Hostapd wifi speed not reach the maximum in Debian11
Hello,
I would like to ask if any one know how to make hostapd wifi AP speed reach 850Mbps , my hostapd.conf not reach more than 100 Mbps.
Please note I tried any comment line for reach the make line speed (850 Mbps)
My Speed test
Testing download speed................................................................................
Download: 824.44 Mbit/s
Testing upload speed......................................................................................................
Upload: 483.48 Mbit/s
Hostapd.conf
interface=wlan1
driver=nl80211
hw_mode=a
channel=0 # Choose an available channel
country_code=IT  # Set your appropriate country code
#ieee80211ac=1
ieee80211n=1
### IEEE 802.11ac
ieee80211ac=1
#vht_oper_chwidth=1
#vht_capab=[MAX-MPDU-11454][RXLDPC][SHORT-GI-80][TX-STBC-2BY1][RX-STBC-1][MAX-A-MPDU-LEN-EXP7][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN]
###WMM
wmm_enabled=1
uapsd_advertisement_enabled=1
wmm_ac_bk_cwmin=4
wmm_ac_bk_cwmax=10
wmm_ac_bk_aifs=7
wmm_ac_bk_txop_limit=0
wmm_ac_bk_acm=0
wmm_ac_be_aifs=3
wmm_ac_be_cwmin=4
wmm_ac_be_cwmax=10
wmm_ac_be_txop_limit=0
wmm_ac_be_acm=0
wmm_ac_vi_aifs=2
wmm_ac_vi_cwmin=3
wmm_ac_vi_cwmax=4
wmm_ac_vi_txop_limit=94
wmm_ac_vi_acm=0
wmm_ac_vo_aifs=2
wmm_ac_vo_cwmin=2
wmm_ac_vo_cwmax=3
wmm_ac_vo_txop_limit=47
wmm_ac_vo_acm=0
### TX queue parameters
tx_queue_data3_aifs=7
tx_queue_data3_cwmin=15
tx_queue_data3_cwmax=1023
tx_queue_data3_burst=0
tx_queue_data2_aifs=3
tx_queue_data2_cwmin=15
tx_queue_data2_cwmax=63
tx_queue_data2_burst=0
tx_queue_data1_aifs=1
tx_queue_data1_cwmin=7
tx_queue_data1_cwmax=15
tx_queue_data1_burst=3.0
tx_queue_data0_aifs=1
tx_queue_data0_cwmin=3
tx_queue_data0_cwmax=7
tx_queue_data0_burst=1.5
ieee80211d=1          # limit the frequencies used to those allowed in the country
auth_algs=1           # 1=wpa, 2=wep, 3=both
#vht_capab=[MAX-AMSDU-3839][SHORT-GI-80]
#vht_oper_chwidth=1
#ht_capab=[HT80+][SHORT-GI-80]
ht_capab=[]   # auto
#ht_capab=[HT40+][SHORT-GI-20][SHORT-GI-40][DSSS_CCK-40]
#vht_capab=[SHORT-GI-80][TX-STBC-2BY1][RX-STBC-1][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7]
vht_capab=[]  # auto
ssid=wifi
wpa=2
wpa_passphrase=password
wpa_key_mgmt=WPA-PSK
wpa_pairwise=CCMP
rsn_pairwise=CCMP
Which device you are using? You should look into iw list which channels allow multichannel (mostly configured channel is centered)
I am using BPI R3 I tried channel 36 and the same result (100 Mbps)
Wiphy phy1
        wiphy index: 1
        max # scan SSIDs: 4
        max scan IEs length: 2190 bytes
        max # sched scan SSIDs: 0
        max # match sets: 0
        Retry short limit: 7
        Retry long limit: 4
        Coverage class: 0 (up to 0m)
        Device supports RSN-IBSS.
        Device supports AP-side u-APSD.
        Device supports T-DLS.
