skype
(廷 李)
Use “2020-05-08-ubuntu-18.04.3-bpi-r64-5.4-sd-emmc.img.zip” firmware。
Power-on default startup settings,But ping error:
ping 192.168.1.1 connect: Network is unreachable
I modified the configuration:
iface eth0 inet static
address 192.168.1.3
netmask 255.255.255.0
gateway 192.168.1.1
But still useless。。。
frank-w
(Frank W.)
2
please print output of “ip a”
just to check if you use a dsa-driver
skype
(廷 李)
3
I have solved it, thanks. This is how I do it。
ip a
ip addr add 192.168.1.3/24 dev lan3
ip link set dev lan3 up / down
ip address show dev lan3
ip route add default via 192.168.1.1
ip addr flush eth0
or
/etc/network/interfaces
iface lan3 inet static
address 192.168.1.3
#gateway 192.168.1.1
network 192.168.1.3
frank-w
(Frank W.)
4
So your image is using dsa-driver…put eth0 up and configure lanX/wan like you do above. And like it’s described in my wiki
