Managed to use USB Serial by adding some modules that were referencing that… so not a problem anymore.
But wifi still not working
So this is the output of iw dev wlan0 scan:
root@bpi-r3:/etc/systemd/system# ifconfig wlan0 up
root@bpi-r3:/etc/systemd/system# iw dev wlan0 scan
BSS 00:06:91:78:d5:a0(on wlan0)
last seen: 1422.948s [boottime]
TSF: 11944142129558 usec (138d, 05:49:02)
freq: 2412
beacon interval: 100 TUs
capability: ESS Privacy ShortSlotTime (0x0411)
signal: -67.00 dBm
last seen: 1270 ms ago
Information elements from Probe Response frame:
SSID: Guests-2.4
Supported rates: 1.0* 2.0* 5.5* 11.0* 18.0 24.0 36.0 54.0
DS Parameter set: channel 1
ERP: <no flags>
Extended supported rates: 6.0 9.0 12.0 48.0
RSN: * Version: 1
* Group cipher: TKIP
* Pairwise ciphers: CCMP TKIP
* Authentication suites: PSK
* Capabilities: 16-PTKSA-RC 1-GTKSA-RC (0x000c)
BSS Load:
* station count: 0
* channel utilisation: 43/255
* available admission capacity: 0 [*32us]
Measurement Pilot Transmission:
* interval: 0 TUs
HT capabilities:
Capabilities: 0x8ad
RX LDPC
HT20
SM Power Save disabled
RX HT20 SGI
TX STBC
No RX STBC
Max AMSDU length: 7935 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT RX MCS rate indexes supported: 0-23
HT TX MCS rate indexes are undefined
HT operation:
* primary channel: 1
* secondary channel offset: no secondary
* STA channel width: 20 MHz
* RIFS: 1
* HT protection: no
* non-GF present: 1
* OBSS non-GF present: 0
* dual beacon: 0
* dual CTS protection: 0
* STBC beacon: 0
* L-SIG TXOP Prot: 0
* PCO active: 0
* PCO phase: 0
Overlapping BSS scan params:
* passive dwell: 20 TUs
* active dwell: 10 TUs
* channel width trigger scan interval: 300 s
* scan passive total per channel: 200 TUs
* scan active total per channel: 20 TUs
* BSS width channel transition delay factor: 5
* OBSS Scan Activity Threshold: 0.25 %
Extended capabilities:
* HT Information Exchange Supported
* Extended Channel Switching
* BSS Transition
* Operating Mode Notification
WPS: * Version: 1.0
* Wi-Fi Protected Setup State: 2 (Configured)
* Response Type: 3 (AP)
* UUID: 69cb2e76-0d6c-46d2-9051-d5c1aad01967
* Manufacturer: PTIN
* Model: PTIN
* Model Number: GR241AG
* Serial Number: 5054494E9178D59F
* Primary Device Type: 6-0050f204-1
* Device name: devName
* Config methods: Label, Display
* RF Bands: 0x3
* Version2: 2.0
WPA: * Version: 1
WMM: * Parameter version 1
* u-APSD
* BE: CW 15-1023, AIFSN 3
* BK: CW 15-1023, AIFSN 7
* VI: CW 7-15, AIFSN 2, TXOP 3008 usec
* VO: CW 3-7, AIFSN 2, TXOP 1504 usec
BSS 00:06:91:78:d5:a2(on wlan0)
last seen: 1422.950s [boottime]
TSF: 11944142137771 usec (138d, 05:49:02)
freq: 2412
capability: ESS ShortSlotTime (0x0401)
signal: -68.00 dBm
last seen: 1260 ms ago
SSID: MEO-WiFi
ERP: <no flags>
BSS Load:
* station count: 1
* interval: 0 TUs
HT capabilities:
Capabilities: 0x8ad
RX LDPC
HT20
RX HT20 SGI
TX STBC
No RX STBC
No DSSS/CCK HT40
HT operation:
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
* u-APSD
BSS 02:92:bf:14:3d:65(on wlan0)
last seen: 1423.309s [boottime]
TSF: 6279650509464 usec (72d, 16:20:50)
freq: 2437
capability: ESS Privacy ShortPreamble ShortSlotTime RadioMeasure (0x1431)
signal: -87.00 dBm
last seen: 910 ms ago
SSID: Visitors-HFA
Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0
DS Parameter set: channel 6
TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x1 Bitmap[0] 0xec (+ 1 octet)
ERP: <no flags>
Extended supported rates: 24.0 36.0 48.0 54.0
