I have a smaller patchset (2 patches) but this make errors on other platforms. Maybe on openwrt this is not a problem if it is only applied for target mediatek (afair aarch64 is also not affected):
Open the commit in github,add .patch to addressline,save it in the target/mediatek/patches-5.10 folder
Should work if there are no conflicting patches applied first
i will test the cursor plane patch next as i noticed a similar problem some time ago with a touchscreen (cursor was placed on last not current position)
In terms of HDMI OpenWrt really just uses v5.10.54 vanilla as-is. We donāt care much about video support as most people run OpenWrt on headless devices.
Forward-porting v5.10 to the level of v5.14 are 100+ patches touching drivers/soc/mediatek and drivers/gpu/drm/mediatek, so thatās not an option.
I also tried reverting a couple of top commits touching drivers/drm/mediatek and also tried disabling CMDQ. All with no success, situation unchanged. I still suspect we just miss something in DTS or a kernel config symbol which needs to be enabledā¦
Thanks for your work. I just cloned the actual repository, could build a new kernel, but didn“t find the needed images in the build folder. My own recipe [1] to create an usable sd-card is obsolete ATM
Because I“m want to add some packages and settings to the build, the download of the finished image ist not the solution for me. How to setup the menuconfig correctly to get the full image file?
First of all this only works on the most recent OpenWrt, ie. 21.02 and 19.07 still come with the old images.
If you want to build from source, pretty much like you describe:
git clone https://git.openwrt.org/openwrt/openwrt.git
cd openwrt
rm .config
make menuconfig
now select Mediatek ARM -> MT7623 -> BananaPi BPi-R2
If you want to preserve your existing .config, make sure you select also the bootloader and build squashfs as wll as initramfs images for the sdcard.img.gz to be created. This happens automatically if you start off an empty .config and then select the target.
If you are not modifying any source code but just want to select the packages which are installed, itās better to use the OpenWrt ImageBuilder which can compose images from existing binaries in a much more reliable and reproducible way than building from source.
Very excited that OpenWrt 21.02.0-rc4 is building correctly on the site. Iāve been running snapshot builds for a long time now, getting worn out from manual updates. Download and flash, up and running in minutes.
Now working on my gnu libc build (everything I like to run on it needs gnu libc). (I have 2 bpi-r2, 1 as main and one to tinker with)
I do have one problem though, Iām still getting disappointing throughput. Service is 1Gb and I can barely get 150-200Mb down. (Even before installing and enabling SQM) Not sure what causes this. The last version that gave good throughput was frank-wās 18.06. Trying to investigate the differences proved too challenging for me.
Does anyone A. report better performance with the buildbot provided 21.02? or B. Know off hand what patches are missing to get throughput working properly? Or C. report better performance with snapshots?
You always need to push the start button unless you modify the board (solder the bridge next to the switch) BUT, sometimes, if I use the USB console (in the back) it turns itself on. (probably the 5v from the host) But I usually use the other serial which doesnāt pass power. I havenāt tried the uart pins on the gpio
Have been running rc4 for a week now. I have a problem with lan ports randomly flapping. The r2 is my edge router, I only use one downlink to my AP/bridge. It works fine for hours/days at a time, and then this:
Sun Aug 29 12:52:50 2021 kern.info kernel: [330726.006066] mt7530 mdio-bus:00 lan1: Link is Down
Sun Aug 29 12:52:50 2021 kern.info kernel: [330726.011116] br-lan: port 2(lan1) entered disabled state
Sun Aug 29 12:52:50 2021 daemon.notice netifd: Network device 'lan1' link is down
Sun Aug 29 12:52:51 2021 daemon.notice netifd: bridge 'br-lan' link is down
Sun Aug 29 12:52:51 2021 daemon.notice netifd: Interface 'lan' has link connectivity loss
Sun Aug 29 12:52:55 2021 daemon.notice netifd: Network device 'lan1' link is up
Sun Aug 29 12:52:55 2021 kern.info kernel: [330731.206212] mt7530 mdio-bus:00 lan1: Link is Up - 1Gbps/Full - flow control off
Sun Aug 29 12:52:55 2021 kern.info kernel: [330731.213648] br-lan: port 2(lan1) entered blocking state
Sun Aug 29 12:52:55 2021 kern.info kernel: [330731.218985] br-lan: port 2(lan1) entered forwarding state
Sun Aug 29 12:52:55 2021 daemon.notice netifd: bridge 'br-lan' link is up
Sun Aug 29 12:52:55 2021 daemon.notice netifd: Interface 'lan' has link connectivity
Sun Aug 29 12:53:07 2021 daemon.notice netifd: Network device 'lan1' link is down
Sun Aug 29 12:53:07 2021 kern.info kernel: [330742.646065] mt7530 mdio-bus:00 lan1: Link is Down
Sun Aug 29 12:53:07 2021 kern.info kernel: [330742.650978] br-lan: port 2(lan1) entered disabled state
Sun Aug 29 12:53:08 2021 daemon.notice netifd: bridge 'br-lan' link is down
Sun Aug 29 12:53:08 2021 daemon.notice netifd: Interface 'lan' has link connectivity loss
Sun Aug 29 12:53:09 2021 daemon.notice netifd: Network device 'lan1' link is up
Sun Aug 29 12:53:09 2021 daemon.notice netifd: bridge 'br-lan' link is up
Sun Aug 29 12:53:09 2021 daemon.notice netifd: Interface 'lan' has link connectivity
Sun Aug 29 12:53:09 2021 kern.info kernel: [330744.726208] mt7530 mdio-bus:00 lan1: Link is Up - 1Gbps/Full - flow control off
Sun Aug 29 12:53:09 2021 kern.info kernel: [330744.733638] br-lan: port 2(lan1) entered blocking state
Sun Aug 29 12:53:09 2021 kern.info kernel: [330744.738968] br-lan: port 2(lan1) entered forwarding state
Iām not detecting a pattern to this interval. Iāve already replaced the AP/bridge, convinced it was the bridge.
Itās also a completely random chance that the interface comes back up at all. Twice, itās gone down and refused to come back up without a restart.
It also gets worse/more frequent if I enable SQM.
Does anyone report similar?
I will find an opportunity this week to switch R2ās to see if itās a hardware issue with this unit, but thatās a stretch.
