Searching testing people for hdmi + wifi in Kernel 4.16
(Frank W.) #1
we search people for testing new function before they get merged into main-branch to find out bugs.
Sourcecode (HDMI):
Sourcecode (WIFI):
compiled Kernel: https://drive.google.com/drive/folders/1dJPz1REuIQiVfY4XliGOmGSZVDgT80Yc
how to install new kernel: https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:kernel#compiled_414x
regards Frank
(Frank W.) #2
previous discussion: Hdmi in uboot and linux
some info about (e.g. how to set resolution in uenv.txt) in my wiki: http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:hdmi
tested resolutions
working:
  • 1080p (frank-w, fb-console + xserver)
  • 1280x1024@60Hz (frank-w, fbconsole)
  • 1024x768@75 and 1280x1024(@75) (alex-r, fb-console+xserver)
not working:
  • 720p -> (frank-w, fbconsole)
  • 1024x768@60hz (frank-w,fbconsole, hsync to high)
  • 800x600@60hz (frank-w, fbconsole, fuzzy image)
  • 640x480@60hz (frank-w, fbconsole, hsync to high)
(Frank W.) #3
I have uploaded combined kernel (hdmi+wlan)…
driver is also ported to 4.14 in branch 4.14-hdmi
Please give us the following information:
  • kernel used (4.14/4.16)
  • operation system (debian/ubuntu with version)
  • resolutions and frequency (vsync)
  • adapters used (dvi/vga) if any
  • tested function (fbconsole/xorg)
  • problems
BPI-R2 OpenWrt(LEDE) Souce code : 2018-04-11
#4
1024x600 Not working As the version 4.4 do the same.
but 1280x800 Works fine.
(Frank W.) #5
Do you use 1024x600 direct (hdmi-hdmi,without adapter)? Does this resolution work with other client on same monitor? What is your vsync (hz)
#6
Yes just HDMI to HDMI cable,if I use 1024x600@75 ,it results more strange mode(401x600@75). At Windows I can manually set the resolution and it works fine. At Linux PC ,it is plug and play. At my raspberry Pi …it just output 512x600,without tear.
(Frank W.) #7
you set it via uEnv.txt (video=) or how do you set it?
#8
I set it via uEnv.txt
(Alex R.) #9
I’ve tested usin HDMI connection:
640x480 both 75 and 60 Hz - Ok (fb and Xorg)
800x600 both 75 and 60 Hz - Not Ok, Monitor detects resolution as 400x600, image is broken
1024x768 both 75 and 60 Hz - Ok
1280 x1024@75Hz -Ok
1600x900@60Hz - Ok
1440x900@60Hz - Ok
1920x1080@60Hz(native, selected by default) - Ok
I cant test VGA as I don’t have VGA cable. :frowning:
P.S. Tested on both 4.16, and 4.14 (frank’s 4.14-hdmi branch) kernels
Kernel 4.19-rc1 for testers
(Alex R.) #10
I’ve tested 1024x600@75: It’s don’t works. Resolution detects as 256x600 image is broken, and looks very similar to @tinylib’s photo.
New photo by Alexander Ryabchenko New photo by Alexander Ryabchenko
(Frank W.) #11
@Ryder.Lee any idea how to fix the resolution and the hsync-problem?
#12
kernel used 4.16
operation system debian/stretch)
resolutions and frequency (vsync) fbconsole 1920x1080@60
xorg 1920x1080 & 1600x1200 & 1680x1050 & ......60Hz
adapters used no
tested function fbconsole & xorg
problems
hdmi no
but
[    6.447454] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus/switch@0[0]' - status (0)
[    6.468859] gpio gpiochip0: Persistence not supported for GPIO 33
[    6.515841] mdio_bus dsa-0.0: GPIO lookup for consumer reset
[    6.531183] mdio_bus dsa-0.0: using lookup tables for GPIO lookup
[    6.531197] mdio_bus dsa-0.0: lookup for GPIO reset failed
[    6.727284] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mdio-bus/switch@0/ports/port@6/fixed-link[0]'
[    6.778947] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus/switch@0/ports/port@6[0]'
at times
[  584.701629] ata1.00: exception Emask 0x10 SAct 0x4 SErr 0x280100 action 0x6 frozen
[  584.709355] ata1.00: irq_stat 0x08000000, interface fatal error
[  584.715429] ata1: SError: { UnrecovData 10B8B BadCRC }
[  584.720659] ata1.00: failed command: READ FPDMA QUEUED
[  584.725913] ata1.00: cmd 60/00:10:00:97:f0/01:00:0e:00:00/40 tag 2 ncq dma 131072 in
[  584.725913]          res 40/00:10:00:97:f0/00:00:0e:00:00/40 Emask 0x10 (ATA bus error)
[  584.741911] ata1.00: status: { DRDY }
[  584.745646] ata1: hard resetting link
[  594.742279] ata1: softreset failed (1st FIS failed)
[  594.747259] ata1: hard resetting link
[  604.742492] ata1: softreset failed (1st FIS failed)
[  604.747466] ata1: hard resetting link
[  639.741993] ata1: softreset failed (1st FIS failed)
[  639.746974] ata1: limiting SATA link speed to 3.0 Gbps
[  639.752232] ata1: hard resetting link
[  644.752017] ata1: softreset failed (1st FIS failed)
[  644.756992] ata1: reset failed, giving up
[  644.761068] ata1.00: disabled
[  644.764188] ata1: EH complete
[  644.767351] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.767355] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.767369] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 0e f0 97 00 00 01 00 00
[  644.775686] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x2a 2a 00 0e e7 98 38 00 00 08 00
[  644.775700] print_req_error: I/O error, dev sda, sector 250058808
[  644.784030] print_req_error: I/O error, dev sda, sector 250648320
[  644.791706] Buffer I/O error on dev sda2, logical block 7, lost async page write
[  644.819362] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.827704] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 0e f0 98 00 00 01 00 00
