How to build yourself openwrt image for banana pi from github
(bpi team) #1
we test it with deepin2014(base on ubuntu14.04)
1,install depend package :
apt-get install subversion build-essential libncurses5-dev zlib1g-dev gawk git ccache gettext libssl-dev xsltproc unzip subversion file
2,get openwrt source code
git clone https://github.com/BPI-SINOVOIP/BPI-OpenWRT.git
3,enter openwrt dir:
cd BPI-OpenWRT
4,update package and install
./scripts/feeds update -a
./scripts/feeds install -a
5 Enter the customization interface:
please choose your need:
Target System default is BananaPi,its the only choice on that matte.,Please change the device selection under Target Profile. The OpenWrt image supports M1, M1+ and R1.
example : i need web and add chinese support
LuCI—> 1. Collections  ---> <*> luci  add Luci support ,it mean web GUI support,it is defaultes
LuCI—>2. Modules  ---> <*> luci-i18n-chinese   add chinese also you can choose others.
6,Make ,you can add V=s to see more message ,also add -j4 to use quad core to work .
make
when compile finish bin/sunxi/ dir have a image,file name:openwrt-sunxi-BPI-XX-sdcard-vfat-ext4.img,i compile is BPI-R1,so name is :openwrt-sunxi-BPI-R1-sdcard-vfat-ext4.img,
7, use USB Image Tool burn image to sd,insert BPI-R1 and booting it.
8 running :
(bpi team) #2
Kernel booting message display:
[    0.000000] Linux version 3.18.19 (charli@charli-pc) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 unknown) ) #3 SMP PREEMPT Mon Aug 24 22:13:58 CST 2015
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[    0.000000] Machine model: BPI R1
[    0.000000] On node 0 totalpages: 260096
[    0.000000] free_area_init_node: node 0, pgdat c0503740, node_mem_map ef00a000
[    0.000000]   Normal zone: 1520 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 194560 pages, LIFO batch:31
[    0.000000]   HighMem zone: 512 pages used for memmap
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] PERCPU: Embedded 9 pages/cpu @eefe1000 s6272 r8192 d22400 u36864
[    0.000000] pcpu-alloc: s6272 r8192 d22400 u36864 alloc=9*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258576
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk rootwait root=/dev/mmcblk0p2
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1025388K/1040384K available (3811K kernel code, 169K rwdata, 1068K rodata, 200K init, 606K bss, 14996K reserved, 262144K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xffe00000   (2048 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04cbef4   (4880 kB)
[    0.000000]       .init : 0xc04cc000 - 0xc04fe000   ( 200 kB)
[    0.000000]       .data : 0xc04fe000 - 0xc0528738   ( 170 kB)
[    0.000000]        .bss : 0xc0528738 - 0xc05c0048   ( 607 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
[    0.000022] Switching to timer-based delay loop, resolution 41ns
[    0.000352] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[    0.000510] sched_clock: 32 bits at 160MHz, resolution 6ns, wraps every 26843545593ns
[    0.000673] Console: colour dummy device 80x30
[    0.000702] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000718] pid_max: default: 32768 minimum: 301
[    0.000824] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000837] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001454] CPU: Testing write buffer coherency: ok
[    0.001761] /cpus/cpu@0 missing clock-frequency property
[    0.001778] /cpus/cpu@1 missing clock-frequency property
[    0.001791] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001847] Setting up static identity map for 0x40011b68 - 0x40011b9c
[    0.060422] CPU1: Booted secondary processor
[    0.060466] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.060535] Brought up 2 CPUs
[    0.060557] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.060564] CPU: All CPU(s) started in HYP mode.
[    0.060569] CPU: Virtualization extensions available.
