Grub on BPI-R2: kernel starting problem
Hi everyone.
Just wondering if anyone has tried to run OS using GRUB, and if it was successfull?
For now i’ve installed grub (u-boot 2020-01-bpi-r2 from Frank’s repo), i’m able to run it, but i can’t load linux kernel ftom grub.
u-boot env for grub run:
boot19=load mmc 0:1 ${loadaddr} /grub/arm-uboot/core.img; bootm ${loadaddr}
bootmenu_4=5. Run GRUB.=run boot19
Grub Menu:
GNU GRUB  version 2.05_alpha20200110
|*Gentoo GNU/Linux                                                           |
| Advanced options for Gentoo GNU/Linux                                      |
     Use the ^ and v keys to select which entry is highlighted.
     Press enter to boot the selected OS, `e' to edit the commands
     before booting or `c' for a command-line.
cgub.cfg:
menuentry 'Gentoo GNU/Linux' --class gentoo --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-4d920cff-b900-40c2-90c8-ffc716a6656f' {
        load_video
        insmod gzio
        insmod part_msdos
        insmod fat
        if [ x$feature_platform_search_hint = xy ]; then
          search --no-floppy --fs-uuid --set=root  4449-36D1
        else
        fi
        echo    'Loading Linux 5.5.0-rc1-arm+ ...'
        devicetree /bpi-r2.dts
        linux   /vmlinuz-5.5.0-rc1-arm+ root=UUID=4d920cff-b900-40c2-90c8-ffc716a6656f ro root=/dev/sdb1 rootfstype=ext4 rootwait console=earlyprintk console=tty1 fbcon=map:0 console=ttyS0,115200
        echo    'Loading initial ramdisk ...'
        initrd  /initramfs-5.5.0-rc1-arm+.img
root=UUID=4d920cff-b900-40c2-90c8-ffc716a6656f ro root=/dev/sdb1 - are the same drive
/etc/default/grub:
GRUB_DISTRIBUTOR="Gentoo"
GRUB_TERMINAL="console serial"
GRUB_SERIAL_COMMAND="serial --speed=115200 --unit=0 --word=8 --parity=no --stop=1"
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX="root=/dev/sdb1 rootfstype=ext4 rootwait console=earlyprintk console=tty1 fbcon=map:0 console=ttyS0,115200"
Kernel is my 5.5-merged-lima branch based on Frank’s 5.5-merged. It runs w/o any problebs when built by build.sh script for u-boot.
After attempt to boot it prints Loading Linux 5.5.0-rc1-arm+ ... halts for 3-5 secs and resets.
P.S. Looks like uboot has some type of watchdog and restart board after some period of inactivity, if it’s really u-boot, where can i edit timeouts?
uboot has watchdog timeout, but it is ~20 sec of inactivity and shows message before do the reset…
have not tried using grub because one bootloader is enough for me :wink: what do you want to archive with it?
More familiar environment for me, no u-boot image ‘magic’,no uboot env - easy to update kernel, easy to use initramfs(useful for mdadm, zfs, dmraid, etc), new experience :wink:
Where can I disable it or edit timeout? Not very convinient when r2 reboots during reading manuals :slight_smile:.
I didn’t catched the message.
maybe by disabling the watchdog-driver…imho timeout cannot be increased
if not maybe you can start timer again if it is timed-out
It is hardware timer. You should put grup to update watchdog timer regular interval. I don’t know how but I guess that broblem is solved in grub somehow.
Fixed!
The problem was in wrong grub loading address.
Works great with:
load mmc 0:1 0x88000000 /grub/arm-uboot/core.img; bootm 0x88000000
Kernel loads, and works great:
Loading Devicetree ...
Done, starting ...
[    0.000000] Linux version 5.5.0-rc1-arm+ (root@bpi-r2-gentoo) (gcc version 9.2.0 (Gentoo 9.2.0-r2 p3)) #1 SMP Wed Jan 29 23:02:39 PST 2020
[    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] OF: fdt: Machine model: Bananapi BPI-R2
[    0.000000] [WMT-CONSYS-HW][W]reserve_memory_consys_fn: name: consys-reserve-memory, base: 0xffe00000, size: 0x100000
[    0.000000] OF: reserved mem: initialized node consys-reserve-memory, compatible id mediatek,consys-reserve-memory
[    0.000000] cma: Reserved 64 MiB at 0xfb800000
Menuenty for my boot:
    menuentry 'Gentoo GNU/Linux, with Linux 5.5.0-rc1-arm+' --class gentoo --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.5.0-rc1-arm+-advanced-4d920cff-b900-40c2-90c8-ffc716a6656f' {
            load_video
            insmod gzio
            insmod part_msdos
            insmod fat
            else
            fi
            echo  'Loading Devicetree ...'
            devicetree /bpi-r2.dtb
            echo  'Done, starting ...'
P.S. grub is installed to /boot using:
bpi-r2-gentoo ~ # grub-install /boot
Installing for arm-uboot platform.
grub-install: warning: no hints available for your platform. Expect reduced performance.
grub-install: warning: WARNING: no platform-specific install was performed.
Installation finished. No error reported.
P.P.S. My personal benefits using GRUB is to update, install and/or use multiple kernels without modifying u-boot env. :sunglasses:
Small HOWTO:
  • build u-boot (i use Frank’s 2020-01-bpi-r2)
Grub requires u-boot with enabled U-Boot API (enabled from menuconfig)
and
diff --git a/include/configs/mt7623.h b/include/configs/mt7623.h
index e5182aeea8..50c3fc66b0 100644
--- a/include/configs/mt7623.h
+++ b/include/configs/mt7623.h
@@ -15,6 +15,10 @@
 #define CONFIG_SETUP_MEMORY_TAGS
 #define CONFIG_INITRD_TAG
 #define CONFIG_CMDLINE_TAG
+#define CONFIG_SYS_MMC_MAX_DEVICE      2
+#define CONFIG_SYS_SCSI_MAX_DEVICE     2
+#define CONFIG_CMD_EXT2
+#define CONFIG_CMD_ECHO
 #define CONFIG_SYS_MAXARGS             8
 #define CONFIG_SYS_BOOTM_LEN           SZ_64M
(define CONFIG_SYS_MMC_MAX_DEVICE 2 is likely not needed)
  • Install grub
First install grub-uboot package (in gentoo: emerge -av grub with GRUB_PLATFORMS="uboot" defined )
2nd - install grub to /boot: grub-install /boot
  • Modify /etc/default/grub (to enable serial console and add kernel boot barameters):
/etc/default/grub:
  • Create and modify grub config (/boot/grub/grub.cfg)
create:
grub-mkconfig -o /boot/grub/grub.cfg
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.5.0-rc1-arm+
Found initrd image: /boot/initramfs-5.5.0-rc1-arm+.img
Found linux image: /boot/kernel-5.5.0-bananapi
Found linux image: /boot/kernel-5.4.0-bananapi
done
in my case it detects kernels and initramfs files placed in /boot
modify /boot/grub/grub.cfg: in my case i had to add devicetree /bpi-r2.dtb to each menuentry, and some verbose messages, but as i know there is a way to automate it by editing grub templates.
And the last…
  • modify uboot env to boot grub
I’ve changed 1 of boot entry envs to:
boot19=load mmc 0:1 0x88000000 /grub/arm-uboot/core.img; bootm 0x88000000
