Use nodejs write code to control webduino LED
(bpi team) #1
webduino support graphical programming, so you can use it to control LED .
if you check the red box button, you can see js code:
var rgbled;
boardReady({board: 'Smart', url: '10.73.83.110'}, function (board) {
    board.systemReset();
    board.samplingInterval = 50;
    rgbled = getRGBLedCathode(board, 15, 12, 13);
    rgbled.setColor('#ff0000');
so we can try to use nodejs to control it:
first , we can start official open source js,code at : https://github.com/webduinoio/webduino-js
at first , you must install nodejs .
1, create a led dir 2, install webduino js lib
cd led
npm install webduino-js
3 ,create led.js file:
var webduino = require('webduino-js');
var board, rgbled;
board = new webduino.board['Smart']({url: '10.73.83.110'});
function getRGBLedCathode(board, red, green, blue) {
    return new webduino.module.RGBLed(board, board.getDigitalPin(red), board.getDigitalPin(green), board.getDigitalPin(blue), webduino.module.RGBLed.COMMON_CATHODE);
board.on('ready', function() {
    console.log("board ready")
    board.samplingInterval = 500;
    rgbled.setColor('#0000ff');
    console.log("board end")
so you can control led with nodejs code.
