Use key to control LED brightness and extinguish
The front panel of BPI:bit is 1600W color LED-WS2812, that is to say, we can play a lot of tricks behind us.
This time to play a simple point. The key is used to control the brightness and extinction of LED.
Press the ammonium button
按下
Unpress the ammonium button
松开
The code is as follows
    #include <Arduino.h>
    #include <NeoPixelBus.h>
    #define LEDC_CHANNEL_0 0
    #define LEDC_TIMER_13_BIT 13
    #define LEDC_BASE_FREQ 4500
    const uint16_t PixelCount = 25;
    const uint8_t PixelPin = 4;
    #define colorSaturation 128
    #define delay_ms 500
    NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
    RgbColor red(colorSaturation, 0, 0);
    RgbColor green(0, colorSaturation, 0);
    RgbColor blue(0, 0, colorSaturation);
    RgbColor white(colorSaturation);
    RgbColor black(0);
    RgbColor num1(0.8 * colorSaturation, 0, 0.2 * colorSaturation);
    RgbColor num2(0.5 * colorSaturation, 0, 0.5 * colorSaturation);
    RgbColor num3(0.25 * colorSaturation, 0, 0.75 * colorSaturation);
    HslColor hslRed(red);
    HslColor hslGreen(green);
    HslColor hslBlue(blue);
    HslColor hslWhite(white);
    HslColor hslBlack(black);
    #define ledPower 2
    #define BottomA 35
    #define BottomB 27
    void ledcAnalogWrite(uint8_t channel, uint32_t value)
        // calculate duty, 8191 from 2 ^ 13 - 1 (2 ^ LEDC_TIMER_13_BIT - 1)
        //value_MAX = 255
        uint32_t duty = (8191 / 255) * value;
        // write duty to LEDC
        ledcWrite(channel, duty);
    void setup()
        Serial.begin(115200); //Serial Port Config 115200-8-N-1
        while (!Serial)
            ; // wait for serial attach
        Serial.println();
        Serial.println("Initializing...");
        Serial.flush();
        // this resets all the neopixels to an off state
        strip.Begin();
        strip.Show();
        pinMode(ledPower,OUTPUT);
        pinMode(BottomA, INPUT);
        pinMode(BottomB, INPUT);
        digitalWrite(ledPower, HIGH);
        // strip.SetPixelColor(10, blue);
        // strip.SetPixelColor(11, blue);
        // strip.SetPixelColor(12, blue);
        // strip.SetPixelColor(13, blue);
        // strip.SetPixelColor(14, red);
        // strip.Show();
        // delay(1000);
        // int i;
        // for (i = 0; i <= PixelCount - 1; i++)
        //     strip.SetPixelColor(i, black);
        //     strip.Show();
    void loop()
        if (digitalRead(BottomA) == LOW)
            delay(10);
                strip.SetPixelColor(16, num1);
                strip.SetPixelColor( 7, num2);
                strip.SetPixelColor(18, num3);
                strip.Show();
            else
            int i;
            Serial.println("Turn Off");
                strip.SetPixelColor(i, hslBlack);
                strip.Show();
Press three lights and loose and go out,github url
