MineOS 'bananacraftv1.img' for the Banana PI -- piefacewow
piefacewow share it
MineOS ‘bananacraftv1.img’ for the Banana PI – piefacewow
Scrubbed image for a small download size of 344MB MD5 2a3c00c75c8fc593f61e540686d40aca
MineOS a one-stop answer to Minecraft hosting, enthusiasts can successfully host Minecraft on Linux or BSD-based platforms.
Features: Web user interface with modern Knockout templating Scheduled backups, archives, and restarts Command-line scriptable Leverages host system’s existing user passwords (/etc/shadow) and HTTPS Shared administration functionality using group permissions Works on Linux and BSD
Recommended server settings:
WebUI: https://your_pi_ip:8080 Lighttpd: http://localhost/jar_name.jar [for local hosting jars/incudes for profiles/servers]/var/www/
#When creating a server using the WebUI do these settings
-Xms 256 -Xmx 496
# /var/games/minecraft/servers/[servername]/server.properties
# Default is 10, 3-5 ideal for bPi
view-distance=4
# Set false for 'offline' (cracked mode) WARNING OFFLINE MODE HAS NO USER AUTHENTICATION!
online-mode=true
# You need to agree to the EULA in order to run the server. Go to eula.txt /var/games/minecraft/servers/[servername]/eula.txt [=true] or agree using the WebUI under 'Server Settings'.
Minecraft server WebUI group:
Group Ownership: nannergroup [select when creating server]
8GB “Room to Host!” Image Build Base utilizing “Bananian Linux”. Image can be resized using ‘bananian-config’.
https://www.bananian.org/
Users:
root, bananacraft passwd: bananapi
Q/A
Can I use WiFi?
Yes! %sudo wicd-curses
Can I use plugins?
Yes! add them here:
/var/games/minecraft/servers/[servername]/plugins/
Readme Download MD5