        Supported Ciphers:
                * WEP40 (00-0f-ac:1)
                * WEP104 (00-0f-ac:5)
                * TKIP (00-0f-ac:2)
                * CCMP-128 (00-0f-ac:4)
                * CCMP-256 (00-0f-ac:10)
                * GCMP-128 (00-0f-ac:8)
                * GCMP-256 (00-0f-ac:9)
                * CMAC (00-0f-ac:6)
                * CMAC-256 (00-0f-ac:13)
                * GMAC-128 (00-0f-ac:11)
                * GMAC-256 (00-0f-ac:12)
        Available Antennas: TX 0xf RX 0xf
        Configured Antennas: TX 0xf RX 0xf
        Supported interface modes:
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
        Band 2:
                Capabilities: 0x9ff
                        RX LDPC
                        HT20/HT40
                        SM Power Save disabled
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        Max AMSDU length: 7935 bytes
                        No DSSS/CCK HT40
                Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                Minimum RX AMPDU time spacing: 4 usec (0x05)
                HT TX/RX MCS rate indexes supported: 0-31
                VHT Capabilities (0x339b79f6):
                        Max MPDU length: 11454
                        Supported Channel Width: 160 MHz
                        RX LDPC
                        short GI (80 MHz)
                        short GI (160/80+80 MHz)
                        TX STBC
                        SU Beamformer
                        SU Beamformee
                        MU Beamformer
                        MU Beamformee
                        RX antenna pattern consistency
                        TX antenna pattern consistency
                VHT RX MCS set:
                        1 streams: MCS 0-9
                        2 streams: MCS 0-9
                        3 streams: MCS 0-9
                        4 streams: MCS 0-9
                        5 streams: not supported
                        6 streams: not supported
                        7 streams: not supported
                        8 streams: not supported
                VHT RX highest supported: 0 Mbps
                VHT TX MCS set:
                        1 streams: MCS 0-9
                        2 streams: MCS 0-9
                        3 streams: MCS 0-9
                        4 streams: MCS 0-9
                VHT TX highest supported: 0 Mbps
                HE Iftypes: Station
                        HE MAC Capabilities (0x08011a000040):
                                +HTC HE Supported
                                Trigger Frame MAC Padding Duration: 2
                                OM Control
                                Maximum A-MPDU Length Exponent: 3
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x5c70ce126d00f3164e3f00):
                                HE40/HE80/5GHz
                                HE160/5GHz
                                HE160/HE80+80/5GHz
                                242 tone RUs/5GHz
                                Device Class: 1
                                LDPC Coding in Payload
                                HE SU PPDU with 1x HE-LTF and 0.8us GI
                                NDP with 4x HE-LTF and 3.2us GI
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                Full Bandwidth UL MU-MIMO
                                Partial Bandwidth UL MU-MIMO
                                DCM Max Constellation: 2
                                DCM Max Constellation Rx: 2
                                SU Beamformee
                                Beamformee STS <= 80Mhz: 3
                                Beamformee STS > 80Mhz: 3
                                Codebook Size SU Feedback
                                Codebook Size MU Feedback
                                Triggered CQI Feedback
                                Partial Bandwidth Extended Range
                                Partial Bandwidth DL MU-MIMO
                                PPE Threshold Present
                                Power Boost Factor ar
                                HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
                                Max NC: 2
                                20MHz in 40MHz HE PPDU 2.4GHz
                                20MHz in 160/80+80MHz HE PPDU
                                80MHz in 160/80+80MHz HE PPDU
                                DCM Max BW: 1
                                Longer Than 16HE SIG-B OFDM Symbols
                                Non-Triggered CQI Feedback
                                TX 1024-QAM
                                RX 1024-QAM
                                RX Full BW SU Using HE MU PPDU with Compression SIGB
                                RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
                        HE RX MCS and NSS set <= 80 MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                        HE TX MCS and NSS set <= 80 MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                        HE RX MCS and NSS set 160 MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                        HE TX MCS and NSS set 160 MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                        HE RX MCS and NSS set 80+80 MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                        HE TX MCS and NSS set 80+80 MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                        PPE Threshold 0x3b 0x1c 0xc7 0x71 0x1c 0xc7 0x71 0x1c 0xc7 0x71
