bialy39
(Andrzej)
March 19, 2018, 7:52pm
Hello.
Recently I downloaded DNSCrypt-proxy 2 to my BPI-R2 with LEDE (https://github.com/jedisct1/dnscrypt-proxy/releases/tag/2.0.7 )
Program itself is working good but I have few questions about init.d scripts.
dnscrypt-proxy don’t have --daemon option. When I put it to init.d it hanging entire boot process.
Only one solution that I found is to start it is:
(dnscrypt-proxy -config … -pidfile …)&
Is there a possibility to “daemonize” progam in init.d script in LEDE?
Dnscrypt-proxy is starting as root. To change user I put into init.d script:
(sudo -u SomeUser dnscrypt-proxy -config … -pidfile …)&
Is there a other way to run as non-root user in init.d script in LEDE?
After it started as non-root user program didn’t have permission to bind addres: permission denied.
Is there way to set file capabilities in LEDE, like: (https://github.com/jedisct1/dnscrypt-proxy/wiki/installation )
setcap cap_net_bind_service=+pe dnscrypt-proxy
And now off-topic:
My ISP is forcing me to use their router. To avoid this I need to VLAN.
How to complie LEDE with switch support? My swconfig shows notching.
Thank you in advance.
Regards,
Andrzej Bialic
xbgmsharp
(xbgmsharp)
March 19, 2018, 8:11pm
2
To vlan tag traffic you can try:
vconfig add $IFACE $TAGID
For my ISP, i do
vconfig add eth1 6
Then you should have a new interface cal eth1.6 to run pppoe.
bialy39
(Andrzej)
March 19, 2018, 8:31pm
3
I should extend my question more.
On my ISP’s forum https://forum.t-mobile.nl/t-mobile-thuis-algemeen-490/draytek-vervangen-met-je-eigen-router-297061 (Dutch language) I founded this:
IGMP Snooping: uitschakelen (turn off)
IGMP Proxy: uitschakelen (turn off)
IGMP Version: V2 (turn on)
IPTV/VLAN inschakelen (turn on)
Internet Vlan ID: 300 Priority 0
802.1Q tag inschakelen (turn on)
So I witll do some tries.
Thank you.
bialy39
(Andrzej)
March 19, 2018, 9:51pm
5
It’s working like a charm
Only problem is that it’s not saving it permanently and I must do it after every reboot.
Thank you very much for your help
xbgmsharp
(xbgmsharp)
March 19, 2018, 9:53pm
6
To do on boot on debian system
auto wan
iface wan inet manual
pre-up vconfig add $IFACE 6 && ifconfig $IFACE up
pre-down ifconfig $IFACE down && vconfig rem $IFACE 6
bialy39
(Andrzej)
March 19, 2018, 9:58pm
7
I will try to fing out how to make it on LEDE.
Thanks, you made my day anyway.