[    0.064967] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.065370] pinctrl core: initialized pinctrl subsystem
[    0.065762] regulator-dummy: no parameters
[    0.071879] NET: Registered protocol family 16
[    0.072229] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.111482] reg-fixed-voltage ahci-5v: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/ahci_pwr_pin@0, deferring probe
[    0.111521] platform ahci-5v: Driver reg-fixed-voltage requests probe deferral
[    0.111550] reg-fixed-voltage usb1-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb1_vbus_pin@0, deferring probe
[    0.111565] platform usb1-vbus: Driver reg-fixed-voltage requests probe deferral
[    0.111589] reg-fixed-voltage usb2-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb2_vbus_pin@0, deferring probe
[    0.111603] platform usb2-vbus: Driver reg-fixed-voltage requests probe deferral
[    0.111817] vcc3v0: 3000 mV
[    0.112040] vcc3v3: 3300 mV
[    0.112264] vcc5v0: 5000 mV
[    0.112345] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/gmac_power_pin@0, deferring probe
[    0.112362] platform gmac-3v3: Driver reg-fixed-voltage requests probe deferral
[    0.112811] SCSI subsystem initialized
[    0.112885] libata version 3.00 loaded.
[    0.113197] usbcore: registered new interface driver usbfs
[    0.113274] usbcore: registered new interface driver hub
[    0.113403] usbcore: registered new device driver usb
[    0.113546] pps_core: LinuxPPS API ver. 1 registered
[    0.113553] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.113584] PTP clock support registered
[    0.114654] Switched to clocksource arch_sys_counter
[    0.121779] NET: Registered protocol family 2
[    0.122818] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.122902] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.123024] TCP: Hash tables configured (established 8192 bind 8192)
[    0.123105] TCP: reno registered
[    0.123122] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.123179] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.123443] NET: Registered protocol family 1
[    0.124957] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.125108] audit: initializing netlink subsys (disabled)
[    0.125185] audit: type=2000 audit(0.110:1): initialized
[    0.133939] VFS: Disk quotas dquot_6.5.2
[    0.134207] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.135970] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.135994] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.136719] msgmni has been set to 1490
[    0.138903] bounce: pool size: 64 pages
[    0.138931] io scheduler noop registered
[    0.138946] io scheduler deadline registered
[    0.138996] io scheduler cfq registered (default)
[    0.139318] platform 1c13400.phy: Driver sun4i-usb-phy requests probe deferral
[    0.142025] sun7i-a20-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.184985] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.187319] console [ttyS0] disabled
[    0.207743] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[    0.828354] console [ttyS0] enabled
[    0.854828] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.886744] 1c29c00.serial: ttyS2 at MMIO 0x1c29c00 (irq = 52, base_baud = 1500000) is a U6_16550A
[    0.899279] platform 1c50000.ethernet: Driver stmmaceth requests probe deferral
[    0.906754] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.913282] ehci-platform: EHCI generic platform driver
[    0.918683] platform 1c14000.usb: Driver ehci-platform requests probe deferral
[    0.926000] platform 1c1c000.usb: Driver ehci-platform requests probe deferral
[    0.933320] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.939546] ohci-platform: OHCI generic platform driver
[    0.944901] platform 1c14400.usb: Driver ohci-platform requests probe deferral
[    0.952185] platform 1c1c400.usb: Driver ohci-platform requests probe deferral
[    0.959587] usbcore: registered new interface driver usb-storage
[    0.965867] mousedev: PS/2 mouse device common for all mice
[    0.971551] 1c22800.lradc supply vref not found, using dummy regulator
[    0.978474] input: 1c22800.lradc as /devices/soc@01c00000/1c22800.lradc/input/input0
[    0.991771] axp20x-regulator axp20x-regulator: regulators node not found
[    0.998630] LDO1: 1300 mV
[    1.001767] LDO2: at 3000 mV
[    1.005157] LDO3: at 2275 mV
[    1.008294] LDO4: at 2800 mV
[    1.011695] LDO5: at 2800 mV
[    1.015085] DCDC2: at 1400 mV
[    1.018533] DCDC3: at 1250 mV
