How to : Use bpi-update command to update kernel image
Step1: Update bpi-tools
$ git clone https://github.com/BPI-SINOVOIP/bpi-tools.git
$ cd bpi-tools
$ sudo ./bpi-tools -u -U
Step 2: Check bpi-tools version
$ bpi-tools -v
Step 3: Use bpi-update to update kerenl
$ mkdir update_file $ cd update_file
BPI-M2U
$ sudo bpi-update -c bpi-m2u.conf
BPI-M2P
$ sudo bpi-update -c bpi-m2p.conf
BPI-M3
$ sudo bpi-update -c bpi-m3.conf
Can this be run from any of the supplied images (Ubuntu etc) using ssh?
you can use ssh to try it .
I guess there is a small typo there should be a new line before the second $
Hi, I am using BPI-M2 zero hardware, and the OS installed is Raspbian stretch kernel version is 4.4 which is found in this website https://wiki.banana-pi.org/Banana_Pi_BPI-M2_ZERO. When I try to run this command “sudo apt-get install linux-tools-generic”, it throw the error “unable to locate the package linux-tools-generic”. Is this because of the kernel version is too old? If it is, how can I update the kernel version? In this topic, @BPI_Justin didn’t included the device BPI-M2 zero for update the kernel. Thanks in Advance.
Hi. Did you find a solution? I am having the same problem.
Just change sudo bpi-update -c bpi-m3.conf in sudo bpi-update -c bpi-m2.conf