                HE Iftypes: AP
                        HE MAC Capabilities (0x00051a081044):
                                +HTC HE Supported
                                TWT Responder
                                BSR
                                OM Control
                                BQR
                                A-MSDU in A-MPDU
                                OM Control UL MU Data Disable RX
                        HE PHY Capabilities: (0x1c20ce926f1bafd0000c00):
                                HE40/HE80/5GHz
                                HE160/5GHz
                                HE160/HE80+80/5GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformer
                                SU Beamformee
                                MU Beamformer
                                Sounding Dimensions <= 80Mhz: 3
                                Sounding Dimensions > 80Mhz: 3
                                Triggered SU Beamforming Feedback
                                Triggered MU Beamforming Feedback
                                Max NC: 2
                                STBC Tx > 80MHz
                                STBC Rx > 80MHz
                                TX 1024-QAM
                                RX 1024-QAM
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                HE Iftypes: Mesh
                        HE MAC Capabilities (0x00011a000040):
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x1c200c0000000000008000):
                                HE40/HE80/5GHz
                                HE160/5GHz
                                HE160/HE80+80/5GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                Bitrates (non-HT):
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 5180 MHz [36] (23.0 dBm)
                        * 5200 MHz [40] (23.0 dBm)
                        * 5220 MHz [44] (23.0 dBm)
                        * 5240 MHz [48] (23.0 dBm)
                        * 5260 MHz [52] (20.0 dBm) (radar detection)
                        * 5280 MHz [56] (20.0 dBm) (radar detection)
                        * 5300 MHz [60] (20.0 dBm) (radar detection)
                        * 5320 MHz [64] (20.0 dBm) (radar detection)
                        * 5500 MHz [100] (26.0 dBm) (radar detection)
                        * 5520 MHz [104] (26.0 dBm) (radar detection)
                        * 5540 MHz [108] (26.0 dBm) (radar detection)
                        * 5560 MHz [112] (26.0 dBm) (radar detection)
                        * 5580 MHz [116] (26.0 dBm) (radar detection)
                        * 5600 MHz [120] (26.0 dBm) (radar detection)
                        * 5620 MHz [124] (26.0 dBm) (radar detection)
                        * 5640 MHz [128] (26.0 dBm) (radar detection)
                        * 5660 MHz [132] (26.0 dBm) (radar detection)
                        * 5680 MHz [136] (26.0 dBm) (radar detection)
                        * 5700 MHz [140] (26.0 dBm) (radar detection)
                        * 5720 MHz [144] (13.0 dBm) (radar detection)
                        * 5745 MHz [149] (13.0 dBm)
                        * 5765 MHz [153] (13.0 dBm)
                        * 5785 MHz [157] (13.0 dBm)
                        * 5805 MHz [161] (13.0 dBm)
                        * 5825 MHz [165] (13.0 dBm)
                        * 5845 MHz [169] (13.0 dBm)
                        * 5865 MHz [173] (13.0 dBm)
        Supported commands:
                 * new_interface
                 * set_interface
                 * new_key
                 * start_ap
                 * new_station
                 * new_mpath
                 * set_mesh_config
                 * set_bss
                 * authenticate
                 * associate
                 * deauthenticate
                 * disassociate
                 * join_ibss
                 * join_mesh
                 * remain_on_channel
                 * set_tx_bitrate_mask
                 * frame
                 * frame_wait_cancel
                 * set_wiphy_netns
                 * set_channel
                 * tdls_mgmt
                 * tdls_oper
                 * probe_client
                 * set_noack_map
                 * register_beacons
                 * start_p2p_device
                 * set_mcast_rate
                 * connect
                 * disconnect
                 * channel_switch
                 * set_qos_map
                 * set_multicast_to_unicast
                 * Unknown command (140)
        software interface modes (can always be added):
                 * AP/VLAN
                 * monitor
        valid interface combinations:
                 * #{ IBSS } <= 1, #{ AP, mesh point } <= 16, #{ managed } <= 19,
                   total <= 19, #channels <= 1, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz, 80+80 MHz, 160 MHz }
        HT Capability overrides:
                 * MCS: ff ff ff ff ff ff ff ff ff ff
                 * maximum A-MSDU length
                 * supported channel width
                 * short GI for 40 MHz
                 * max A-MPDU length exponent
                 * min MPDU start spacing
        Device supports TX status socket option.
        Device supports HT-IBSS.
        Device supports SAE with AUTHENTICATE command
        Device supports low priority scan.
        Device supports scan flush.
        Device supports AP scan.