[    1.021668] axp20x 0-0034: AXP20X driver loaded
[    1.027508] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.036066] sunxi-mmc 1c0f000.mmc: No vqmmc regulator found
[    1.041994] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.084877] sunxi-mmc 1c0f000.mmc: base:0xf00fa000 irq:64
[    1.092685] sunxi-ss 1c15000.crypto-engine: Die ID 0
[    1.099853] TCP: cubic registered
[    1.103201] Initializing XFRM netlink socket
[    1.107611] NET: Registered protocol family 17
[    1.112178] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.124806] 8021q: 802.1Q VLAN Support v1.8
[    1.129125] Registering SWP/SWPB emulation handler
[    1.134455] registered taskstats version 1
[    1.139223] ahci-5v: 5000 mV
[    1.142597] usb1-vbus: 5000 mV
[    1.147273] usb2-vbus: 5000 mV
[    1.150752] gmac-3v3: 3300 mV
[    1.192892] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.203577] mmc0: new high speed SDHC card at address 0001
[    1.209591] mmcblk0: mmc0:0001 00000 7.44 GiB
[    1.215221]  mmcblk0: p1 p2
[    1.264746] stmmaceth 1c50000.ethernet: no reset control found
[    1.270578]  Ring mode enabled
[    1.273630]  No HW DMA feature register supported
[    1.278179]  Normal descriptors
[    1.281500]  TX Checksum insertion supported
[    1.292504] libphy: stmmac: probed
[    1.295950] eth0: PHY ID 03625f24 at 0 IRQ POLL (stmmac-0:00) active
[    1.302298] eth0: PHY ID 03625f24 at 1 IRQ POLL (stmmac-0:01)
[    1.308050] eth0: PHY ID 03625f24 at 2 IRQ POLL (stmmac-0:02)
[    1.313789] eth0: PHY ID 03625f24 at 3 IRQ POLL (stmmac-0:03)
[    1.319538] eth0: PHY ID 03625f24 at 4 IRQ POLL (stmmac-0:04)
[    1.325287] eth0: PHY ID 03625f24 at 30 IRQ POLL (stmmac-0:1e)
[    1.331456] ehci-platform 1c14000.usb: EHCI Host Controller
[    1.337154] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[    1.345031] ehci-platform 1c14000.usb: irq 71, io mem 0x01c14000
[    1.364665] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[    1.370952] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.377753] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.384988] usb usb1: Product: EHCI Host Controller
[    1.389862] usb usb1: Manufacturer: Linux 3.18.19 ehci_hcd
[    1.395353] usb usb1: SerialNumber: 1c14000.usb
[    1.400464] hub 1-0:1.0: USB hub found
[    1.404250] hub 1-0:1.0: 1 port detected
[    1.408963] ehci-platform 1c1c000.usb: EHCI Host Controller
[    1.414564] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[    1.422482] ehci-platform 1c1c000.usb: irq 72, io mem 0x01c1c000
[    1.444681] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    1.450961] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.457766] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.464991] usb usb2: Product: EHCI Host Controller
[    1.469865] usb usb2: Manufacturer: Linux 3.18.19 ehci_hcd
[    1.475355] usb usb2: SerialNumber: 1c1c000.usb
[    1.480460] hub 2-0:1.0: USB hub found
[    1.484246] hub 2-0:1.0: 1 port detected
[    1.488775] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[    1.495451] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[    1.503327] ohci-platform 1c14400.usb: irq 96, io mem 0x01c14400
[    1.568861] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.575669] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.582883] usb usb3: Product: Generic Platform OHCI controller
[    1.588814] usb usb3: Manufacturer: Linux 3.18.19 ohci_hcd
[    1.594296] usb usb3: SerialNumber: 1c14400.usb
[    1.599360] hub 3-0:1.0: USB hub found
[    1.603146] hub 3-0:1.0: 1 port detected
[    1.607711] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    1.614350] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[    1.622242] ohci-platform 1c1c400.usb: irq 97, io mem 0x01c1c400
[    1.688838] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.695643] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.702858] usb usb4: Product: Generic Platform OHCI controller
[    1.708790] usb usb4: Manufacturer: Linux 3.18.19 ohci_hcd
[    1.714271] usb usb4: SerialNumber: 1c1c400.usb
[    1.719358] hub 4-0:1.0: USB hub found
[    1.723148] hub 4-0:1.0: 1 port detected
[    1.732286] ahci-5v: disabling
[    1.735459] vcc5v0: disabling
[    1.738427] vcc3v0: disabling
[    1.743698] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.752677] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.766260] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.773791] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.780839] Freeing unused kernel memory: 200K (c04cc000 - c04fe000)