[  644.829333] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.829337] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.829348] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 0e f0 97 00 00 00 08 00
[  644.829353] print_req_error: I/O error, dev sda, sector 250648320
[  644.829476] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.829486] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 0e f0 97 00 00 00 08 00
[  644.829490] print_req_error: I/O error, dev sda, sector 250648320
[  644.835470] print_req_error: I/O error, dev sda, sector 250648576
[  644.843789] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x2a 2a 00 10 67 98 00 00 00 10 00
[  644.852204] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.856161] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.856175] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 19 ad cb 80 00 00 70 00
[  644.856182] print_req_error: I/O error, dev sda, sector 430820224
[  644.858398] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.858410] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 19 ad cb 80 00 00 08 00
[  644.858416] print_req_error: I/O error, dev sda, sector 430820224
[  644.858534] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  644.858544] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 19 ad cb 80 00 00 08 00
[  644.858549] print_req_error: I/O error, dev sda, sector 430820224
[  644.859843] print_req_error: I/O error, dev sda, sector 275224576
[  644.866066] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x2a 2a 00 16 2b 9f 58 00 00 98 00
[  644.867328] print_req_error: I/O error, dev sda, sector 430740952
[  644.874453] Buffer I/O error on dev sda2, logical block 3145728, lost async page write
[  644.874476] Buffer I/O error on dev sda2, logical block 3145729, lost async page write
[  644.882403] Aborting journal on device sda2-8.
[  644.888601] Buffer I/O error on dev sda2, logical block 3153953, lost async page write
[  644.894900] Buffer I/O error on dev sda2, logical block 15237120, lost sync page write
[  645.034724] Buffer I/O error on dev sda2, logical block 3153956, lost async page write
[  645.034759] JBD2: Error -5 detected when updating journal superblock for sda2-8.
[  645.034768] EXT4-fs error (device sda2) in ext4_reserve_inode_write:5764: Journal has aborted
[  645.035001] EXT4-fs (sda2): Remounting filesystem read-only
[  645.042915] Buffer I/O error on dev sda2, logical block 12582913, lost async page write
[  645.050726] EXT4-fs (sda2): ext4_writepages: jbd2_start: 4095 pages, ino 5637663; err -30
[  645.059194] Buffer I/O error on dev sda2, logical block 12582928, lost async page write
[  645.097110] Buffer I/O error on dev sda2, logical block 12582944, lost async page write
[  645.113025] EXT4-fs warning (device sda2): ext4_end_bio:323: I/O error 10 writing to inode 5637663 (offset 0 size 0 starting bloc
k 31274641)
[  645.133573] Buffer I/O error on device sda2, logical block 17296
[  645.245352] EXT4-fs error (device sda2): ext4_find_entry:1437: inode #4196067: comm aptitude: reading directory lblock 0
[  645.264372] EXT4-fs (sda2): previous I/O error to superblock detected
[  668.108211] scsi_io_completion: 26 callbacks suppressed
[  668.108234] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  668.137783] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 10 68 99 20 00 00 08 00
[  668.153399] print_req_error: 29 callbacks suppressed
[  668.153404] print_req_error: I/O error, dev sda, sector 275290400
[  668.180684] EXT4-fs warning (device sda2): htree_dirblock_to_tree:978: inode #786443: lblock 0: comm aptitude: error -5 reading d
irectory block
[  668.202310] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  668.219044] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 16 ed 7c 80 00 00 48 00
[  668.235188] print_req_error: I/O error, dev sda, sector 384662656
[  668.249973] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[  668.266886] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 16 ed 7c 98 00 00 08 00
[  668.283209] print_req_error: I/O error, dev sda, sector 384662680
(Frank W.) #13
Sata-issue seems to be this: SATA Kernel 4.14 failed command: IDENTIFY DEVICE
Need pcie-patch…https://github.com/garywangcn/bpi-r2_lede/blob/bpi-r2-on-lede-v1/target/linux/mediatek/patches-4.9/0073-mtk-pcie-bug-fix.patch
i’ve seen the others,but currently no idea how to fix. These should not occour in 4.14…4.16 is no longtime and will be end-of-life soon
(Alex R.) #14
I’ve tested VGA agapter - same results. X*600 resolutions don’t work.
(Frank W.) #15
can you please test 1024x768@60 over vga and look at the hsync?
(Frank W.) #16
@jofri can you please try last 4.16-main for the sata-issue? i have removed the pcie-nodes and re-added them with the patch-file i’ve used for 4.14 (which seems to fix that issue), not much changes, but maybe it’s enough
#17
Actually, X * 600 are not standard DMT or CEA HDMI resolutions but DVI.
HDMI spec:
MT7623 HW could support these DVI resolutions but I’m not sure whether the related functionality has been implemented or not.
(Alex R.) #18
Hi, I’ve testet 1024x768@60 over vga, and I got hsync 48kHz
(Frank W.) #19
strange that it does not work in my tests…or only partial after killing xorg first time
@Ryder.Lee can you explain the values for hsync-start and hsync-end because these do not match the expected values
#20
I don’t get your points (hsync-start and hsync-end because these do not match the expected values) ?
