Can someone please point me in the right direction to have X11 working?
What I did:
Started with Frank-W’s Debian image
Compiled Framebuffer (as good as I know) into Kernel
Compiled Mali-module
Compiled libdri2, libump, sunxi-mali, and xf86-video-fbturbo
On reboot /var/log/Xorg.0.log shows up like this:
[ 19.051] (II) LoadModule: "fbturbo"
[ 19.051] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 19.052] (II) Module fbturbo: vendor="X.Org Foundation"
[ 19.052] compiled for 1.19.2, module version = 0.4.0
[ 19.052] Module class: X.Org Video Driver
[ 19.052] ABI class: X.Org Video Driver, version 23.0
[ 19.052] (II) FBTURBO: driver for framebuffer: fbturbo
[ 19.053] (WW) Falling back to old probe method for fbturbo
[ 19.053] (II) Loading sub module "fbdevhw"
[ 19.053] (II) LoadModule: "fbdevhw"
[ 19.053] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.053] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 19.053] compiled for 1.19.2, module version = 0.0.2
[ 19.054] ABI class: X.Org Video Driver, version 23.0
[ 19.054] (EE) open /dev/fb0: No such file or directory
[ 19.054] (EE) No devices detected.
It seems I simply forgot something. Can someone help?
simply the graphic-driver for this soc is missing if you try to run the x-server on the real hardware (not virtual like vncserver or similar).
thats the main-problem i got hdmi not working in 4.14. We are till the point that the Multimedia-framework of mediatek (iommu, larb,…) seems to work,but we don’t get any output yet
I thought the mali-driver accompanied by fbturbo would do it. Obviously this is not the case. You mean there are sources missing in the kernel tree? Sorry, I’m still not diving deep enough.
Do you have more hints perhaps where I might look?
There must be a driver in the Ubuntu Image. (Even if it has poor performance) Where did that come from?
The graphic-part in kernel 4.4 was included with first commit (no separate commit with diff) so its hard to find the changes. Maybe you can compare kernel 4.4.70 from kernel.org with that from the github and search for the driver files
Exactly that’s what Im aiming at. What I really want is a piece of hardware which everyone can use with a more or less standard Debian. And all the nice hardware features should be easily usable without need to compile anything.
Under normal circumstances this should be the task of the manufacturer, shouldn’t it?
there are 2 groups of people here which can give support, one is the manufacturer of bpi-r2-board (Sinovoip) and one is the vendor of the SOC (mediatek). Sinovoip is mainly dependent on the vendor. the vendor will submit patches for hdmi inside 4.14 kernel…that take some time because 4.15 is not final released yet
So let’s wait a while. In the meanwhile I might get another project done: Surveillance of my heating using a BPI-M1, a bit of circuit and an I2C 20x4 Display. All called “Heiznane”