[    1.804732] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    1.896387] init: Console is alive
[    1.900086] init: - watchdog -
[    1.956437] usb 2-1: New USB device found, idVendor=0bda, idProduct=8178
[    1.963264] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.970476] usb 2-1: Product: 802.11n WLAN Adapter
[    1.975289] usb 2-1: Manufacturer: Realtek
[    1.979482] usb 2-1: SerialNumber: 00e04c000001
[    2.114708] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    2.122202] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1
[    2.128109] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    2.137085] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc
[    2.146090] scsi host0: ahci_platform
[    2.150140] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
[    2.504668] ata1: SATA link down (SStatus 0 SControl 300)
[    2.903980] init: - preinit -
[    3.049304] b53_common: found switch: BCM53125, rev 4
[    3.064921]  RX IPC Checksum Offload disabled
[    3.069283]  No MAC Management Counters available
[    4.240130] random: mktemp urandom read with 5 bits of entropy available
[    5.044697] stmmaceth 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[    7.303617] mount_root: mounting /dev/root
[    7.313783] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    7.324800] procd: - early -
[    7.327825] procd: - watchdog -
[    8.196631] procd: - ubus -
[    9.200629] procd: - init -
[    9.740779] NET: Registered protocol family 10
[    9.750621] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    9.781222] Loading modules backported from Linux version master-2015-03-09-0-g141f155
[    9.789242] Backport generated by backports.git backports-20150129-0-gdd4a670
[    9.797957] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.808055] nf_conntrack version 0.5.0 (16024 buckets, 64096 max)
[    9.895305] xt_time: kernel timezone is -0000
[    9.909554] cfg80211: Calling CRDA to update world regulatory domain
[    9.916314] cfg80211: World regulatory domain updated:
[    9.921471] cfg80211:  DFS Master region: unset
[    9.926943] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    9.936834] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    9.944963] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    9.952992] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    9.961171] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    9.969328] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    9.978922] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    9.987125] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    9.995867] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   10.033695] PPP generic driver version 2.4.2
[   10.039216] NET: Registered protocol family 24
[   10.057795] rtl8192cu: Chip version 0x11
[   10.148074] rtl8192cu: MAC address: ac:a2:13:5c:96:bf
[   10.153232] rtl8192cu: Board Type 0
[   10.164227] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[   10.170284] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[   10.177753] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[   10.179863] usbcore: registered new interface driver rtl8192cu
[   11.862773] random: nonblocking pool is initialized
[   14.869421] b53_common: found switch: BCM53125, rev 4
[   14.899568]  RX IPC Checksum Offload disabled
[   14.916057]  No MAC Management Counters available
[   14.921020] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   16.864711] stmmaceth 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   16.872809] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  220.810635] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[  221.264426] rtl8192cu: MAC auto ON okay!
[  221.301871] rtl8192cu: Tx queue select: 0x05
[  221.725855] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  221.734477] device wlan0 entered promiscuous mode
[  221.739510] br-lan: port 1(wlan0) entered forwarding state
[  221.745096] br-lan: port 1(wlan0) entered forwarding state
[  221.752455] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[  221.772506] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  223.741765] br-lan: port 1(wlan0) entered forwarding state
#3
Please post iperf results for the ‘official’ OpenWRT image so that they can be compared to the community’s: http://www.bananapi.com/index.php/forum/general/1157-openwrt-chaos-calmer-3rd-test-version-gigabit-and-temp-sensors-10-08-15?start=54#3516
(bpi team) #4
ok, we will try to do this .thank you