        Device supports per-vif TX power setting
        Driver supports full state transitions for AP/GO clients
        Driver supports a userspace MPM
        Device supports active monitor (which will ACK incoming frames)
        Device supports configuring vdev MAC-addr on create.
        max # scan plans: 1
        max scan plan interval: -1
        max scan plan iterations: 0
        Supported TX frame types:
                 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
        Supported RX frame types:
                 * IBSS: 0x40 0xb0 0xc0 0xd0
                 * managed: 0x40 0xb0 0xd0
                 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * mesh point: 0xb0 0xc0 0xd0
                 * P2P-client: 0x40 0xd0
                 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * P2P-device: 0x40 0xd0
        Supported extended features:
                * [ VHT_IBSS ]: VHT-IBSS
                * [ RRM ]: RRM
                * [ BEACON_RATE_LEGACY ]: legacy beacon rate setting
                * [ BEACON_RATE_HT ]: HT beacon rate setting
                * [ BEACON_RATE_VHT ]: VHT beacon rate setting
                * [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
                * [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
                * [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
                * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
                * [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
                * [ AQL ]: Airtime Queue Limits (AQL)
                * [ SCAN_RANDOM_SN ]: use random sequence numbers in scans
                * [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
                * [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
                * [ DEL_IBSS_STA ]: deletion of IBSS station support
                * [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
                * [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 4
        max scan IEs length: 2200 bytes
        max # match sets: 0
        Retry long limit: 4
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                * CMAC (00-0f-ac:6)
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
        Band 1:
                Capabilities: 0x9ff
                        RX LDPC
                        HT20/HT40
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        No DSSS/CCK HT40
                HE Iftypes: Station
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x2270ce126d00f3164e3f00):
                                HE40/2.4GHz
                                242 tone RUs/2.4GHz
                                Device Class: 1
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformee
                                Max NC: 2
                                DCM Max BW: 1
                                TX 1024-QAM
                                RX 1024-QAM
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                HE Iftypes: AP
                                +HTC HE Supported
                                TWT Responder
                                BSR
                                OM Control
                                BQR
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x0220ce926f1bafd0000c00):
                                HE40/2.4GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                SU Beamformer
                                SU Beamformee
                                MU Beamformer
                                Max NC: 2
                                STBC Tx > 80MHz
                                STBC Rx > 80MHz
                                TX 1024-QAM
                                RX 1024-QAM
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                HE Iftypes: Mesh
                                +HTC HE Supported
                                OM Control
                                A-MSDU in A-MPDU
                        HE PHY Capabilities: (0x02200c0000000000008000):
                                HE40/2.4GHz
                                STBC Tx <= 80MHz
                                STBC Rx <= 80MHz
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                                         1 streams: MCS 0-11
                                         2 streams: MCS 0-11
                                         3 streams: MCS 0-11
                                         4 streams: MCS 0-11
                Bitrates (non-HT):
                        * 1.0 Mbps (short preamble supported)
                        * 2.0 Mbps (short preamble supported)
                        * 5.5 Mbps (short preamble supported)
                        * 11.0 Mbps (short preamble supported)
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 2412 MHz [1] (20.0 dBm)
                        * 2417 MHz [2] (20.0 dBm)
                        * 2422 MHz [3] (20.0 dBm)
                        * 2427 MHz [4] (20.0 dBm)
                        * 2432 MHz [5] (20.0 dBm)
                        * 2437 MHz [6] (20.0 dBm)
                        * 2442 MHz [7] (20.0 dBm)
                        * 2447 MHz [8] (20.0 dBm)
                        * 2452 MHz [9] (20.0 dBm)
                        * 2457 MHz [10] (20.0 dBm)
                        * 2462 MHz [11] (20.0 dBm)
                        * 2467 MHz [12] (20.0 dBm)
                        * 2472 MHz [13] (20.0 dBm)
                        * 2484 MHz [14] (disabled)
        Supported commands:
                 * new_interface
                 * set_interface
                 * new_key
                 * start_ap
                 * new_station
                 * new_mpath
                 * set_mesh_config
                 * set_bss
                 * authenticate
                 * associate
                 * deauthenticate
                 * disassociate
                 * join_ibss
                 * join_mesh
                 * remain_on_channel
                 * frame
                 * frame_wait_cancel
                 * set_wiphy_netns
                 * set_channel
                 * tdls_mgmt
                 * tdls_oper
                 * probe_client
                 * set_noack_map
                 * register_beacons
                 * start_p2p_device
                 * set_mcast_rate
                 * connect
                 * disconnect
                 * channel_switch
                 * set_qos_map
                 * AP/VLAN
                 * monitor
        max # scan plans: 1
                * [ RRM ]: RRM
Try channel 161 with vht80/160
vht_oper_chwidth=1
ieee80211ac=1
vht_capab= [SHORT-GI-80][SHORT-GI-160]
systemctl status hostapd.service
● hostapd.service - Access point and authentication server for Wi-Fi and Ethernet
     Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
     Active: activating (auto-restart) (Result: exit-code) since Mon 2024-03-25 16:39:43 CET; 367ms ago
       Docs: man:hostapd(8)
    Process: 465234 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1/FAILURE)
        CPU: 12ms
Mar 25 16:39:43 AlmaOS systemd[1]: hostapd.service: Control process exited, code=exited, status=1/FAILURE
Mar 25 16:39:43 AlmaOS systemd[1]: hostapd.service: Failed with result 'exit-code'.
