what is difference between Bpi Banana Pi R64
and Bpi Banana Pi R64 (rootdisk)
in make menuconfig?
In the Bpi Banana Pi R64
target/linux/mediatek/files-4.19/arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64.dts
chosen {
bootargs = "earlycon=uart8250,mmio32,0x11002000 console=ttyS0,115200n1 swiotlb=512";
In the Bpi Banana Pi R64 (rootdisk)
target/linux/mediatek/files-5.4/arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64-rootdisk.dts
chosen {
stdout-path = "serial0:115200n8";
bootargs = "earlycon=uart8250,mmio32,0x11002000 console=ttyS0,115200n1 swiotlb=512 root=/dev/mmcblk0p7 rootfstype=squashfs,f2fs";
The original Bpi Banana Pi R64 image only support initramfs rootfs, but if you enable kernel option (CONFIG_BLK_DEV_LOOP=y) and build mt7622-bananapi-bpi-r64-rootdisk target device image,this image will use emmc disk(p7) as rootfs(squash + ext4 overlayfs).
Note,the default bpi-r64 emmc disk paritition are only p1~p5, hence you need to use tools like fdisk to create p6 (for recovery) and p7(rootfs) to support bpi-r64 rootdisk function.
