How to use bpi-copy command (Burning images to EMMC , Copying data from SD-Card/EMMC to be Images)
(BPI_Justin) #1
usage: bpi-copy bpi-copy IMGFILE bpi-copy IMGDIR bpi-copy IMGFILE DEVICE bpi-copy DEVICE IMGFILE
  1. Download BPI-Tools , please run the following command
wget https://github.com/BPI-SINOVOIP/BPI-files/raw/master/debs/bananapi-bpi-tools_1.0.3_armhf.deb
  1. Set up development environment
    2-1: On X86-PC (Ubunut 12.04)
    sudo echo “foreign-architecture armhf” >> /etc/dpkg/dpkg.cfg.d/multiarch
    2-2 :On X86-PC (Ubunut 14.04)
    sudo dpkg --add-architecture armhf
    2-3 :On BananaPI M3/M2Plus do nothing
  2. Install BPI-Tools
sudo dpkg -i bananapi-bpi-tools*.deb
  1. Creat a folder of BPI-Tools
    mkdir BPI-Tools
cd BPI-Tools
  1. Update BPI-Tools
sudo bpi-tools --upgrade
  1. Use bpi-copy commnad
    6-1: To burn into EMMC, please run the following command
    sudo bpi-copy < images file>
    6-2 :Copy data from SD-Card/EMMC to be Images
    sudo bpi-copy < device path> < xxxxx.img.zip>
    6-3 :To burn into certain device,please run the following command
    sudo bpi-copy < xxxxx.img.zip> < device path>
Video Demo (To burn into EMMC)
Video Demo ( Copy data from SD-Card/EMMC to be Images)
BPi-M3 new image: 2018-01-15-ubuntu-16.04-server-v1.0-bpi-m3mst-sd-emmc
Ubuntu 16.04 problems; eMMC, sensors
Fash image to eMMC
(zawier) #2
During:
I get:
pi@bpi-iot-ros-ai:~/BPI-Tools$ bpi-tools bpi-tools v1.0.6 usage: bpi-tools bpi-tools FILE bpi-tools --all | --update | --download | --version
bpi files: html> lang=en> charset=utf-8> name=viewport minimum-scale=1, 404 Found)!!1
arial,sans-serif}html{background:#fff;color:#222;padding:15px}body{margin:7% 0;max-width:390px;min-height:180px;padding:30px
href=//www.google.com/> That’s error. requested /host/0B6FbwMfcqfFZTUpocHhQbzZJSkk pi@bpi-iot-ros-ai:~/BPI-Tools$ sudo dpkg -i bananapi-bpi-tools*.deb dpkg: error processing archive bananapi-bpi-tools*.deb (–install): cannot access archive: No such file or directory Errors were encountered while processing: bananapi-bpi-tools*.deb pi@bpi-iot-ros-ai:~/BPI-Tools$ sudo dpkg -i bananapi-bpi-tools*.deb dpkg: error processing archive bananapi-bpi-tools*.deb (–install): cannot access archive: No such file or directory Errors were encountered while processing: bananapi-bpi-tools*.deb
Could you explain me what to do with that,please?