Mar 25 16:39:43 AlmaOS systemd[1]: Failed to start Access point and authentication server for Wi-Fi and Ethernet.
Channelwidth needs to be greater afaik
ht_capab=[]
vht_oper_chwidth=2
     Active: failed (Result: exit-code) since Mon 2024-03-25 17:02:31 CET; 39s ago
    Process: 521367 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1/FAILURE)
        CPU: 9ms
Mar 25 17:02:31 AlmaOS systemd[1]: hostapd.service: Scheduled restart job, restart counter is at 28.
Mar 25 17:02:31 AlmaOS systemd[1]: Stopped Access point and authentication server for Wi-Fi and Ethernet.
Mar 25 17:02:31 AlmaOS systemd[1]: hostapd.service: Start request repeated too quickly.
Mar 25 17:02:31 AlmaOS systemd[1]: hostapd.service: Failed with result 'exit-code'.
Mar 25 17:02:31 AlmaOS systemd[1]: Failed to start Access point and authentication server for Wi-Fi and Ethernet.
hostapd -d /etc/hostapd/hostapd.conf
random: getrandom() support available
Configuration file: /etc/hostapd/hostapd.conf
nl80211: TDLS supported
nl80211: TDLS external setup
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:10
nl80211: Supported cipher 00-0f-ac:8
nl80211: Supported cipher 00-0f-ac:9
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported cipher 00-0f-ac:13
nl80211: Supported cipher 00-0f-ac:11
nl80211: Supported cipher 00-0f-ac:12
nl80211: Using driver-based off-channel TX
nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 00 00 40 00 00 00 00 40
nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 00 00 40 00 00 00 00 40
nl80211: interface wlan1 in phy phy1
nl80211: Set mode ifindex 17 iftype 3 (AP)
nl80211: Failed to set interface 17 to mode 3: -16 (Device or resource busy)
nl80211: Try mode change after setting interface down
nl80211: Mode change succeeded while interface is down
nl80211: Setup AP(wlan1) - device_ap_sme=0 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x55878bbc30
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x55878bbc30 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x55878bbc30 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x55878bbc30 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x55878bbc30 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x55878bbc30 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x55878bbc30 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=0503
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=12
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55878bbc30 match=7f
rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
nl80211: Add own interface ifindex 17 (ifidx_reason -1)
nl80211: if_indices[16]: 17(-1)
phy: phy1
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Previous country code IT, new country code IT
nl80211: Regulatory information - country=IT (DFS-ETSI)
nl80211: 2400-2483 @ 40 MHz 20 mBm
nl80211: 5150-5250 @ 80 MHz 23 mBm (no outdoor)
nl80211: 5250-5350 @ 80 MHz 20 mBm (no outdoor) (DFS)
nl80211: 5470-5725 @ 160 MHz 26 mBm (DFS)
nl80211: 5725-5875 @ 80 MHz 13 mBm
nl80211: 57000-66000 @ 2160 MHz 40 mBm
nl80211: Mode IEEE 802.11a: 5180 5200 5220 5240 5260[RADAR] 5280[RADAR] 5300[RADAR] 5320[RADAR] 5500[RADAR] 5520[RADAR] 5540[RADAR] 5560[RADAR] 5580[RADAR] 5600[RADAR] 5620[RADAR] 5640[RADAR] 5660[RADAR] 5680[RADAR]
hw vht capab: 0x339b79f6, conf vht capab: 0x60
Completing interface initialization
Mode: IEEE 802.11a  Channel: 36  Frequency: 5180 MHz
DFS chan_idx seems wrong; num-ch: 27 ch-no: -6 conf-ch-no: 36 11n: 1 sec-ch: 0 vht-oper-width: 1
Available channel: 36
Available channel: 40
Available channel: 44
