How to install official openwrt releases/19.07.4 to BPI-R2?
Is there anyone use official openwrt releases/19.07.4 on BPI-R2?
Is the internal wifi working properly?Can SATA be used properly?
Is there a simple way to quick install?
https://openwrt.org/toh/hwdata/sinovoip/sinovoip_banana_pi_r2 Unsupported Functions: HDMI WIFI
Can I use a wireless network card with usb interface for AP?
on r2 sata should work without problem as it works in mainline linux without any modification. as you found out internal wifi and hdmi is not included as it requires additional Patches which are not upstream (hdmi will be upstream with 5.10). USB-wifi should work if driver is compiled in
I am using LEDE-4.9.44(SNAPSHOT, r4773-2cb61a8).
root@LEDE:~# uname -a
Linux LEDE 4.9.44 #0 SMP PREEMPT Wed May 16 00:11:34 2018 armv7l GNU/Linux
root@LEDE:~#
Is there a simple way to quick install official 19.07.4?
