Hello,
I’ve tried to use crytodev and I strangly I didn’t see any hardware driver. I build openssl from the debian repository and I added some patch from openwrt (available here: https://github.com/openwrt/openwrt/tree/master/package/libs/openssl/patches).
After installing the openssl and libssl package I can see a lot of information about each driver in cryptodev:
[root@r2] kernel # openssl engine -t -c -vv -pre DUMP_INFO devcrypto
(devcrypto) /dev/crypto engine
Information about ciphers supported by the /dev/crypto engine:
Cipher DES-CBC, NID=31, /dev/crypto info: id=1, driver=cbc(des-generic) (software)
Cipher DES-EDE3-CBC, NID=44, /dev/crypto info: id=2, driver=cbc(des3_ede-generic) (software)
Cipher BF-CBC, NID=91, /dev/crypto info: id=3, CIOCGSESSION (session open call) failed
Cipher CAST5-CBC, NID=108, /dev/crypto info: id=4, CIOCGSESSION (session open call) failed
Cipher AES-128-CBC, NID=419, /dev/crypto info: id=11, driver=cbc-aes-mtk (software)
Cipher AES-192-CBC, NID=423, /dev/crypto info: id=11, driver=cbc-aes-mtk (software)
Cipher AES-256-CBC, NID=427, /dev/crypto info: id=11, driver=cbc-aes-mtk (software)
Cipher RC4, NID=5, /dev/crypto info: id=12, CIOCGSESSION (session open call) failed
Cipher AES-128-CTR, NID=904, /dev/crypto info: id=21, driver=ctr-aes-mtk (software)
Cipher AES-192-CTR, NID=905, /dev/crypto info: id=21, driver=ctr-aes-mtk (software)
Cipher AES-256-CTR, NID=906, /dev/crypto info: id=21, driver=ctr-aes-mtk (software)
Cipher AES-128-ECB, NID=418, /dev/crypto info: id=23, driver=ecb-aes-mtk (software)
Cipher AES-192-ECB, NID=422, /dev/crypto info: id=23, driver=ecb-aes-mtk (software)
Cipher AES-256-ECB, NID=426, /dev/crypto info: id=23, driver=ecb-aes-mtk (software)
Cipher CAMELLIA-128-CBC, NID=751, /dev/crypto info: id=101, CIOCGSESSION (session open call) failed
Cipher CAMELLIA-192-CBC, NID=752, /dev/crypto info: id=101, CIOCGSESSION (session open call) failed
Cipher CAMELLIA-256-CBC, NID=753, /dev/crypto info: id=101, CIOCGSESSION (session open call) failed
[Success]: DUMP_INFO
[ available ]
USE_SOFTDRIVERS: specifies whether to use software (not accelerated) drivers (0=use only accelerated drivers, 1=allow all drivers, 2=use if acceleration can't be determined) [default=2]
CIPHERS: either ALL, NONE, or a comma-separated list of ciphers to enable [default=ALL]
DUMP_INFO: dump info about each algorithm to stderr; use 'openssl engine -pre DUMP_INFO devcrypto'
Generally we get something like this (as mentionned here https://openwrt.org/docs/techref/hardware/cryptographic.hardware.accelerators):
Cipher AES-192-CBC, NID=423, /dev/crypto info: id=11, driver=mv-cbc-aes (hw accelerated)
Cipher AES-256-CBC, NID=427, /dev/crypto info: id=11, driver=mv-cbc-aes (hw accelerated)
So as I understand there are not hardware acceleration. Note that I’m using the kernel 5.4 from the @frank-w repository and I build cryptodev v1.11 from the official repository.
