i’m trying to make a 4.9-repo for comparing with 4.14 (to include missing festures like hnat, 2nd gmac). till patch 59 all ok. but patch 0060 needs existing mt7623n-bananapi-bpi-r2.dts which was not created till this point, so this patch failes
https://github.com/frank-w/BPI-R2-4.14/tree/4.9_fully_patched edit: source-tree is a bit confusing…it’s not a standard-4.9-source it’s modified (at least dts for bpi is added). copied that dts and the patch works
seems that it’s not the only file:
patch -p1 < patches_from_lede/0066-backport-mtk-crypto-from-4.13-rc1.patch
patching file arch/arm/boot/dts/mt7623.dtsi
can't find file to patch at input line 29
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|Index: linux-4.9.44/drivers/crypto/mediatek/mtk-aes.c
seems that these file must be integrated into 4.9.44 first before applying the patches:
regards Frank
