New image :2018-01-04-kali-xfce-desktop-v1.0-sd-emmc for banana pi
(bpi team) #1
BPI-M2+ Kali image 2018-01-04
2018-01-04-kali-xfce-desktop-v1.0-bpi-m2p-sd-emmc.img.zip
Google Drive:
https://drive.google.com/file/d/1z2OgEQFwLr4N0nM1qW-JNeKnco_hrYyT/view?usp=sharing
Baidu cloud:
https://pan.baidu.com/s/1qXNMHxM
MD5: 81308dadfb4b69e23b0cc513a34e5f49
BPI-M2 Ultra/Berry Kali image 2018-01-04
2018-01-04-kali-xfce-desktop-v1.0-bpi-m2u-sd-emmc.img.zip
Google Drive:
https://drive.google.com/file/d/1vvarGORZakY0esNaEBkC-KmmpDIQcwLN/view?usp=sharing
Baidu cloud:
https://pan.baidu.com/s/1c2HFP1e
MD5: 3f436a0fe437cca9c3f5417297ab538a
BPI-M3 Kali image 2018-01-04
2018-01-04-kali-xfce-desktop-v1.0-bpi-m3-sd-emmc.img.zip
Google Drive:
https://drive.google.com/file/d/1Y01Qmuy5qzRTJWPZ5ouJQCXFQpBl2nsV/view?usp=sharing
Baidu cloud:
https://pan.baidu.com/s/1jHI9qU6
MD5: 314b13ca82114a24fe6c8e02f442f798
BPI-M64 Kali image 2018-01-04
2018-01-04-kali-xfce-desktop-v1.0-bpi-m64-sd-emmc.img.zip
Google Drive:
https://drive.google.com/file/d/1AuZsnBSyKgk58TIP1is9XVVSzkRtpeo6/view?usp=sharing
Baidu cloud:
https://pan.baidu.com/s/1jIkZAdw
MD5: daad3c0c88dc872c036df03966cd0e28
BPI-R2 Kali image 2018-01-04
2018-01-04-kali-xfce-desktop-v1.0-bpi-r2-sd-emmc.img.zip
Google Drive:
https://drive.google.com/file/d/1fDo8ITziO3tIMQ_sXT7aSiKv1k1NKdxV/view?usp=sharing
Baidu cloud:
https://pan.baidu.com/s/1nuLQWcT
MD5: 88f146d09b5fbe7b87b5c08263df1f62
(Brian Beuken) #2
Which image for the m2 zero?
(bpi team) #3
not ready yet ,will update soon.
(pendik) #4
how to change 720p to 1080p? thnx
(andrefleitao) #5
Hi. I installed this 2017-12-03-Armbian image.
I’m trying to blink a led using this library https://github.com/LeMaker/WiringBP1
bpibpi.jpg1023x767 208 KB Location of the example file: root@bananapim2zero:~/WiringBP/examples/blink.c I manage to compile the blink.c file using this command
gcc blink.c -o blink -lwiringPi -lpthread
executed like this
sudo chmod +x ./blink
sudo ./blink
The string appears: Raspberry Pi blink
…but nothing happens with the led. And yes the led and resistor are properly connected. If i change the red led from the GPIO to the 5V the LED turns on. I tested using raspberry pi zero and the setup works. How do i blink a led using BPI-M2 Zero? Can you suggest other library? The GPIO is not working correctly with this image? I’d like to use this BPI board for my company robotic projects.
(Maxim Alexandrovich Gusev) #6
any one can help me to boot this version of Kali with LCD7. i had tryied to copy script.bin.lcd7-gt to script.bin and env from lcd7-gt to /boot/bananapi/bpi-m3/linux and it does not helps to turn on 7" LCD display.
