updating from lts to lts is maybe possible but if you break it you have no working system…better is to create a new/fresh system and configure this leaving the old as backup till all is configured
for reading out board you can use devicetree if you have a kernel using this (most arm/arm64)
cat /sys/firmware/devicetree/base/compatible
in my case it shows
bananapi,bpi-r2mediatek,mt7623
if you have bananapi-r2 or r64 you can look in my wiki on how to create an ubuntu image, and only need to change it a bit to get 20.4 (focal)
If you still want armbian,you can look in their repo…maybe they have a focal image
Note i want to build up a NAS/ Samba server.;: can i do that with this UDoo quad - guess so
found the following specs
are they still correct - and do the describe the Rev D too!?
CPU NXP i.MX 6 ARM Cortex-A9 Quad core 1GHz
GPU Vivante GC 2000 + Vivante GC 355 + Vivante GC 320
Integrated accelerators for 2D, OpenGL® ES2.0 3D and OpenVG™
Atmel SAM3X8E ARM Cortex-M3 CPU (same as Arduino Due)
RAM DDR3 1GB
76 fully available GPIO: 62 digital + 14 digital/analog
Arduino-compatible R3 1.0 pinout
HDMI and LVDS + Touch
2 Micro USB (1 OTG type a+b)
2 USB type A (x2) and 1 USB connector (requires a specific wire)
Analog Audio and Mic
CSI Camera Connection
on board Micro SD card reader (boot device)
Input Voltage (recommended) 6-15 V
Ethernet RJ45 (10/100/1000 MBit)
WiFi Module
SATA
i guess so
and now i want to have a closer look at allnet - to see if /and where i get a operation system for this one
i don’t know this board, and here is R2/r64 thread of bananapi only. only the bananapi board can be posted here but in different section (@sinovoip can you change section to bananapi 1?). i had one old bananapi, but after this has some ethernet-issues i dropped it
