After playing around a bit with the image, i find the network somewhat buggy in what relates to DNS. Is there any service missing or that should not be installed in your debian 11 image? I plan to use bpi as a network “slave” so to speak and not a router/gateway/switch.
Also, sometimes network configs using netplan seem to not be applied correctly. What is the method that you would use on this image to configure network interfaces?
EDIT: Can this problem be related to any virtual interfaces left on device. On boot log, i see this:
Also another question… what is this interface lanbr0?
EDIT: I get the impression that DHCP client may not be working properly on wired interfaces. Wifi interfaces seem to be OK.
I also tested old way (using /etc/network/interfaces) and wired ifaces still seem to have trouble acquiring IP addresses
Ah makes sense. Actually already seen those files but were unsure if they were needed…
So, without such files, i should have a “default” debian 11 installation?
Is there any dhcp client installed in your base image? I assume there is because wifi interfaces got IP without specifying
Right, wlan0 and 1 also get fixed ip and dhcp-server from these files…also additional interfaces like vlans are created by those. Make sure you use debug-uart before disabling my network config
dhclient should be installed by default. I have not modified much only created a basic configuration like network,hostname rootpw and installed some basic packages like hostapd and network diagnostic tools
Systemd-networkd is default network-manager in debian, ifupdown (which uses /etc/network/interfaces) is deprecated and not installed by default. Netplan is ubuntu specific but also available in debian (imho not installed by default)
You can basicly disable systemd-networkd and keep the files and activating your netplan,but make sure you are not working over network-connection
My files contain example how to use dhcp on wan if needed,but remember your main-router needs to know your lan-subnet behind r3 (when not doing masquerading on wan) which needs to be different to its lan and routing needs to be activated.
IMma bit confused right now. I thought that netplan was just an interface for networkd or NetworkManager (on ubuntu).
So if i disable systemd-networkd things should not work. Anyway, after deleting those files, looks like it got better. My only problem now seem to be DNS resolving
