MultiQB project: Next Generation Media Router
(bpi team) #1
MultiQB project design:
MultiQB project hardware:
Hardware Specification
  1. SIZE: two-deck, 88x88 mm
  2. CPU Chipset: A20 ARM Cortex™-A7 Dual-Core 1 GHz
  3. GPU Chipset: ARM Mali400MP2Complies with OpenGL ES 2.0/1.1
  4. Memory: 1 GB DDR3
  5. Storage Slot: micro SD Card 16G Bytes
  6. Network Ethernet: – 10/100/1000Mbps WAN x 1 – 10/100/1000Mbps LAN x 4
  7. WIFI: – 3x 2.4GHz, Support IEEE 802.11b/g/n,Up to 300Mbps – 1x 5GHz,Support IEEE 802.11a/n/ac,Up to 433Mbps – External High-Gain Antenna 2.4GHz x3,5GHz x1 –WIFI model MT7632 or AP6335
  8. 4G LTE – SimCom Sim7100C, FDD B3 LTE 1800, – Model SIM7100C – External High-Gain Antenna 4G x1
  9. USB: USB Host 2.0 x 1
  10. CAMERA: Camera x 1, Screen resolution HD 1280x720 pixels, 30 FPS, UVC H.264 encoding technology, CSI Connector
  11. AUDIO Input: Microphone x 1
  12. VIDEO Outputs: HDMI out x 1
  13. AUDIO Outputs: 3.5mm Jack and HDMI
  14. SPEAKER: BP-5032-44, 1xSpeaker, Diameter 50mm, Depth 32mm, Power 4w, Impedance 4±15%Ω
  15. KEY: POWER KEY x 1 Touch Sensor Power Button RESET KEY x 1
  16. LED: RJ45 LED (Upload, Download) x 5 WIFI LED (2.4G, 5.8G) x 2 POWER STATUS LED x 1 GPIO LED (4 pins LED) x 1 USB LED x 1 CAMERA LED x 1 4G LED x 1 AUDIO LED x1 MICROPHONE LED x1
  17. Debugging: Serial Console, JTAG
  18. Reserved Pin: GPIO PIN x 26, UART, 12C bus, SPI bus with two chip selects, CAN bus, ADC, PWM, +5V, +3.3V, GND
  19. IR Receiver: x1
  20. Power Source: Micro-USB Power DC 5V/2A
  21. Battery: Li-ION 4400 mAh 3.7V, Battery Connector: x1
  22. Adaptor: DC Adaptor 5V/2A with micro-USB cable
run system : Andorid or OpenWRT
MultiQB official website:
http://www.multiqb.com/
MultiQb Media Router datasheet:
https://drive.google.com/file/d/0B4PAo2nW2Kfnb3BQcFR3S3dvdEE/view?usp=sharing
BPI-4G LTE module for banana pi (USB interface)
(bpi team) #2
if anyone like this product ,please contact us .
(etyrnal) #3
I’m Interested. How much?
(bpi team) #4
you can send mail to jasonye@banana-pi.com ask for support.
(bpi team) #5
more aout BPI 4.0 Service :
http://wiki.banana-pi.org/Successful_case