Available channel: 48
Available channel: 52
Available channel: 56
Available channel: 60
Available channel: 64
Available channel: 100
Available channel: 104
Available channel: 108
Available channel: 112
Available channel: 116
Available channel: 120
Available channel: 124
Available channel: 128
Available channel: 132
Available channel: 136
Available channel: 140
Available channel: 144
Available channel: 149
Available channel: 153
Available channel: 157
Available channel: 161
Available channel: 165
Available channel: 169
Available channel: 173
Interface initialization failed
wlan1: interface state COUNTRY_UPDATE->DISABLED
wlan1: AP-DISABLED
wlan1: Unable to setup interface.
hostapd_interface_deinit_free(0x55878b39a0)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x55878b39a0)
wlan1: interface state DISABLED->DISABLED
hostapd_bss_deinit: deinit bss wlan1
wlan1: Deauthenticate all stations
nl80211: send_mlme - da= ff:ff:ff:ff:ff:ff noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3
nl80211: send_mlme -> send_frame
nl80211: send_frame - Use bss->freq=0
nl80211: send_frame -> send_frame_cmd
nl80211: Frame command failed: ret=-22 (Invalid argument) (freq=0 wait=0)
wlan1: AP-DISABLED
hostapd_cleanup(hapd=0x55878b4ff0 (wlan1))
wlan1: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan1 wasn't started
hostapd_interface_deinit_free: driver=0x5580afd670 drv_priv=0x55878b6430 -> hapd_deinit
nl80211: deinit ifname=wlan1 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
nl80211: Remove beacon (ifindex=17)
netlink: Operstate: ifindex=17 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 17 iftype 2 (STATION)
nl80211: Failed to set interface 17 to mode 2: -16 (Device or resource busy)
nl80211: Teardown AP(wlan1) - device_ap_sme=0 use_monitor=0
nl80211: Unsubscribe mgmt frames handle 0x888888dd0f0334b9 (AP teardown)
hostapd_interface_free(0x55878b39a0)
hostapd_interface_free: free hapd 0x55878b4ff0
hostapd_cleanup_iface(0x55878b39a0)
hostapd_cleanup_iface_partial(0x55878b39a0)
hostapd_cleanup_iface: free iface=0x55878b39a0
share the output of the following:
iw reg get
iw dev nameofwifiinterface station dump (connect mobile or pc to wifi network)
if you are in Italy, the only channel which support 160mhz is 100 try the following:
country_code=IT
ieee80211d=1
local_pwr_constraint=0
ieee80211h=1
hw_mode=a
supported_rates=240 360 480 540
basic_rates=240
beacon_int=100
channel=100
chanlist=100
ieee80211n=1
ht_coex=0
ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935]
ieee80211ac=1
vht_oper_chwidth=2
vht_oper_centr_freq_seg0_idx=114
vht_capab=[RXLDPC][SHORT-GI-80][SHORT-GI-160][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-3][BF-ANTENNA-3][VHT160][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7]
ieee80211ax=1
he_oper_chwidth=2
he_oper_centr_freq_seg0_idx=114
he_su_beamformer=1
he_su_beamformee=1
he_mu_beamformer=1
he_bss_color=128
he_spr_sr_control=3
he_default_pe_duration=4
he_rts_threshold=1023
 iw dev wlan1 station dump
Station 02:9d:fd:fe:b8:a2 (on wlan1)
        inactive time:  0 ms
        rx bytes:       1934638
        rx packets:     20355
        tx bytes:       51672692
        tx packets:     36522
        tx retries:     0
        tx failed:      0
        rx drop misc:   0
        signal:         -71 [-76, -85, -75, -75] dBm
        signal avg:     -70 [-76, -85, -75, -74] dBm
        tx bitrate:     130.0 MBit/s MCS 14 short GI
        tx duration:    11141877 us
        rx bitrate:     130.0 MBit/s MCS 15
        rx duration:    1019447 us
        airtime weight: 256