BSS Load:
* station count: 1
* channel utilisation: 22/255
* available admission capacity: 31250 [*32us]
RM enabled capabilities:
Capabilities: 0x73 0xd0 0x00 0x00 0x0c
Link Measurement
Neighbor Report
Beacon Passive Measurement
Beacon Active Measurement
Beacon Table Measurement
LCI Measurement
Transmit Stream/Category Measurement
Triggered Transmit Stream/Category
FTM Range Report
Civic Location Measurement
Nonoperating Channel Max Measurement Duration: 0
Measurement Pilot Capability: 4
HT capabilities:
Capabilities: 0x41ac
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
40 MHz Intolerant
Minimum RX AMPDU time spacing: 8 usec (0x06)
HT TX/RX MCS rate indexes supported: 0-23
HT operation:
* primary channel: 6
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* TFS
* WNM-Sleep Mode
* TIM Broadcast
* BSS Transition
* SSID List
RSN: * Version: 1
* Group cipher: CCMP
* Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
BSS fa:92:bf:14:3d:65(on wlan0)
TSF: 6279650511990 usec (72d, 16:20:50)
freq: 2437
signal: -89.00 dBm
SSID: Hfa
Supported rates: 12.0* 18.0 24.0* 36.0 48.0 54.0
TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x0 Bitmap[0] 0x0
ERP: <no flags>
BSS Load:
* station count: 0
Link Measurement
Neighbor Report
LCI Measurement
FTM Range Report
HT capabilities:
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
40 MHz Intolerant
HT TX/RX MCS rate indexes supported: 1-23
HT operation:
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* TFS
* WNM-Sleep Mode
* TIM Broadcast
* BSS Transition
* SSID List
RSN: * Version: 1
BSS fa:92:bf:14:3c:64(on wlan0)
last seen: 1423.706s [boottime]
TSF: 11952009423982 usec (138d, 08:00:09)
freq: 2462
signal: -83.00 dBm
last seen: 510 ms ago
SSID: Hfa
DS Parameter set: channel 11
ERP: <no flags>
BSS Load:
* station count: 0
Link Measurement
Neighbor Report
LCI Measurement
FTM Range Report
HT capabilities:
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
40 MHz Intolerant
HT operation:
* primary channel: 11
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* TFS
* WNM-Sleep Mode
* TIM Broadcast
* BSS Transition
* SSID List
RSN: * Version: 1
BSS 02:92:bf:14:3c:64(on wlan0)
last seen: 1423.808s [boottime]
TSF: 11952009523584 usec (138d, 08:00:09)
freq: 2462
signal: -86.00 dBm
last seen: 410 ms ago
SSID: Visitors-HFA
TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x1 Bitmap[0] 0x1c
ERP: <no flags>
BSS Load:
* station count: 1
Link Measurement
Neighbor Report
LCI Measurement
FTM Range Report
HT capabilities:
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
40 MHz Intolerant
HT operation:
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* TFS
* WNM-Sleep Mode
* TIM Broadcast
* BSS Transition
* SSID List
RSN: * Version: 1
BSS 08:3a:2f:15:e7:e0(on wlan0)
last seen: 1423.983s [boottime]
TSF: 1408617251 usec (0d, 00:23:28)
freq: 2472
signal: -90.00 dBm
last seen: 230 ms ago
SSID: NVR083a2f15e7e0
DS Parameter set: channel 13
ERP: Barker_Preamble_Mode
RSN: * Version: 1
HT capabilities:
Capabilities: 0x2c
HT20
RX HT20 SGI
No RX STBC
No DSSS/CCK HT40
Minimum RX AMPDU time spacing: 2 usec (0x04)
HT RX MCS rate indexes supported: 0-15
HT operation:
* primary channel: 13
* RIFS: 0
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* u-APSD
* VI: CW 7-15, AIFSN 2, TXOP 2976 usec
* VO: CW 3-7, AIFSN 2, TXOP 1472 usec
i cannot find hostapd2 service:
This next command makes me think that system thinks that wlan0 is wired interface:
