New OpenWrt Image "squashfs-sysupgrade-emmc.bin.gz" for Bpi-R64 on development brunch
On development brunch OpenWrt appear new image: openwrt-mediatek-mt7622-bpi_bananapi-r64-rootdisk-squashfs-sysupgrade-emmc.bin.gz . In “.gz” archive located “.bin” image ~500MB. But I dont know how use this image. Can someone explain how use it.
Take a look to https://git.openwrt.org/?p=openwrt/openwrt.git;a=blob_plain;f=target/linux/mediatek/image/gen_mt7622_emmc_img.sh and https://git.openwrt.org/?p=openwrt/openwrt.git;a=blob_plain;f=target/linux/mediatek/files-5.4/arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64-rootdisk.dts
It seems that image expects eMMC having following partitions: p0/p1/p2/p3/p4 - service partitions as usual, p5 - kernel, 20M (40960 sectors), p6 - recovery initrd, 10M (20480 sectors), p7 - rootfs.
That image should be written starting from p5 partition, you can do it by u-boot (write kernel image to flash) or using dd if=rootdisk-squashfs-sysupgrade-emmc.bin of=/dev/mmcblk0 bs=512 seek=4096
P.S: you should change device to “Banana Pi R64 (rootdisk)” in openwrt’s menuconfig
Hi, it boot like this, I switch the boot select to 0
Looks like the image is not booted…only preloader
Thanks to remind. I’ll try binwalk and add preloader.
I boot this image from emmc:
1. use https://github.com/m2LiJu/BPI_R64_OpenWRT   install_emmc.sh  to init the emmc.
2. dd if=rootdisk-squashfs-sysupgrade-emmc.bin of=/dev/mmcblk0 bs=512 seek=4096
there is some dmesg:
[    0.000000] Linux version 5.4.40 (root@) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r13219-0fed36dd48)) #0 SMP Tue May 12 10:36:28 2020
[    0.000000] Machine model: Bananapi BPI-R64
[    1.068497] mtk-pcie 1a140000.pcie: Port1 link down
[    1.073490] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[    1.079672] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.085156] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[    1.092028] pci_bus 0000:00: scanning bus
[    1.096065] pci 0000:00:00.0: [14c3:3258] type 01 class 0x060400
[    1.102130] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x1ffffffff 64bit pref]
[    1.110934] pci_bus 0000:00: fixups for bus
[    1.115120] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[    1.121818] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.129848] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[    1.136647] pci_bus 0000:01: scanning bus
[    1.140780] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[    1.147011] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[   12.049489] mt7615e 0000:01:00.0: assign IRQ: got 139
[   12.054593] pci 0000:00:00.0: enabling device (0000 -> 0002)
[   12.060257] pci 0000:00:00.0: enabling bus mastering
[   12.065232] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[   12.071312] mt7615e 0000:01:00.0: enabling bus mastering
[   12.078419] mt7615e 0000:01:00.0: Invalid MAC address, using random address 06:88:be:82:7c:7b
[   12.088968] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   12.110076] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 2e:df:a6:55:6c:fa
[   12.120639] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   12.146341] PPP generic driver version 2.4.2
[   12.151905] NET: Registered protocol family 24
[   12.157687] usbcore: registered new interface driver qmi_wwan
[   12.163642] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[   12.163642]
[   12.175154] kmodloader: done loading kernel modules from /etc/modules.d/*
[   12.193244] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[   13.706453] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[   33.763113] mt7615e 0000:01:00.0: Message -4294967280 (seq 1) timeout
[   33.769564] mt7615e 0000:01:00.0: Failed to get patch semaphore
root@OpenWrt:/etc/config# iw dev
phy#1
        Interface wlan1
                ifindex 8
                wdev 0x100000002
                addr 2e:df:a6:55:6c:fa
                ssid OpenWrt
                type AP
                channel 11 (2462 MHz), width: 20 MHz, center1: 2462 MHz
                txpower 6.00 dBm
                multicast TXQ:
                        qsz-byt qsz-pkt flows   drops   marks   overlmt hashcol tx-bytes        tx-packets
                        0       0       0       0       0       0       0       0               0
phy#0
        Interface wlan0
                ifindex 7
                wdev 0x2
                addr 06:88:be:82:7c:7b
                type AP
                txpower 6.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0               0
according to http://forum.banana-pi.org/t/bpi-r64-openwrt-kernel-5-4-40-running-from-emmc/11087/85
there still be a long way to make this board run as a normal router.
please apply this series https://patchwork.kernel.org/project/linux-mediatek/list/?series=294647
