHz. But as soon as I switch authentication on (like WPA2PSK, WPA3PSK etc…) connect cannot be established anymore. :frowning:
This is the same one I use. I can’t remember exactly what I did differently last time that helped, but it was in MKT->WiFi Configuration. Could have been simply pressing ‘Reload’ and ‘Disable/Enable’ after making changes. Current config is attached below. wireless.txt (12.8 KB)
you should create dedicated threads with the used image…thread is mixed up with general questions, bpi image, mainline openwrt and hard to follow.
On the last snapshot I have 6GHz wifi 6E on the ‘soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+1’ device. Its wierd for me, but it work. My config:
Спойлер
	option band '6g'
	option channel '53'
	option htmode 'HE160'
	option txpower '100'
	option country 'DE'
	option cell_density '0'
	option disabled '0'
	option mode 'ap'
	option ssid 'OpenWrt5'
	option vifidx '1'
	option hidden '0'
	option wmm '1'
	option dtim_period '1'
	option encryption 'owe'
	option rekey_interval '3600'
	option rekey_meth 'DISABLE'
	option ieee8021x '0'
	option ownip '192.168.1.1'
	option disabled '0'
Thanks. I tested and got only 36 Mbps iperf3 test. I expected more speed. Something is wrong here because with HE160 I get more than 1.6 Gbps. image
It may be a problem with the receiving device. I have a Samsung S24 Ultra. It has Wi-Fi 7 declared as a test one.
I am having speed issues on my Galaxy S24 Ultra too, using the latest image from Banana-PI in WiFi7, oddly enough this is the only device that has this issue, anything else connected to the Banana-PI works fine, including Laptops using BE200 WiFi NICs.
My Galaxy S24 Ultra works fine when I connect it to another (Qualcomm based) WiFi 7 access point, so I am fairly confident this is a bug in the firmware or MT7990 driver running on the Banana-Pi router.
In my case i can set wifi protection wpa2 aes with password and client don’t even ask to provide password, today got second module and antennas from sinovoip, one module not directly from sinovoip was doa… Bpi hang with green led and not boot, no serial console output.
Because of mixing different topics around the wifi module…please create dedicated threads
