frank-w
(Frank W.)
Hi
i recognized out-of-memory messages in dmesg, and guess the memory-block in dts is wrong
actual value is afair changed by a patch from lede (in mainline same value is used but in 4.14 it is 0x40000000)
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/arch/arm/boot/dts/mt7623n-bananapi-bpi-r2.dts?h=v4.14.64#n102
@moore @linkerosa @Ryder.Lee
can anybody explain me the values? how is size of memory calculated
regards Frank
base = 0x80000000
size = 0x80000000 for (2GB RAM)
frank-w
(Frank W.)
3
So it should be correct…any suggestion to prevent oom-messages? I tried vm-settings in /etc/sysctl.conf
# Prevent OOM killer (Out of Memory) which causes the server to crash
vm.overcommit_memory = 2
vm.overcommit_ratio = 80
moore
(moore liu)
4
It may caused by …
1.try to run too many features in run time
2.app/driver has memory leak issue
I will suggest to dump free memory regularly after system boot up to see the trend of free memory, thanks.
frank-w
(Frank W.)
5
System should swap if there is too few memory.
I have this issue after near 15 days (in dmesg)
And aditional to router function i have 2 lxc vms running (webserver+mysql,vncserver+firefox)
Which command do you suggest to get (per-app) memory usage (ps?)?
moore
(moore liu)
6
linux kernel will try to kill applications to free more memory to satisfy the need. you can use ps or top command to show the memory usage, thanks.
ps -eo pid,ppid,cmd,%mem,%cpu --sort=-%mem | head
top -b -o +%MEM | head -n 20
