Audio on Banana Pi M2 Zero?
(Simon Hilton) #1
Hi, So while there isnt a dedicated audio out on the board. I do know the chip can output audio, having looked at the datasheets for the SOC.
So the question is… Is there a unpopulated header I can solder to to get PCM audio? Or is there a guide to route audio through the GPIO?
(ZB) #2
hello, I just checked, you could use PCM0 on 40pin, but before this, you need to change the gpio function in “sys_config.fex”. if you still have question, we could discuss this later.
(Simon Hilton) #3
Hi so i see PCM. But only 1 pin… Does that mean this is only capable of outputting mono sound?
I noticed the SPDIF pin, but id rather not have to add a decoder, as it just raises the costs… Is there anyway to get a stereo signal out?