        authorized:     yes
        authenticated:  yes
        associated:     yes
        preamble:       long
        WMM/WME:        yes
        MFP:            no
        TDLS peer:      no
        DTIM period:    2
        beacon interval:100
        short slot time:yes
        connected time: 70 seconds
        associated at [boottime]:       67589.044s
        associated at:  1711384929742 ms
        current time:   1711385000026 ms
Station de:11:cf:17:6c:42 (on wlan1)
        inactive time:  45930 ms
        rx bytes:       43974
        rx packets:     169
        tx bytes:       47846
        tx packets:     123
        tx retries:     0
        tx failed:      0
        rx drop misc:   1
        signal:         -71 [-73, -79, -76, -81] dBm
        signal avg:     -71 [-73, -79, -76, -81] dBm
        tx bitrate:     78.0 MBit/s MCS 12
        tx duration:    502089 us
        rx bitrate:     24.0 MBit/s
        rx duration:    15299 us
        airtime weight: 256
        authorized:     yes
        authenticated:  yes
        associated:     yes
        preamble:       long
        WMM/WME:        yes
        MFP:            no
        TDLS peer:      no
        DTIM period:    2
        beacon interval:100
        short slot time:yes
        connected time: 56 seconds
        associated at [boottime]:       67603.522s
        associated at:  1711384944220 ms
 iw reg get
global
country IT: DFS-ETSI
        (2400 - 2483 @ 40), (N/A, 20), (N/A)
        (5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
        (5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
        (5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
        (5725 - 5875 @ 80), (N/A, 13), (N/A)
        (57000 - 66000 @ 2160), (N/A, 40), (N/A)
I tried it , it return error in hostapd
     Active: failed (Result: exit-code) since Mon 2024-03-25 17:45:58 CET; 5s ago
    Process: 567192 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1/FAILURE)
        CPU: 9ms
Mar 25 17:45:58 AlmaOS systemd[1]: hostapd.service: Scheduled restart job, restart counter is at 34.
Mar 25 17:45:58 AlmaOS systemd[1]: Stopped Access point and authentication server for Wi-Fi and Ethernet.
Mar 25 17:45:58 AlmaOS systemd[1]: hostapd.service: Start request repeated too quickly.
Mar 25 17:45:58 AlmaOS systemd[1]: hostapd.service: Failed with result 'exit-code'.
Mar 25 17:45:58 AlmaOS systemd[1]: Failed to start Access point and authentication server for Wi-Fi and Ethernet.
hostapd -dd /etc/hostapd/hostapd.conf
Line 18: unknown configuration item 'ht_coex'
Line 25: unknown configuration item 'he_oper_chwidth'
Line 26: unknown configuration item 'he_oper_centr_freq_seg0_idx'
Line 27: unknown configuration item 'he_su_beamformer'
Line 28: unknown configuration item 'he_su_beamformee'
Line 29: unknown configuration item 'he_mu_beamformer'
Line 30: unknown configuration item 'he_bss_color'
Line 31: unknown configuration item 'he_spr_sr_control'
Line 32: unknown configuration item 'he_default_pe_duration'
Line 33: unknown configuration item 'he_rts_threshold'
10 errors found in configuration file '/etc/hostapd/hostapd.conf'
Failed to set up interface with /etc/hostapd/hostapd.conf
hostapd_init: free iface 0x55b1adb9a0
Failed to initialize interface
seems you have to rebuilt the hostapd to support AX, anyway try the following:
country_code=IT
ieee80211d=1
ieee80211h=1
hw_mode=a
basic_rates=240
beacon_int=100
channel=100
chanlist=100
ieee80211n=1
ieee80211ac=1
vht_oper_chwidth=2
it work and reach 550 Mbps Thank you very much
