I will release my tool, it can do some debugging stuff from userspace on sfp modules via i2c.
USE WITH CAUTION!!!
Features:
i2cdump
eeprom dump, showing different pages
edit eeprom data
read/write using protocols: byte, c22m, c22r, c45, rollball
Extract rollball password
Brute force attack eeprom
It can edit eeprom data of the OEM modules so it can match another string, so you do not need to add another quirk if the same hardware already has a quirk but uses different id string.
Is it possible to add temperature limits? I have one module with the wrong minimum temperature limit. It issues an alarm because the minimum temperature limit is set at 127 degrees Celsius.
Yes it worked, you need a password to change the limits.
Thanks to the author!
Here’s the broken limit
root@OpenWrt:/tmp# ethtool -m eth2
Identifier : 0x03 (SFP)
Connector : 0x07 (LC)
Transceiver codes : 0x10 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Transceiver type : 10G Ethernet: 10G Base-SR
Encoding : 0x06 (64B/66B)
BR, Nominal : 10300MBd
Length (SMF,km) : 0km
Length (SMF) : 0m
Length (50um) : 80m
Length (62.5um) : 20m
Length (Copper) : 0m
Length (OM3) : 300m
Laser wavelength : 850nm
Vendor name : OEM
Vendor OUI : 00:00:00
Vendor PN : SFP-10G-T
Vendor rev : 1
Option values : 0x00 0x1a
Option : RX_LOS implemented
Option : TX_FAULT implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : C2312180141
Date code : 231218
Optical diagnostics support : Yes
Laser bias current : 6.000 mA
Laser output power : 0.5000 mW / -3.01 dBm
Receiver signal average optical power : 0.0000 mW / -inf dBm
Module temperature : 35.53 degrees C / 95.95 degrees F
Module voltage : 3.3345 V
Alarm/warning flags implemented : Yes
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : Off
Laser output power high warning : Off
Laser output power low warning : Off
Module temperature high alarm : Off
Module temperature low alarm : On
Module temperature high warning : Off
Module temperature low warning : Off
Module voltage high alarm : Off
Module voltage low alarm : Off
Module voltage high warning : Off
Module voltage low warning : Off
Laser rx power high alarm : Off
Laser rx power low alarm : On
Laser rx power high warning : Off
Laser rx power low warning : On
Laser bias current high alarm threshold : 15.000 mA
Laser bias current low alarm threshold : 1.000 mA
Laser bias current high warning threshold : 13.000 mA
Laser bias current low warning threshold : 2.000 mA
Laser output power high alarm threshold : 1.9952 mW / 3.00 dBm
Laser output power low alarm threshold : 0.1584 mW / -8.00 dBm
Laser output power high warning threshold : 1.5848 mW / 2.00 dBm
Laser output power low warning threshold : 0.1778 mW / -7.50 dBm
Module temperature high alarm threshold : 95.00 degrees C / 203.00 degrees F
Module temperature low alarm threshold : 127.01 degrees C / 260.62 degrees F
Module temperature high warning threshold : 90.00 degrees C / 194.00 degrees F
Module temperature low warning threshold : -45.00 degrees C / -49.00 degrees F
Module voltage high alarm threshold : 3.6000 V
Module voltage low alarm threshold : 3.0000 V
Module voltage high warning threshold : 3.5000 V
Module voltage low warning threshold : 3.1000 V
Laser rx power high alarm threshold : 1.1220 mW / 0.50 dBm
Laser rx power low alarm threshold : 0.0199 mW / -17.01 dBm
Laser rx power high warning threshold : 1.0000 mW / 0.00 dBm
Laser rx power low warning threshold : 0.0223 mW / -16.52 dBm
And here is the corrected one
Length (SMF) : 0m
Length (50um) : 80m
Length (OM3) : 300m
Vendor name : OEM
Vendor rev : 1
BR margin, max : 0%
BR margin, min : 0%
Date code : 231218
Module temperature : 35.98 degrees C / 96.77 degrees F
Module voltage : 3.3300 V
Module temperature low alarm : Off
Module temperature low alarm threshold : -50.00 degrees C / -58.00 degrees F
That’s ok, I also had some, for aarch64, armv7h and x86_64. But the code is still changing quite often, so for now, I have removed them, since it is still an alfa/beta version.
Would this tool also be able to show me, why I don’t see that full output from ethtool? Like if there is some issue with the i2c configuration or something?
Because I’m not seeing the power usage and temperature and all the other diagnostics data of my module, even though according to the manufacturer, it supports DOM.
