wiringPi2 is not working with the Banana Pi M3
Hello !
I have never installed any wiringPi and I have no idea how to install https://github.com/BPI-SINOVOIP/BPI-WiringPi2.
I don’t understand a thing from the readme. Do I need to install the original WiringPi ? Do I need to install only this WiringPi2 ?
This git clone git://git.drogon.net/wiringPi is for the original one or for the BPI one ?
I did the following:
git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi2
cd BPI-WiringPi2
chmod +x ./build
sudo ./build
gpio -v
And it did not work:
Unable to determine hardware version. I see: Hardware	: Allwinner A83t board
 - expecting BCM2708, BCM2709 or BCM2835.
If this is a genuine Raspberry Pi then please report this
to projects@drogon.net. If this is not a Raspberry Pi then you
are on your own as wiringPi is designed to support the
Raspberry Pi ONLY.
So it doesn’t work.
This is the OS that I am using on the Banana Pi:
ARMBIAN 5.83 stable Debian GNU/Linux 9 (stretch) 4.19.38-sunxi
